01-04-2021, 17:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 46
Member: 78657 Status: Offline Thanks Meter: 71 | Oppo A31 2020 dead after reset [Answered] after reset the phone is dead Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414202557B90A04731 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Product revision : 0.2 Product serial number : (hex) 557B90A0 Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DH6DAB_04_01_2021_17_06_06.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: nvcfg (0005FC40, 00010000) 32 MB P11: nvdata (0006FC40, 00020000) 64 MB P12: metadata (0008FC40, 00010000) 32 MB P13: protect1 (0009FC40, 00004000) 8 MB P14: protect2 (000A3C40, 000043C0) 8.469 MB P15: seccfg (000A8000, 00004000) 8 MB P16: persist (000AC000, 00018000) 48 MB P17: sec1 (000C4000, 00001000) 2048 KB P18: proinfo (000C5000, 00001800) 3072 KB P19: md1img (000C6800, 00032000) 100 MB P20: spmfw (000F8800, 00000800) 1024 KB P21: scp1 (000F9000, 00000800) 1024 KB P22: scp2 (000F9800, 00000800) 1024 KB P23: sspm_1 (000FA000, 00000800) 1024 KB P24: sspm_2 (000FA800, 00000800) 1024 KB P25: gz1 (000FB000, 00008000) 16 MB P26: gz2 (00103000, 00008000) 16 MB P27: nvram (0010B000, 00020000) 64 MB P28: lk (0012B000, 00002800) 5 MB P29: lk2 (0012D800, 00002800) 5 MB P30: boot (00130000, 00010000) 32 MB P31: logo (00140000, 00008000) 16 MB P32: dtbo (00148000, 00008000) 16 MB P33: tee1 (00150000, 00002800) 5 MB P34: tee2 (00152800, 00005800) 11 MB P35: odm (00158000, 00080000) 256 MB P36: vendor (001D8000, 00230000) 1120 MB P37: system (00408000, 00C00000) 6 GB P38: vbmeta (01008000, 00004000) 8 MB P39: cache (0100C000, 000D8000) 432 MB P40: userdata (010E4000, 0637A7DF) 49.74 GB P41: otp (0745E7DF, 00015800) 43 MB P42: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_nvdata_0x6fc40_0x20000_04_01_2021_17_06_06.bin file... Reading. Please wait... Done. Elapsed time 00:00:26 SW: 2.1.8; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4227072 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20201127.205442 release-keys --------------------------------------------------------------- Reset operation finished |
01-05-2021, 10:10 | #4 (permalink) |
Member: 78657 Status: Offline Thanks Meter: 71 | i dont save a backup first time connect operation Code: Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414202557B90A04731 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Product revision : 0.2 Product serial number : (hex) 557B90A0 Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DH6DAB_05_01_2021_09_47_06.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: nvcfg (0005FC40, 00010000) 32 MB P11: nvdata (0006FC40, 00020000) 64 MB P12: metadata (0008FC40, 00010000) 32 MB P13: protect1 (0009FC40, 00004000) 8 MB P14: protect2 (000A3C40, 000043C0) 8.469 MB P15: seccfg (000A8000, 00004000) 8 MB P16: persist (000AC000, 00018000) 48 MB P17: sec1 (000C4000, 00001000) 2048 KB P18: proinfo (000C5000, 00001800) 3072 KB P19: md1img (000C6800, 00032000) 100 MB P20: spmfw (000F8800, 00000800) 1024 KB P21: scp1 (000F9000, 00000800) 1024 KB P22: scp2 (000F9800, 00000800) 1024 KB P23: sspm_1 (000FA000, 00000800) 1024 KB P24: sspm_2 (000FA800, 00000800) 1024 KB P25: gz1 (000FB000, 00008000) 16 MB P26: gz2 (00103000, 00008000) 16 MB P27: nvram (0010B000, 00020000) 64 MB P28: lk (0012B000, 00002800) 5 MB P29: lk2 (0012D800, 00002800) 5 MB P30: boot (00130000, 00010000) 32 MB P31: logo (00140000, 00008000) 16 MB P32: dtbo (00148000, 00008000) 16 MB P33: tee1 (00150000, 00002800) 5 MB P34: tee2 (00152800, 00005800) 11 MB P35: odm (00158000, 00080000) 256 MB P36: vendor (001D8000, 00230000) 1120 MB P37: system (00408000, 00C00000) 6 GB P38: vbmeta (01008000, 00004000) 8 MB P39: cache (0100C000, 000D8000) 432 MB P40: userdata (010E4000, 0637A7DF) 49.74 GB P41: otp (0745E7DF, 00015800) 43 MB P42: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_nvdata_0x6fc40_0x20000_05_01_2021_09_47_06.bin file... Reading. Please wait... Done. Elapsed time 00:00:27 SW: 2.1.8; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4227072 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20201127.205442 release-keys |
01-05-2021, 11:37 | #5 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Russia,Yekaterinburg
Member: 1363017 Status: Offline Thanks Meter: 44 | Medusa Box Maybe you should not hide in the log what exactly does the software with the device when reset OPPO hiding behind the inscription Reset operation finished ? In fact, I will assume that the software writes factory vipe commands to the misc and para sections, but ... Look at the markup P01: boot_para (00000040, 00000800) 1024 KB P03: para (00010840, 00000400) 512 KB Are you sure that the software writes only in para, and did not accidentally write the vape command to the boot_para section? If it was written in the log with which section and what is being done. it would be easier to catch the error. Last edited by andrei_d1978; 01-05-2021 at 11:47. |
The Following 2 Users Say Thank You to andrei_d1978 For This Useful Post: |
01-05-2021, 12:47 | #6 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | We'll check what we can do with log, but every time when You're trying to perform Reset operation for this device, You and other users were warned, that we highly recommend to do backup first! If users are keep ignoring such messages and warning, there are not much what we can do Besides, that's not the first time when we were warned and explain this |
The Following User Says Thank You to Medusa Box For This Useful Post: |
01-05-2021, 14:17 | #7 (permalink) | |
Member: 78657 Status: Offline Thanks Meter: 71 | Quote:
i poste full log and operation that are do. 1 conncetion 2 read with error and the technicien cancel the operation with 33Mo mpt file 3 reset Code: Welcome to Medusa Pro Software version 2.1.8. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(LIVE_LOG OPPO A31) COREID_007050E1.TXT. Downloaded and installed file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A31_USB_MSM8916.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414202557B90A04731 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Product revision : 0.2 Product serial number : (hex) 557B90A0 Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DH6DAB_04_01_2021_17_00_03.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: nvcfg (0005FC40, 00010000) 32 MB P11: nvdata (0006FC40, 00020000) 64 MB P12: metadata (0008FC40, 00010000) 32 MB P13: protect1 (0009FC40, 00004000) 8 MB P14: protect2 (000A3C40, 000043C0) 8.469 MB P15: seccfg (000A8000, 00004000) 8 MB P16: persist (000AC000, 00018000) 48 MB P17: sec1 (000C4000, 00001000) 2048 KB P18: proinfo (000C5000, 00001800) 3072 KB P19: md1img (000C6800, 00032000) 100 MB P20: spmfw (000F8800, 00000800) 1024 KB P21: scp1 (000F9000, 00000800) 1024 KB P22: scp2 (000F9800, 00000800) 1024 KB P23: sspm_1 (000FA000, 00000800) 1024 KB P24: sspm_2 (000FA800, 00000800) 1024 KB P25: gz1 (000FB000, 00008000) 16 MB P26: gz2 (00103000, 00008000) 16 MB P27: nvram (0010B000, 00020000) 64 MB P28: lk (0012B000, 00002800) 5 MB P29: lk2 (0012D800, 00002800) 5 MB P30: boot (00130000, 00010000) 32 MB P31: logo (00140000, 00008000) 16 MB P32: dtbo (00148000, 00008000) 16 MB P33: tee1 (00150000, 00002800) 5 MB P34: tee2 (00152800, 00005800) 11 MB P35: odm (00158000, 00080000) 256 MB P36: vendor (001D8000, 00230000) 1120 MB P37: system (00408000, 00C00000) 6 GB P38: vbmeta (01008000, 00004000) 8 MB P39: cache (0100C000, 000D8000) 432 MB P40: userdata (010E4000, 0637A7DF) 49.74 GB P41: otp (0745E7DF, 00015800) 43 MB P42: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_nvdata_0x6fc40_0x20000_04_01_2021_17_00_03.bin file... Reading. Please wait... Done. Elapsed time 00:00:26 SW: 2.1.8; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4227072 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20201127.205442 release-keys --------------------------------------------------------------- Save to C:/Program Files (x86)/Medusa Pro Software/oppo a31 2020/Samsung eMMC DH6DAB_04_01_2021__17_01_37.mpt file... Reading partition GPT... ERROR[011]: Read error. At sector 0 Attempting to read... Done. Reading partition boot_para... Done. Reading partition recovery... Done. Reading partition para... Done. Reading partition opporeserve1... Done. Reading partition opporeserve2... Done. Reading partition opporeserve3... ERROR[011]: Read error. At sector 250107 Attempting to read... Done. Reading partition oppo_custom... Done. Reading partition expdb... Done. Reading partition frp... Done. Reading partition nvcfg... Done. Reading partition nvdata... ERROR[011]: Read error. At sector 502281 Attempting to read... Done. Reading is canceled. SW: 2.1.8; FW: 1.24. ERROR[012]: Write error. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414202557B90A04731 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Product revision : 0.2 Product serial number : (hex) 557B90A0 Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DH6DAB_04_01_2021_17_06_06.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: nvcfg (0005FC40, 00010000) 32 MB P11: nvdata (0006FC40, 00020000) 64 MB P12: metadata (0008FC40, 00010000) 32 MB P13: protect1 (0009FC40, 00004000) 8 MB P14: protect2 (000A3C40, 000043C0) 8.469 MB P15: seccfg (000A8000, 00004000) 8 MB P16: persist (000AC000, 00018000) 48 MB P17: sec1 (000C4000, 00001000) 2048 KB P18: proinfo (000C5000, 00001800) 3072 KB P19: md1img (000C6800, 00032000) 100 MB P20: spmfw (000F8800, 00000800) 1024 KB P21: scp1 (000F9000, 00000800) 1024 KB P22: scp2 (000F9800, 00000800) 1024 KB P23: sspm_1 (000FA000, 00000800) 1024 KB P24: sspm_2 (000FA800, 00000800) 1024 KB P25: gz1 (000FB000, 00008000) 16 MB P26: gz2 (00103000, 00008000) 16 MB P27: nvram (0010B000, 00020000) 64 MB P28: lk (0012B000, 00002800) 5 MB P29: lk2 (0012D800, 00002800) 5 MB P30: boot (00130000, 00010000) 32 MB P31: logo (00140000, 00008000) 16 MB P32: dtbo (00148000, 00008000) 16 MB P33: tee1 (00150000, 00002800) 5 MB P34: tee2 (00152800, 00005800) 11 MB P35: odm (00158000, 00080000) 256 MB P36: vendor (001D8000, 00230000) 1120 MB P37: system (00408000, 00C00000) 6 GB P38: vbmeta (01008000, 00004000) 8 MB P39: cache (0100C000, 000D8000) 432 MB P40: userdata (010E4000, 0637A7DF) 49.74 GB P41: otp (0745E7DF, 00015800) 43 MB P42: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_nvdata_0x6fc40_0x20000_04_01_2021_17_06_06.bin file... Reading. Please wait... Done. Elapsed time 00:00:26 SW: 2.1.8; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4227072 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20201127.205442 release-keys --------------------------------------------------------------- Reset operation finished Disconnected. | |
01-05-2021, 16:48 | #8 (permalink) |
Member: 1363017 Status: Offline Thanks Meter: 44 | bilm25 and the device is now in BROM(mtk usb port)? Can you merge Boot1 and Boot2 and attach it here? and also make a high-quality photo of the place near EMMC where you soldered, maybe where the snot from the tin remained? |
The Following User Says Thank You to andrei_d1978 For This Useful Post: |
01-05-2021, 17:54 | #9 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | Quote:
emmc power from usb cable or vcc;vccq from box ? | |
01-06-2021, 11:03 | #10 (permalink) | |
the mainboard is fine and clean. | |
01-06-2021, 18:21 | #14 (permalink) |
Member: 1363017 Status: Offline Thanks Meter: 44 | Medusa Box Would you like to improve Parse MTK preloader 1. Please add parsing boot 1. Otherwise, at the present time, you have to use another software to find out which microcircuits are indicated in the preloader prescribed in boot 1 2.And can you make the Kingston flash drive parser call Kingston? eMMC Vendor ID: 70 (Pretec eMMC) eMMC Model ID: 0001 eMMC Name: V10008 eMMC CID: 700100563130303038 |
01-08-2021, 09:21 | #15 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. We will check everything from out description and try to add it in future updates Besides, please write here full name for Kingston, that we can add it Last edited by Medusa Box; 01-08-2021 at 09:27. |
