12-24-2020, 16:55 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 564300 Status: Offline Thanks Meter: 10 | oppo a31 cph2015 dead after remove frp with medusa pro [Solved] Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414202819D90C647AB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Product revision : 0.2 Product serial number : (hex) 819D90C6 Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/DH6DAB_24_12_2020_16_16_19.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: nvcfg (0005FC40, 00010000) 32 MB P11: nvdata (0006FC40, 00020000) 64 MB P12: metadata (0008FC40, 00010000) 32 MB P13: protect1 (0009FC40, 00004000) 8 MB P14: protect2 (000A3C40, 000043C0) 8.469 MB P15: seccfg (000A8000, 00004000) 8 MB P16: persist (000AC000, 00018000) 48 MB P17: sec1 (000C4000, 00001000) 2048 KB P18: proinfo (000C5000, 00001800) 3072 KB P19: md1img (000C6800, 00032000) 100 MB P20: spmfw (000F8800, 00000800) 1024 KB P21: scp1 (000F9000, 00000800) 1024 KB P22: scp2 (000F9800, 00000800) 1024 KB P23: sspm_1 (000FA000, 00000800) 1024 KB P24: sspm_2 (000FA800, 00000800) 1024 KB P25: gz1 (000FB000, 00008000) 16 MB P26: gz2 (00103000, 00008000) 16 MB P27: nvram (0010B000, 00020000) 64 MB P28: lk (0012B000, 00002800) 5 MB P29: lk2 (0012D800, 00002800) 5 MB P30: boot (00130000, 00010000) 32 MB P31: logo (00140000, 00008000) 16 MB P32: dtbo (00148000, 00008000) 16 MB P33: tee1 (00150000, 00002800) 5 MB P34: tee2 (00152800, 00005800) 11 MB P35: odm (00158000, 00080000) 256 MB P36: vendor (001D8000, 00230000) 1120 MB P37: system (00408000, 00C00000) 6 GB P38: vbmeta (01008000, 00004000) 8 MB P39: cache (0100C000, 000D8000) 432 MB P40: userdata (010E4000, 0637A7DF) 49.74 GB P41: otp (0745E7DF, 00015800) 43 MB P42: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files/Medusa Pro Software/Backups/DH6DAB_nvdata_0x6fc40_0x20000_24_12_2020_16_16_19. bin file... Reading. Please wait... Done. Elapsed time 00:00:26 SW: 2.1.4; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4227072 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20200526.150414 release-keys ---------------------------------------------------------------Partition table has been found on device. Partition table has been found on device. Partition table has been found on device. Partition table has been found on device. Partition table has been found on device. Backuping FRP data... Opening C:/Program Files/Medusa Pro Software/Backups/FRP_0x5f440_0x800_24_12_2020_16_22_26.bin file... Reading. Please wait... ERROR[011]: Read error. Attempting to read... Done. Elapsed time 00:00:00 SW: 2.1.4; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.1.4; FW: 1.24. Partition table has been found on device. Partition table has been found on device. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414202819D90C647AB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Product revision : 0.2 Product serial number : (hex) 819D90C6 Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/DH6DAB_24_12_2020_16_23_07.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: nvcfg (0005FC40, 00010000) 32 MB P11: nvdata (0006FC40, 00020000) 64 MB P12: metadata (0008FC40, 00010000) 32 MB P13: protect1 (0009FC40, 00004000) 8 MB P14: protect2 (000A3C40, 000043C0) 8.469 MB P15: seccfg (000A8000, 00004000) 8 MB P16: persist (000AC000, 00018000) 48 MB P17: sec1 (000C4000, 00001000) 2048 KB P18: proinfo (000C5000, 00001800) 3072 KB P19: md1img (000C6800, 00032000) 100 MB P20: spmfw (000F8800, 00000800) 1024 KB P21: scp1 (000F9000, 00000800) 1024 KB P22: scp2 (000F9800, 00000800) 1024 KB P23: sspm_1 (000FA000, 00000800) 1024 KB P24: sspm_2 (000FA800, 00000800) 1024 KB P25: gz1 (000FB000, 00008000) 16 MB P26: gz2 (00103000, 00008000) 16 MB P27: nvram (0010B000, 00020000) 64 MB P28: lk (0012B000, 00002800) 5 MB P29: lk2 (0012D800, 00002800) 5 MB P30: boot (00130000, 00010000) 32 MB P31: logo (00140000, 00008000) 16 MB P32: dtbo (00148000, 00008000) 16 MB P33: tee1 (00150000, 00002800) 5 MB P34: tee2 (00152800, 00005800) 11 MB P35: odm (00158000, 00080000) 256 MB P36: vendor (001D8000, 00230000) 1120 MB P37: system (00408000, 00C00000) 6 GB P38: vbmeta (01008000, 00004000) 8 MB P39: cache (0100C000, 000D8000) 432 MB P40: userdata (010E4000, 0637A7DF) 49.74 GB P41: otp (0745E7DF, 00015800) 43 MB P42: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files/Medusa Pro Software/Backups/DH6DAB_nvdata_0x6fc40_0x20000_24_12_2020_16_23_07. bin file... Reading. Please wait... ERROR[011]: Read error. Attempting to read... Done. Elapsed time 00:00:38 SW: 2.1.4; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4227072 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20200526.150414 release-keys ---------------------------------------------------------------Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414202819D90C647AB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Product revision : 0.2 Product serial number : (hex) 819D90C6 Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/DH6DAB_24_12_2020_16_26_14.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: nvcfg (0005FC40, 00010000) 32 MB P11: nvdata (0006FC40, 00020000) 64 MB P12: metadata (0008FC40, 00010000) 32 MB P13: protect1 (0009FC40, 00004000) 8 MB P14: protect2 (000A3C40, 000043C0) 8.469 MB P15: seccfg (000A8000, 00004000) 8 MB P16: persist (000AC000, 00018000) 48 MB P17: sec1 (000C4000, 00001000) 2048 KB P18: proinfo (000C5000, 00001800) 3072 KB P19: md1img (000C6800, 00032000) 100 MB P20: spmfw (000F8800, 00000800) 1024 KB P21: scp1 (000F9000, 00000800) 1024 KB P22: scp2 (000F9800, 00000800) 1024 KB P23: sspm_1 (000FA000, 00000800) 1024 KB P24: sspm_2 (000FA800, 00000800) 1024 KB P25: gz1 (000FB000, 00008000) 16 MB P26: gz2 (00103000, 00008000) 16 MB P27: nvram (0010B000, 00020000) 64 MB P28: lk (0012B000, 00002800) 5 MB P29: lk2 (0012D800, 00002800) 5 MB P30: boot (00130000, 00010000) 32 MB P31: logo (00140000, 00008000) 16 MB P32: dtbo (00148000, 00008000) 16 MB P33: tee1 (00150000, 00002800) 5 MB P34: tee2 (00152800, 00005800) 11 MB P35: odm (00158000, 00080000) 256 MB P36: vendor (001D8000, 00230000) 1120 MB P37: system (00408000, 00C00000) 6 GB P38: vbmeta (01008000, 00004000) 8 MB P39: cache (0100C000, 000D8000) 432 MB P40: userdata (010E4000, 0637A7DF) 49.74 GB P41: otp (0745E7DF, 00015800) 43 MB P42: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files/Medusa Pro Software/Backups/DH6DAB_nvdata_0x6fc40_0x20000_24_12_2020_16_26_14. bin file... Reading. Please wait... Done. Elapsed time 00:00:27 SW: 2.1.4; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4227072 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20200526.150414 release-keys |
12-24-2020, 18:37 | #2 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Russia,Yekaterinburg
Member: 1363017 Status: Offline Thanks Meter: 44 | was Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 became Partition config : (0x78) 01111000 Boot partition enable : User area Return the mtk config to the proc and there will be happiness |
