Oppo A5 2020 CPH1931 Pattern FRP Unlock Without Losing Data Done By Medusa PRO Oppo A5 2020 CPH1931 Pattern FRP Unlock
Without Losing Data Done .::By::. .::: Medusa PRO :::. Code:
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 2.2V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC hC8aP
Page size : 512 B
Block size : 512 B
Block count : 122142720
Size : 58.24 GB (59640.00 MB)
CID Info
CID : 90014A68433861503E03428252848603
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : hC8aP
Product revision : 0.3
Product serial number : (hex) 42825284
Manufacturing date : 08/2019
CSD Info
CSD : D02700328F5903FFFFFFFFEF8E400043
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x38) 00111000
Boot partition enable : User area
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 30531584 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : 8f800000 bytes
Device sector size : 512 bytes
Partition offset : 5243136
Number of sectors : 13099008
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_23_05_2020_16_44_24.bin.
Connect successful.
SW: 2.0.9; FW: 1.24.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.2V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Ok
Build ID : PKQ1.190714.001
Release ID : 9
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description : trinket-user 9 PKQ1.190714.001 eng.root.20200412.184857 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_23_05_2020_16_44_46.bin.
Connect successful.
P00: GPT (00000000, 00000028) 20 KB
P01: oppodycnvbk (00000028, 00005000) 10 MB
P02: oppostanvbk (00005028, 00005000) 10 MB
P03: modemst1 (0000A028, 00001000) 2048 KB
P04: modemst2 (0000B028, 00001000) 2048 KB
P05: opporeserve1 (0000C028, 00004000) 8 MB
P06: opporeserve2 (00010028, 00020000) 64 MB
P07: opporeserve3 (00030028, 00020000) 64 MB
P08: oppo_sec (00050028, 00005000) 10 MB
P09: xbl (00060000, 00001C00) 3584 KB
P10: xblbak (00061C00, 00001C00) 3584 KB
P11: xbl_config (00080000, 00000100) 128 KB
P12: xbl_configbak (00080100, 00000100) 128 KB
P13: tz (000A0000, 00002000) 4 MB
P14: tzbak (000C0000, 00002000) 4 MB
P15: rpm (000E0000, 00000400) 512 KB
P16: rpmbak (00100000, 00000400) 512 KB
P17: hyp (00120000, 00004000) 8 MB
P18: hypbak (00140000, 00004000) 8 MB
P19: boot (00144000, 00030000) 96 MB
P20: bootbak (00174000, 00030000) 96 MB
P21: cache (001A4000, 00080000) 256 MB
P22: keymaster (00240000, 00000400) 512 KB
P23: keymasterbak (00240400, 00000400) 512 KB
P24: cmnlib (00240800, 00000400) 512 KB
P25: cmnlib64 (00240C00, 00000400) 512 KB
P26: cmnlibbak (00241000, 00000400) 512 KB
P27: cmnlib64bak (00241400, 00000400) 512 KB
P28: mdtpsecapp (00241800, 00002000) 4 MB
P29: mdtpsecappbak (00243800, 00002000) 4 MB
P30: mdtp (00245800, 00010000) 32 MB
P31: mdtpbak (00255800, 00010000) 32 MB
P32: modem (00265800, 00080000) 256 MB
P33: dsp (002E5800, 00020000) 64 MB
P34: dspbak (00305800, 00020000) 64 MB
P35: abl (00325800, 00000800) 1024 KB
P36: ablbak (00326000, 00000800) 1024 KB
P37: ddr (00326800, 00000800) 1024 KB
P38: bluetooth (00327000, 00000800) 1024 KB
P39: bluetoothbak (00327800, 00000800) 1024 KB
P40: ssd (00340000, 00000010) 8 KB
P41: dtbo (00340010, 0000C000) 24 MB
P42: dtbobak (0034C010, 0000C000) 24 MB
P43: recovery (00360000, 00020000) 64 MB
P44: recoverybak (00380000, 00020000) 64 MB
P45: imagefv (003A0000, 00001000) 2048 KB
P46: imagefvbak (003A1000, 00001000) 2048 KB
P47: uefisecapp (003A2000, 00001000) 2048 KB
P48: uefisecappbak (003A3000, 00001000) 2048 KB
P49: persist (003A4000, 00010000) 32 MB
P50: metadata (003B4000, 00008000) 16 MB
P51: misc (003BC000, 00000800) 1024 KB
P52: keystore (003BC800, 00000400) 512 KB
P53: devcfg (003BCC00, 00000100) 128 KB
P54: devcfgbak (003BCD00, 00000100) 128 KB
P55: qupfw (003BCE00, 000000A0) 80 KB
P56: qupfwbak (003BCEA0, 000000A0) 80 KB
P57: frp (003BCF40, 00000400) 512 KB
P58: rawdump (003BD340, 00040000) 128 MB
P59: devinfo (00400000, 00000008) 4 KB
P60: dip (00400008, 00000800) 1024 KB
P61: apdp (00420000, 00000200) 256 KB
P62: spunvm (00420200, 00004000) 8 MB
P63: splash (00424200, 00010520) 32.64 MB
P64: limits (00440000, 00000008) 4 KB
P65: toolsfv (00440008, 00000800) 1024 KB
P66: logfs (00460000, 00004000) 8 MB
P67: cateloader (00464000, 00001000) 2048 KB
P68: logdump (00465000, 00020000) 64 MB
P69: vbmeta (004A0000, 00000080) 64 KB
P70: vbmetabak (004A0080, 00000080) 64 KB
P71: storsec (004A0100, 00000100) 128 KB
P72: multiimgoem (004A0200, 00000040) 32 KB
P73: multiimgqti (004A0240, 00000040) 32 KB
P74: secdata (004A0280, 00000032) 25 KB
P75: catefv (004A02B8, 00000400) 512 KB
P76: catecontentfv (004A06B8, 00000800) 1024 KB
P77: uefivarstore (004A0EB8, 00000400) 512 KB
P78: DRIVER (004C0000, 00010000) 32 MB
P79: fsg (004E0000, 00001000) 2048 KB
P80: fsc (00500000, 00000100) 128 KB
P81: system (00500100, 00C7E000) 6.246 GB
P82: vendor (0117E100, 00322000) 1604 MB
P83: odm (014A0100, 00080000) 256 MB
P84: userdata (01520100, 05F5BEDF) 47.68 GB
Backuping modemst1 partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_modemst1_0xa028_0x1000_23_05_2020_16_44_46.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:00
Backuping modemst2 partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_modemst2_0xb028_0x1000_23_05_2020_16_44_46.bin file...
Backuping fsg partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_fsg_0x4e0000_0x1000_23_05_2020_16_44_46.bin file...
Reset operation finished
Backuping FRP data...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x17a400_0x40_23_05_2020_16_44_54.bin file...
Removing FRP. Please wait... Done.
SW: 2.0.9; FW: 1.24. |
