07-29-2020, 09:31 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Oppo R15 Pro [PAAT00_11_C.68] Screen Lock || FRP Lock Removed || Dump File[Available] Oppo R15 Pro [PAAT00_11_C.68] How to do it properly:- OPPO R15 Pro eMMC ISP PIN OUT Oppo R15 Pro Screen Lock & FRP Lock Removed & How to Read Dump Code: Welcome to Medusa Pro Software version 2.1.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 8 bits Bus speed : 20 MHz Connecting... Device : Samsung eMMC 3V6CMB Page size : 512 B Block size : 512 B Block count : 244277248 Size : 116.48 GB (119276.00 MB) --------------------------------------------------------------- CID Info CID : 150100335636434D420225D3C84A2569 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 3V6CMB Product revision : 0.2 Product serial number : (hex) 25D3C84A Manufacturing date : 02/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40706048 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/3V6CMB_25_07_2020_21_53_09.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00001000) 2048 KB P04: modemst2 (0000B028, 00001000) 2048 KB P05: persist (0000C028, 00010000) 32 MB P06: opporeserve1 (0001C028, 00004000) 8 MB P07: opporeserve2 (00020028, 00020000) 64 MB P08: carrier (00040028, 00004000) 8 MB P09: xbl (00048000, 00001C00) 3584 KB P10: xblbak (00049C00, 00001C00) 3584 KB P11: tz (0004B800, 00002000) 4 MB P12: tzbak (0004D800, 00002000) 4 MB P13: rpm (0004F800, 00000400) 512 KB P14: rpmbak (0004FC00, 00000400) 512 KB P15: hyp (00050000, 00000400) 512 KB P16: hypbak (00050400, 00000400) 512 KB P17: pmic (00050800, 00000400) 512 KB P18: pmicbak (00050C00, 00000400) 512 KB P19: fsg (00051000, 00001000) 2048 KB P20: boot (00054000, 00020000) 64 MB P21: bootbak (00074000, 00020000) 64 MB P22: recovery (00094000, 00020000) 64 MB P23: keymaster (000B4000, 00000800) 1024 KB P24: keymasterbak (000B4800, 00000800) 1024 KB P25: cmnlib (000B5000, 00000800) 1024 KB P26: cmnlib64 (000B5800, 00000800) 1024 KB P27: cmnlibbak (000B6000, 00000800) 1024 KB P28: cmnlib64bak (000B6800, 00000800) 1024 KB P29: mdtpsecapp (000B7000, 00002000) 4 MB P30: mdtpsecappbak (000B9000, 00002000) 4 MB P31: mdtp (000BB000, 00010000) 32 MB P32: mdtpbak (000CB000, 00010000) 32 MB P33: dsp (000DB000, 00008000) 16 MB P34: dspbak (000E3000, 00008000) 16 MB P35: abl (000EB000, 00000800) 1024 KB P36: ablbak (000EB800, 00000800) 1024 KB P37: dip (000EC000, 00000800) 1024 KB P38: devinfo (000EC800, 00000008) 4 KB P39: apdp (000EC808, 00000200) 256 KB P40: msadp (000ECA08, 00000200) 256 KB P41: dpo (000ECC08, 00000002) 1024 b P42: splash (000ECC10, 00010520) 32.64 MB P43: limits (000FD130, 00000008) 4 KB P44: toolsfv (000FD138, 00000800) 1024 KB P45: logfs (00100000, 00004000) 8 MB P46: ddr (00104000, 00000800) 1024 KB P47: sec (00104800, 00000020) 16 KB P48: bluetooth (00104820, 00000800) 1024 KB P49: bluetoothbak (00105020, 00000800) 1024 KB P50: fsc (00108000, 00000002) 1024 b P51: ssd (00108008, 00000010) 8 KB P52: misc (00108018, 00000800) 1024 KB P53: keystore (00108818, 00000400) 512 KB P54: devcfg (00108C18, 00000800) 1024 KB P55: devcfgbak (00109418, 00000800) 1024 KB P56: frp (00109C18, 00000400) 512 KB P57: logdump (0010A018, 00020000) 64 MB P58: sti (0012A018, 00001000) 2048 KB P59: LOGO (0012B018, 00008000) 16 MB P60: DRIVER (00133018, 00010000) 32 MB P61: vbmeta (00144000, 00000080) 64 KB P62: vbmetabak (00144080, 00000080) 64 KB P63: modem (00144100, 00040000) 128 MB P64: cache (00188000, 00080000) 256 MB P65: system (00208000, 00700000) 3584 MB P66: vendor (00908000, 00300000) 1536 MB P67: odm (00C08000, 00080000) 256 MB P68: storsec (00C88000, 00000100) 128 KB P69: userdata (00C8C000, 0DC69FDF) 110.2 GB Backuping modemst1 partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_modemst1_0xa028_0x1000_25_07_2020_21_53_09.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_modemst2_0xb028_0x1000_25_07_2020_21_53_09.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 1.24. Backuping fsg partition... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/3V6CMB_fsg_0x51000_0x1000_25_07_2020_21_53_09.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 1ec00000 bytes Device sector size : 512 bytes Partition offset : 2129920 Number of sectors : 7340032 Build ID : PKQ1.190414.001 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : sdm660_64-user 9 PKQ1.190414.001 eng.root.20200616.212930 release-keys ---------------------------------------------------------------Reset operation finished Backuping FRP data... Opening C:/Program Files/Octoplus Pro JTAG Software/Backups/FRP_0x109c18_0x400_25_07_2020_21_53_32.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.1.1; FW: 1.24. Download===> Oppo R15 PAAT00_11_C.68_Dump File Link 1 || Link 2 || Link 3 Oppo R15 Pro Read Full Dump Without User Data. Code: Partition table has been found on device. Partition table has been found on device. Save to C:/Program Files/Octoplus Pro JTAG Software/Oppo R15 QCM/Oppo R15 PKQ1.190414.001 Full Dump folder... Reading partition GPT... Done. Reading partition oppodycnvbk... Done. Reading partition oppostanvbk... Done. Reading partition modemst1... Done. Reading partition modemst2... Done. Reading partition persist... Done. Reading partition opporeserve1... Done. Reading partition opporeserve2... Done. Reading partition carrier... Done. Reading partition xbl... Done. Reading partition xblbak... Done. Reading partition tz... Done. Reading partition tzbak... Done. Reading partition rpm... Done. Reading partition rpmbak... Done. Reading partition hyp... Done. Reading partition hypbak... Done. Reading partition pmic... Done. Reading partition pmicbak... Done. Reading partition fsg... Done. Reading partition boot... Done. Reading partition bootbak... Done. Reading partition recovery... Done. Reading partition keymaster... Done. Reading partition keymasterbak... Done. Reading partition cmnlib... Done. Reading partition cmnlib64... Done. Reading partition cmnlibbak... Done. Reading partition cmnlib64bak... Done. Reading partition mdtpsecapp... Done. Reading partition mdtpsecappbak... Done. Reading partition mdtp... Done. Reading partition mdtpbak... Done. Reading partition dsp... Done. Reading partition dspbak... Done. Reading partition abl... Done. Reading partition ablbak... Done. Reading partition dip... Done. Reading partition devinfo... Done. Reading partition apdp... Done. Reading partition msadp... Done. Reading partition dpo... Done. Reading partition splash... Done. Reading partition limits... Done. Reading partition toolsfv... Done. Reading partition logfs... Done. Reading partition ddr... Done. Reading partition sec... Done. Reading partition bluetooth... Done. Reading partition bluetoothbak... Done. Reading partition fsc... Done. Reading partition ssd... Done. Reading partition misc... Done. Reading partition keystore... Done. Reading partition devcfg... Done. Reading partition devcfgbak... Done. Reading partition frp... Done. Reading partition logdump... Done. Reading partition sti... Done. Reading partition LOGO... Done. Reading partition DRIVER... Done. Reading partition vbmeta... Done. Reading partition vbmetabak... Done. Reading partition modem... Done. Reading partition cache... Done. Reading partition system... Done. Reading partition vendor... Done. Reading partition odm... Done. Reading partition storsec... Done. Reading is finished. SW: 2.1.1; FW: 1.24. Download ===> Oppo R15 PAAT00_11_C.68 PKQ1.190414.001 Full Dump Link 1 || Link 2 || Link 3
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 03-30-2021 at 03:42. Reason: Updated..... |
The Following 7 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
