05-28-2020, 15:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Oppo A37f Pattern FRP Unlock Without Losing Data Done By Medusa PRO Oppo A37f Pattern FRP Unlock Without Losing Data Done .::By::. .::: Medusa PRO :::. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Micron eMMC Q2J96R Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 13014E51324A3936521006E933177459 Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : Q2J96R Product revision : 1.0 Product serial number : (hex) 6E93317 Manufacturing date : 07/2017 --------------------------------------------------------------- CSD Info CSD : D07F01320F5913FFFFFFFFEF924000A3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q2J96R_28_05_2020_18_15_27.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 1.24. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 00020000) 64 MB P02: DDR (00040000, 00000040) 32 KB P03: fsg (00040040, 00000C00) 1536 KB P04: sec (00040C40, 00000020) 16 KB P05: fsc (00060000, 00000002) 1024 b P06: ssd (00060002, 00000010) 8 KB P07: sbl1 (00060012, 00000400) 512 KB P08: sbl1bak (00060412, 00000400) 512 KB P09: aboot (00080000, 00000800) 1024 KB P10: abootbak (00080800, 00000800) 1024 KB P11: rpm (000A0000, 00000400) 512 KB P12: rpmbak (000A0400, 00000400) 512 KB P13: tz (000A0800, 00000400) 512 KB P14: tzbak (000A0C00, 00000400) 512 KB P15: hyp (000A1000, 00000400) 512 KB P16: hypbak (000A1400, 00000400) 512 KB P17: modemst1 (000A1800, 00000C00) 1536 KB P18: modemst2 (000A2400, 00000C00) 1536 KB P19: oppodycnvbk (000A3000, 00005000) 10 MB P20: oppostanvbk (000A8000, 00005000) 10 MB P21: LOGO (000AD000, 00008000) 16 MB P22: boot (000C0000, 00010000) 32 MB P23: recovery (000D0000, 00010000) 32 MB P24: system (000E0000, 00580000) 2816 MB P25: devinfo (00660000, 00000800) 1024 KB P26: cache (00680000, 00040000) 128 MB P27: persist (006C0000, 00010000) 32 MB P28: misc (006D0000, 00000800) 1024 KB P29: keystore (006D0800, 00000400) 512 KB P30: config (006D0C00, 00000040) 32 KB P31: oem (006D0C40, 00020000) 64 MB P32: DRIVER (006F0C40, 00010000) 32 MB P33: reserve1 (00700C40, 00001000) 2048 KB P34: reserve2 (00701C40, 00008000) 16 MB P35: reserve3 (00709C40, 00001000) 2048 KB P36: reserve4 (0070AC40, 00008000) 16 MB P37: reserve_exp1 (00712C40, 00001000) 2048 KB P38: userdata (00713C40, 0164639F) 11.14 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q2J96R_fsg_0x40040_0xc00_28_05_2020_18_15_27.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q2J96R_modemst1_0xa1800_0xc00_28_05_2020_18_15_27.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q2J96R_modemst2_0xa2400_0xc00_28_05_2020_18_15_27.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 917504 Number of sectors : 5767168 Device Manufacturer : OPPO Device Platform : msm8916 Build ID : LMY47V Display Build ID : A37fEX_11_190711 Release ID : 5.1.1 Device Model : A37f Device Name : A37f Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8916_64-user 5.1.1 LMY47V eng.root.20190711.032745 release-keys ---------------------------------------------------------------Reset operation finished Backuping FRP data... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x6d0c00_0x40_28_05_2020_18_15_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.0; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.1.0; FW: 1.24. |
The Following 2 Users Say Thank You to kabul For This Useful Post: |
