Oppo Realme 5 RMX1911 Pattern FRP Unlock Without Losing Data Done By Medusa PRO Oppo Realme 5 RMX1911 Pattern FRP Unlock
Without Losing Data Done .::By::. .::: Medusa PRO :::. Code:
Please disconnect battery and USB cable.
Model Settings
Interface eMMC
Voltage 2.2V
Bus Mode 1 bit
Bus speed Auto
Connecting...
ERROR[001] Can not connect. No target device present.
Model Settings
Interface eMMC
Voltage 2.8V
Bus Mode 1 bit
Bus speed Auto
Connecting...
Device Micron eMMC S0J9D8
Page size 512 B
Block size 512 B
Block count 122142720
Size 58.24 GB (59640.00 MB)
CID Info
CID 13014E53304A39443810075E727B95A7
Manufacturer ID 0X13
DeviceBGA BGA (Discrete embedded)
OEMApplication ID 0X4E
Product name S0J9D8
Product revision 1.0
Product serial number (hex) 75E727B
Manufacturing date 092018
CSD Info
CSD D05F01328F5913FFFFFFFFEF964000A9
CSD structure CSD version No. 1.2
SPEC version 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1 50 ms
TRAN speed 26 MHz
READ block length 512 Bytes
WP group enable YES
PERM_WRITE_PROTECT NO
TMP_WRITE_PROTECT NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size 512 Kbytes
Boot1 size 4096 Kbytes
Boot2 size 4096 Kbytes
RPMB size 4096 Kbytes
Partition config (0x38) 00111000
Boot partition enable User area
(Bus width = 1Bit)
Boot ACK No boot acknowledge sent (default)
Boot bus conditions (0x00) 00000000
Boot bus width x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode Use single data rate + backward compatible timings in boot operation (default)
RST_n function (0x01) RST_n signal is permanently enabled
Partitioning support Device supports partitioning features
Enhanced attribute Device can have enhanced technological features in partitions and user data area.
Max enhanced data size 20348928 Kbytes
Partitions attribute 0x0
Part setting completed 0x0
GP partition 1 size 0 b
GP partition 2 size 0 b
GP partition 3 size 0 b
GP partition 4 size 0 b
Enhanced area size (0x0) 0 b
Enhanced area start (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
DiskImage size 8f800000 bytes
Device sector size 512 bytes
Partition offset 2932736
Number of sectors 9989120
Build ID PKQ1.190616.001
Release ID 9
Architecture ABI arm64-v8a
Architecture ABI List arm64-v8a,armeabi-v7a,armeabi
Build Description trinket-user 9 PKQ1.190616.001 eng.root.20200324.011603 release-keys
Backup EXT_CSD saved to file CProgram Files (x86)Medusa Pro SoftwareEXT_CSD BackupsS0J9D8_26_05_2020_19_48_18.bin.
Connect successful.
SW 2.0.9; FW 1.24.
P00 GPT (00000000, 00000028) 20 KB
P01 oppodycnvbk (00000028, 00005000) 10 MB
P02 oppostanvbk (00005028, 00005000) 10 MB
P03 modemst1 (0000A028, 00001000) 2048 KB
P04 modemst2 (0000B028, 00001000) 2048 KB
P05 persist (0000C028, 00010000) 32 MB
P06 opporeserve1 (0001C028, 00004000) 8 MB
P07 opporeserve2 (00020028, 00020000) 64 MB
P08 opporeserve3 (00040028, 00020000) 64 MB
P09 xbl (00064000, 00001C00) 3584 KB
P10 xbl_config (00068000, 00000100) 128 KB
P11 tz (0006C000, 00002000) 4 MB
P12 rpm (0006E000, 00000400) 512 KB
P13 hyp (0006E400, 00000400) 512 KB
P14 fsg (0006E800, 00001000) 2048 KB
P15 fsc (00070000, 00000100) 128 KB
P16 boot (00070100, 00020000) 64 MB
P17 vm-kystore (00090100, 00000800) 1024 KB
P18 vm-data (00090900, 00005000) 10 MB
P19 vm-system (00095900, 00040000) 128 MB
P20 vm-linux (000D8000, 00010000) 32 MB
P21 keymaster (000E8000, 00000400) 512 KB
P22 cmnlib (000E8400, 00000400) 512 KB
P23 cmnlib64 (000E8800, 00000400) 512 KB
P24 mdtpsecapp (000E8C00, 00002000) 4 MB
P25 mdtp (000EAC00, 00010000) 32 MB
P26 dsp (000FAC00, 00010000) 32 MB
P27 abl (0010AC00, 00000800) 1024 KB
P28 ddr (0010B400, 00000800) 1024 KB
P29 bluetooth (0010BC00, 00000800) 1024 KB
P30 ssd (00110000, 00000010) 8 KB
P31 dtbo (00110010, 0000C000) 24 MB
P32 LOGO (0011C010, 00010000) 32 MB
P33 DRIVER (0012C010, 00010000) 32 MB
P34 imagefv (0013C010, 00001000) 2048 KB
P35 uefisecapp (0013D010, 00001000) 2048 KB
P36 metadata (0013E010, 00008000) 16 MB
P37 misc (00146010, 00000800) 1024 KB
P38 keystore (00146810, 00000400) 512 KB
P39 devcfg (00146C10, 00000100) 128 KB
P40 qupfw (00146D10, 00000080) 64 KB
P41 frp (00146D90, 00000400) 512 KB
P42 rawdump (00147190, 00040000) 128 MB
P43 devinfo (00188000, 00000008) 4 KB
P44 dip (00188008, 00000800) 1024 KB
P45 apdp (0018C000, 00000200) 256 KB
P46 spunvm (0018C200, 00004000) 8 MB
P47 splash (00190200, 00010520) 32.64 MB
P48 limits (001A4000, 00000008) 4 KB
P49 toolsfv (001A4008, 00000800) 1024 KB
P50 logfs (001A8000, 00004000) 8 MB
P51 cateloader (001AC000, 00001000) 2048 KB
P52 logdump (001AD000, 00020000) 64 MB
P53 multiimgoem (001D0000, 00000040) 32 KB
P54 multiimgqti (001D0040, 00000040) 32 KB
P55 secdata (001D0080, 00000032) 25 KB
P56 catefv (001D00B8, 00000400) 512 KB
P57 catecontentfv (001D04B8, 00000800) 1024 KB
P58 uefivarstore (001D0CB8, 00000400) 512 KB
P59 vbmeta (001D10B8, 00000080) 64 KB
P60 recovery (001D1138, 00020000) 64 MB
P61 modem (001F1138, 0005A000) 180 MB
P62 cache (0024C000, 00080000) 256 MB
P63 system (002CC000, 00986C00) 4.763 GB
P64 vendor (00C52C00, 002B4800) 1385 MB
P65 oppo_sec (00F07400, 00005000) 10 MB
P66 storsec (00F10000, 00000100) 128 KB
P67 userdata (00F14000, 06567FDF) 50.7 GB
Backuping modemst1 partition...
Opening CProgram Files (x86)Medusa Pro SoftwareBackupsS0J9D8_modemst1_0xa028_0x1000_26_05_2020_19_48_18.bin file...
Reading. Please wait... Done.
Elapsed time 000000
SW 2.0.9; FW 1.24.
Backuping modemst2 partition...
Opening CProgram Files (x86)Medusa Pro SoftwareBackupsS0J9D8_modemst2_0xb028_0x1000_26_05_2020_19_48_18.bin file...
Elapsed time 000000
SW 2.0.9; FW 1.24.
Backuping fsg partition...
Opening CProgram Files (x86)Medusa Pro SoftwareBackupsS0J9D8_fsg_0x6e800_0x1000_26_05_2020_19_48_18.bin file...
Elapsed time 000000
SW 2.0.9; FW 1.24.
Reset operation finished
Backuping FRP data...
Opening CProgram Files (x86)Medusa Pro SoftwareBackupsFRP_0x5f440_0x800_26_05_2020_19_48_30.bin file...
Elapsed time 000000
SW 2.0.9; FW 1.24.
Removing FRP. Please wait... Done.
SW 2.0.9; FW 1.24. |
