10-23-2019, 13:25 | #18 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | Quote:
Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_10_51_16.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Pinout configuration not detected Pinout configuration not detected Pinout configuration not detected Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_10_51_43.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Pinout configuration not detected Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 13 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_10_54_19.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_10_56_27.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_10_57_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Please select file. Please select file. Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... error! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_10_58_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. --------------------------------------------------------------- Selected scatter file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/MT6771_Android_scatter.txt. Scatter file type 2. Opened input file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/preloader_oppo6771_17331.bin No eMMC descriptions found. Writing. Please wait... Write data verification is enabled. Writing partition preloader... Switch error!!! ERROR[012]: Write error. At sector 0 Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_11_02_46.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. --------------------------------------------------------------- Selected scatter file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/MT6771_Android_scatter.txt. Scatter file type 2. Opened input file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/preloader_oppo6771_17331.bin No eMMC descriptions found. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_11_03_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. --------------------------------------------------------------- Selected scatter file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/MT6771_Android_scatter.txt. Scatter file type 2. Opened input file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/preloader_oppo6771_17331.bin No eMMC descriptions found. Writing. Please wait... Write data verification is enabled. Writing partition preloader... Switch error!!! ERROR[012]: Write error. At sector 0 Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_11_15_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Repairing from file "C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf". Write data verification is enabled. Writing para partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : F7_CPH1811 SRF : C:/Users/AnonDz/Desktop/OPPO reset srf/Oppo_F7_CPH1811_RESET_ISP.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 15 MHz Connecting... Device : Hynix eMMC HCG8a4 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484347386134A20A82346815FD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HCG8a4 Product revision : 10.2 Product serial number : (hex) A823468 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFEF8A400027 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HCG8a4_23_10_2019_11_15_46.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. --------------------------------------------------------------- Selected scatter file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/MT6771_Android_scatter.txt. Scatter file type 2. Opened input file: C:/Users/AnonDz/Documents/MEGAsync Downloads/F7_CPH1819_11_A.28_190216_ec586eef/preloader_oppo6771_17331.bin No eMMC descriptions found. Writing. Please wait... Cancelling operation. Please wait... | |
10-28-2019, 17:11 | #22 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Hello Everyone, I told again that Please make good connection then do Smart Repair By Medusa Pro... For OPPO/Realme use voltage 2.2v/Clock Speed 13-15Mhz or 2.8v/ clock Speed 13-20 Mhz... (Some Times Need to Connect Battery) Here 100% Worked that config for every OPPO/Realme…. See Here For Succesfull Results... |
10-29-2019, 08:45 | #23 (permalink) |
Freak Poster Join Date: May 2019 Location: Gujranwala
Member: 2909174 Status: Offline Sonork: 100.650600 Thanks Meter: 77 | please help me i just sold wires realme c2 rmx1941 after sold wires we decide flash online but when i remove wires mobile dead and show in device manger only mediatek port |
10-29-2019, 09:50 | #24 (permalink) | |
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Quote:
if any doubt then Just remove CLK resistor & make a Jumper on CLK line... After that just Power ON the SET | |
The Following User Says Thank You to Pijush Das For This Useful Post: |
11-01-2019, 20:48 | #28 (permalink) |
Member: 2909174 Status: Offline Sonork: 100.650600 Thanks Meter: 77 | Big thanks for your repying cmd lind is damaged now please give me solution please help me i am wait for your reply if i will try with online flash then mobile alive or still dead please please help me |
