03-28-2022, 12:43 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 38
Member: 599024 Status: Offline Thanks Meter: 18 | pin are conected but error 016 or error 009 [Answered] Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) isp pin out are ok i solder two many times all are ok i conect whith isp adapter & i tried whith direct pin conecteur always same error |
03-29-2022, 10:29 | #3 (permalink) |
Member: 599024 Status: Offline Thanks Meter: 18 | Started. Reader #0: Generic Usb Smart Card Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : 25 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : 25 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : 25 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : 25 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : 50 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Oppo Model : A3s SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/OPPO_A3S_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) |
