06-01-2022, 08:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | Please team help with this error [Answered] Get Measurements error. Reloading... I have killed 3 phones with this error log Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC RP64AB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100525036344142001EDDCEC539CF Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RP64AB Product revision : 0.0 Product serial number : (hex) 1EDDCEC5 Manufacturing date : 03/2022 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RP64AB_01_06_2022_10_07_02.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.4; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: efs (00002000, 00004000) 8 MB P02: sec_efs (00006000, 00004000) 8 MB P03: steady (0000A000, 00002000) 4 MB P04: nvram (0000C000, 00020000) 64 MB P05: spmfw (0002C000, 00000800) 1024 KB P06: scp1 (0002C800, 00000800) 1024 KB P07: sspm_1 (0002D000, 00000800) 1024 KB P08: tee1 (0002D800, 00001000) 2048 KB P09: tzar (0002E800, 00002000) 4 MB P10: gz1 (00030800, 00008000) 16 MB P11: lk (00038800, 00001000) 2048 KB P12: dtbo (00039800, 00004000) 8 MB P13: vbmeta (0003D800, 00000080) 64 KB P14: btd (0003D880, 00002780) 4.938 MB P15: protect1 (00040000, 00004000) 8 MB P16: protect2 (00044000, 00004000) 8 MB P17: seccfg (00048000, 00004000) 8 MB P18: bota (0004C000, 00016800) 45 MB P19: boot_para (00062800, 00000800) 1024 KB P20: para (00063000, 00000400) 512 KB P21: misc (00063400, 00000400) 512 KB P22: expdb (00063800, 0000A000) 20 MB P23: frp (0006D800, 00000800) 1024 KB P24: nvcfg (0006E000, 00010000) 32 MB P25: nvdata (0007E000, 00020000) 64 MB P26: metadata (0009E000, 00010000) 32 MB P27: keyrefuge (000AE000, 00008000) 16 MB P28: keydata (000B6000, 00008000) 16 MB P29: md_udc (000BE000, 0000B4D0) 22.6 MB P30: persistent (000C94D0, 00000400) 512 KB P31: proinfo (000C98D0, 00001800) 3072 KB P32: md1img (000CB0D0, 00032000) 100 MB P33: logo (000FD0D0, 00004000) 8 MB P34: param (001010D0, 00002000) 4 MB P35: up_param (001030D0, 00002000) 4 MB P36: persist (001050D0, 00018000) 48 MB P37: boot (0011D0D0, 00010000) 32 MB P38: recovery (0012D0D0, 00012800) 37 MB P39: vbmeta_system (0013F8D0, 00000080) 64 KB P40: vbmeta_vendor (0013F950, 00000080) 64 KB P41: efuse (0013F9D0, 00000400) 512 KB P42: rsv1 (0013FDD0, 00000230) 280 KB P43: sec1 (00140000, 00004000) 8 MB P44: super (00144000, 00B60000) 5.688 GB P45: prism (00CA4000, 00094000) 296 MB P46: optics (00D38000, 0000C000) 24 MB P47: cache (00D44000, 00064000) 200 MB P48: omr (00DA8000, 00019000) 50 MB P49: spu (00DC1000, 00019000) 50 MB P50: userdata (00DDA000, 066A0000) 51.31 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/RP64AB_efs_0x2000_0x4000_01_06_2022_10_07_02.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.4.4; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/RP64AB_nvdata_0x7e000_0x20000_01_06_2022_10_07_02.bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.4.4; FW: 2.00. RPMB: Counter of the successful data write requests = 171. Writing eMMC firmware from file: C:/Users/xxxxx/Desktop/MEDUSA_KMRP60014A_B614_RP64AB.bin...Done. Finalizing... Failed reconnect operation. Get Measurements error. Reloading... Disconnected. elected PIN - CONNECTOR. Please disconnect battery and USB cable. log Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) |
06-01-2022, 08:54 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Where did you take this firmware? Because unfortunately this chip currently not supported on Medusa Pro II Software. Before writing these firmware, the software warns you about this. |
06-01-2022, 11:43 | #3 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | the emmc firmware is very fine and working i made a backup from working device and have used it in more than 30 devices working very well but whenever tool gives that error no matter the chip you are working with is when phone goes dead |
06-01-2022, 11:50 | #4 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | supported chip Code: Welcome to Medusa Pro Software version 2.2.4.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414200581ED0DC3815 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Full name one from : KMDH6001DA-B422 Product revision : 0.0 Product serial number : (hex) 581ED0DC Manufacturing date : 03/2021 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DH6DAB_01_06_2022_13_45_34.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.6; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: efs (00002000, 0000A000) 20 MB P02: sec_efs (0000C000, 0000A000) 20 MB P03: reserved (00016000, 00002000) 4 MB P04: cpefs (00018000, 00004000) 8 MB P05: steady (0001C000, 00002000) 4 MB P06: param (0001E000, 00004000) 8 MB P07: bota (00022000, 00012000) 36 MB P08: ldfw (00034000, 00004000) 8 MB P09: tzsw (00038000, 00000C00) 1536 KB P10: tzar (00038C00, 00003400) 6.5 MB P11: keystorage (0003C000, 00000400) 512 KB P12: nad_refer (0003C400, 00000800) 1024 KB P13: up_param (0003CC00, 00004000) 8 MB P14: misc (00040C00, 00001000) 2048 KB P15: uh (00041C00, 00001000) 2048 KB P16: uhcfg (00042C00, 00002000) 4 MB P17: blcmd (00044C00, 00000400) 512 KB P18: boot (00045000, 00012000) 36 MB P19: recovery (00057000, 0001A800) 53 MB P20: dtb (00071800, 00004000) 8 MB P21: dtbo (00075800, 00004000) 8 MB P22: radio (00079800, 00019000) 50 MB P23: persistent (00092800, 00000400) 512 KB P24: vbmeta (00092C00, 00000400) 512 KB P25: vbmeta_samsung (00093000, 00000400) 512 KB P26: keyrefuge (00093400, 00008000) 16 MB P27: keydata (0009B400, 00008000) 16 MB P28: metadata (000A3400, 00010000) 32 MB P29: reserved2 (000B3400, 00000C00) 1536 KB P30: super (000B4000, 00A5A000) 5.176 GB P31: prism (00B0E000, 00190000) 800 MB P32: optics (00C9E000, 0000A000) 20 MB P33: cache (00CA8000, 00064000) 200 MB P34: omr (00D0C000, 0000A000) 20 MB P35: cp_debug (00D16000, 00002800) 5 MB P36: spu (00D18800, 00019000) 50 MB P37: userdata (00D31800, 06748000) 51.64 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_efs_0x2000_0xa000_01_06_2022_13_45_34.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.2.4.6; FW: 2.00. Backuping cpefs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_cpefs_0x18000_0x4000_01_06_2022_13_45_34.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.4.6; FW: 2.00. RPMB: Counter of the successful data write requests = 140777. EXT_CSD saved to file C:/Users/Robtech.ug/Desktop/SM-A217F_U7/EXT_CSD_01_06_2022_13_45_51.bin. Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC DH6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010044483644414200581ED0DC3815 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DH6DAB Full name one from : KMDH6001DA-B422 Product revision : 0.0 Product serial number : (hex) 581ED0DC Manufacturing date : 03/2021 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DH6DAB_01_06_2022_13_46_12.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.6; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: efs (00002000, 0000A000) 20 MB P02: sec_efs (0000C000, 0000A000) 20 MB P03: reserved (00016000, 00002000) 4 MB P04: cpefs (00018000, 00004000) 8 MB P05: steady (0001C000, 00002000) 4 MB P06: param (0001E000, 00004000) 8 MB P07: bota (00022000, 00012000) 36 MB P08: ldfw (00034000, 00004000) 8 MB P09: tzsw (00038000, 00000C00) 1536 KB P10: tzar (00038C00, 00003400) 6.5 MB P11: keystorage (0003C000, 00000400) 512 KB P12: nad_refer (0003C400, 00000800) 1024 KB P13: up_param (0003CC00, 00004000) 8 MB P14: misc (00040C00, 00001000) 2048 KB P15: uh (00041C00, 00001000) 2048 KB P16: uhcfg (00042C00, 00002000) 4 MB P17: blcmd (00044C00, 00000400) 512 KB P18: boot (00045000, 00012000) 36 MB P19: recovery (00057000, 0001A800) 53 MB P20: dtb (00071800, 00004000) 8 MB P21: dtbo (00075800, 00004000) 8 MB P22: radio (00079800, 00019000) 50 MB P23: persistent (00092800, 00000400) 512 KB P24: vbmeta (00092C00, 00000400) 512 KB P25: vbmeta_samsung (00093000, 00000400) 512 KB P26: keyrefuge (00093400, 00008000) 16 MB P27: keydata (0009B400, 00008000) 16 MB P28: metadata (000A3400, 00010000) 32 MB P29: reserved2 (000B3400, 00000C00) 1536 KB P30: super (000B4000, 00A5A000) 5.176 GB P31: prism (00B0E000, 00190000) 800 MB P32: optics (00C9E000, 0000A000) 20 MB P33: cache (00CA8000, 00064000) 200 MB P34: omr (00D0C000, 0000A000) 20 MB P35: cp_debug (00D16000, 00002800) 5 MB P36: spu (00D18800, 00019000) 50 MB P37: userdata (00D31800, 06748000) 51.64 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_efs_0x2000_0xa000_01_06_2022_13_46_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.2.4.6; FW: 2.00. Backuping cpefs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DH6DAB_cpefs_0x18000_0x4000_01_06_2022_13_46_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.4.6; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 737280 Number of sectors : 10854400 Build ID : RP1A.200720.012 Display Build ID : RP1A.200720.012.A217FXXU6CUH1 Release ID : 11 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a21snsxx-user 11 RP1A.200720.012 A217FXXU6CUH1 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 140777. Writing eMMC firmware from file: C:/Program Files (x86)/Medusa Pro Software/EMMC_firmwares/KMDH6001DM-B422/KMDH6001DM-B422_FW.bin...Done. Finalizing... Failed reconnect operation. Get Measurements error. Reloading... Disconnected. i believe this one is supported check |
06-20-2022, 11:15 | #5 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello What interface do you use to connect your chip(via socket or ISP)? Also, please send us photo of how do you solder. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
