Pls help Bit will change auto 1bit. pls help [Answered] Dear sir, i set manual bit mode was 8Bit, Software change to 1Bit mode.. pls help... but last version is working fine 8Bit Latest update not work pls help Log: Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.0V Bus Mode : 1 bit Bus speed : 50 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC DD68MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100444436384D420230B6D4E8C6BF Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DD68MB Product revision : 0.2 Product serial number : (hex) 30B6D4E8 Manufacturing date : 12/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DD68MB_06_10_2020_14_10_09.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 2.00. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00020000) 64 MB P03: para (00020840, 00000400) 512 KB P04: opporeserve1 (00020C40, 00004000) 8 MB P05: opporeserve2 (00024C40, 00020000) 64 MB P06: opporeserve3 (00044C40, 00020000) 64 MB P07: oppo_custom (00064C40, 00000800) 1024 KB P08: expdb (00065440, 0000A000) 20 MB P09: frp (0006F440, 00000800) 1024 KB P10: nvcfg (0006FC40, 00010000) 32 MB P11: nvdata (0007FC40, 00020000) 64 MB P12: metadata (0009FC40, 00010000) 32 MB P13: protect1 (000AFC40, 00004000) 8 MB P14: protect2 (000B3C40, 000043C0) 8.469 MB P15: seccfg (000B8000, 00004000) 8 MB P16: persist (000BC000, 00018000) 48 MB P17: sec1 (000D4000, 00001000) 2048 KB P18: proinfo (000D5000, 00001800) 3072 KB P19: md1img (000D6800, 00032000) 100 MB P20: spmfw (00108800, 00000800) 1024 KB P21: scp1 (00109000, 00000800) 1024 KB P22: scp2 (00109800, 00000800) 1024 KB P23: sspm_1 (0010A000, 00000800) 1024 KB P24: sspm_2 (0010A800, 00000800) 1024 KB P25: gz1 (0010B000, 00008000) 16 MB P26: gz2 (00113000, 00008000) 16 MB P27: nvram (0011B000, 00020000) 64 MB P28: lk (0013B000, 00002800) 5 MB P29: lk2 (0013D800, 00002800) 5 MB P30: boot (00140000, 00010000) 32 MB P31: logo (00150000, 00008000) 16 MB P32: dtbo (00158000, 00008000) 16 MB P33: tee1 (00160000, 00002800) 5 MB P34: tee2 (00162800, 00005800) 11 MB P35: odm (00168000, 00080000) 256 MB P36: vendor (001E8000, 00230000) 1120 MB P37: system (00418000, 00C00000) 6 GB P38: vbmeta (01018000, 00004000) 8 MB P39: cache (0101C000, 000D8000) 432 MB P40: userdata (010F4000, 0292C7DF) 20.59 GB P41: otp (03A207DF, 00015800) 43 MB P42: flashinfo (03A35FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DD68MB_nvdata_0x7fc40_0x20000_06_10_2020_14_10_09. bin file... Reading. Please wait... Done. Elapsed time 00:00:11 SW: 2.1.3; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 4292608 Number of sectors : 12582912 Build ID : PPR1.180610.011 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6765_19451-user 9 PPR1.180610.011 eng.root.20200910.202802 release-keys ---------------------------------------------------------------RPMB: Counter of the successful data write requests = 382. |
Dear sir pls help help |
You dont have original Medusa sockets If you have original socket you will get full speed |
What type of socket exactly do You have, please make a photo and post here? |
Please, check Statement about third party supplies |
But old version work fine sir.. |
As we mentioned in that statement, we don't provide or guarantee stable or correct work for third party supplies |
for that medusa team stop old version to work |
Official Medusa pro 2 adapter Emmc Bga 254 adapter available or not? I fine gsm server Emmc adapter picture show BGA162/186 BGA 221 BGA 153 BGA 529 But BGA254 available or not? Pls tell me. For am waiting for boy.. |
I think it's not true because moorc adapter always is better than any one I have original socket of Medusa pro2 and many times bit changed to 1 with eMMC brand new I'm sure it's sw problem |
Hello. First of all post here full Software log, we'll check it! |
I think it's bug for new Update V2.1.3. Pls check and fix this issue. Mr.BABAK NURI is test original adapter with same error. |
