08-08-2020, 13:17 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Not Reachable Age: 31
Member: 1351351 Status: Offline Thanks Meter: 277 | qualcomm write .xml file userdata was 0b help team pls [Answered] today write Lenvo k6 power .xml file after user data 0b pls help LOG: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.4V Bus Mode : 8 bits Bus speed : 50 MHz Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A53782B2FC1573 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.5 Product serial number : (hex) 3782B2FC Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG4a2_08_08_2020_17_41_37.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.2; FW: 2.00. P00: GPT (00000000, 00008000) 16 MB P01: modem (00008000, 0002A000) 84 MB P02: sec (00032000, 00000020) 16 KB P03: lksecapp (00032020, 00000100) 128 KB P04: lksecappbak (00032120, 00000100) 128 KB P05: cmnlib (00032220, 00000200) 256 KB P06: cmnlibbak (00032420, 00000200) 256 KB P07: cmnlib64 (00032620, 00000200) 256 KB P08: cmnlib64bak (00032820, 00000200) 256 KB P09: keymaster (00032A20, 00000200) 256 KB P10: keymasterbak (00032C20, 00000200) 256 KB P11: aboot (00032E20, 00001000) 2048 KB P12: abootbak (00033E20, 00001000) 2048 KB P13: devinfo (00034E20, 00000800) 1024 KB P14: limits (00035620, 00000040) 32 KB P15: prov32 (00035660, 00000200) 256 KB P16: prov32bak (00035860, 00000200) 256 KB P17: kpadA (00035A60, 000025A0) 4.703 MB P18: fsc (00038000, 00000002) 1024 b P19: ssd (00038002, 00000010) 8 KB P20: sbl1 (00038012, 00000400) 512 KB P21: sbl1bak (00038412, 00000400) 512 KB P22: rpm (00038812, 00000400) 512 KB P23: rpmbak (00038C12, 00000400) 512 KB P24: tz (00039012, 00001000) 2048 KB P25: tzbak (0003A012, 00001000) 2048 KB P26: devcfg (0003B012, 00000200) 256 KB P27: devcfgbak (0003B212, 00000200) 256 KB P28: dsp (0003B412, 00008000) 16 MB P29: modemst1 (00043412, 00000C00) 1536 KB P30: modemst2 (00044012, 00000C00) 1536 KB P31: DDR (00044C12, 00000040) 32 KB P32: fsg (00044C52, 00000C00) 1536 KB P33: kpadB (00045852, 000027AE) 4.96 MB P34: boot (00048000, 00020000) 64 MB P35: recovery (00068000, 00020000) 64 MB P36: apdp (00088000, 00000200) 256 KB P37: msadp (00088200, 00000200) 256 KB P38: dpo (00088400, 00000010) 8 KB P39: splash (00088410, 00005800) 11 MB P40: misc (0008DC10, 00000800) 1024 KB P41: keystore (0008E410, 00000400) 512 KB P42: config (0008E810, 00000040) 32 KB P43: oem (0008E850, 00020000) 64 MB P44: mota (000AE850, 00000400) 512 KB P45: dip (000AEC50, 00000800) 1024 KB P46: mdtp (000AF450, 00010000) 32 MB P47: syscfg (000BF450, 00000400) 512 KB P48: mcfg (000BF850, 00002000) 4 MB P49: persist (000C1850, 00010000) 32 MB P50: cache (000D1850, 00080000) 256 MB P51: mrd (00158000, 00020000) 64 MB P52: system (00178000, 00700000) 3584 MB P53: preload (00878000, 000C8000) 400 MB P54: userdata (00940000, 00000000) 0 b Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst1_0x43412_0xc00_08_08_2020_17_41_37. bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.2; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst2_0x44012_0xc00_08_08_2020_17_41_37. bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.2; FW: 2.00. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_fsg_0x44c52_0xc00_08_08_2020_17_41_37.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.2; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 1540096 Number of sectors : 7340032 Device Manufacturer : Lenovo Device Platform : msm8937 Build ID : NRD90N Display Build ID : K33_S231_171114_ROW Release ID : 7.0 Device Model : Lenovo K33 Device Name : karate Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : karate-user 7.0 NRD90N K33_S231_171114_ROW release-keys ---------------------------------------------------------------RPMB: Counter of the successful data write requests = 2615. Backuping data... |
09-20-2020, 20:11 | #8 (permalink) |
Major Poster Join Date: Jan 2015
Member: 2328327 Status: Offline Thanks Meter: 3 | Welcome to Medusa Pro Software version 2.1.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC hB8aP Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68423861503E010727B8385661 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hB8aP Product revision : 0.1 Product serial number : (hex) 727B838 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/hB8aP_19_09_2020_14_43_54.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: fsc (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: dpo (00000048, 00000010) 8 KB P04: switch (00000058, 00000020) 16 KB P05: sec (00000078, 00000048) 36 KB P06: DDR (000000C0, 00000080) 64 KB P07: config (00000140, 00000080) 64 KB P08: limits (000001C0, 00000040) 32 KB P09: lksecapp (00000200, 00000100) 128 KB P10: lksecappbak (00000300, 00000100) 128 KB P11: devcfg (00000400, 00000200) 256 KB P12: devcfgbak (00000600, 00000200) 256 KB P13: apdp (00000800, 00000200) 256 KB P14: msadp (00000A00, 00000200) 256 KB P15: rpm (00000C00, 00000400) 512 KB P16: rpmbak (00001000, 00000400) 512 KB P17: mota (00001400, 00000400) 512 KB P18: keystore (00001800, 00000400) 512 KB P19: syscfg (00001C00, 00000400) 512 KB P20: misc (00002000, 00000800) 1024 KB P21: dip (00002800, 00000800) 1024 KB P22: sbl1 (00003000, 00000800) 1024 KB P23: sbl1bak (00003800, 00000800) 1024 KB P24: cmnlib (00004000, 00000800) 1024 KB P25: cmnlibbak (00004800, 00000800) 1024 KB P26: cmnlib64 (00005000, 00000800) 1024 KB P27: cmnlib64bak (00005800, 00000800) 1024 KB P28: keymaster (00006000, 00000800) 1024 KB P29: keymasterbak (00006800, 00000800) 1024 KB P30: aboot (00007000, 00001000) 2048 KB P31: abootbak (00008000, 00001000) 2048 KB P32: fsg (00009000, 00001000) 2048 KB P33: tz (0000A000, 00002000) 4 MB P34: tzbak (0000C000, 00002000) 4 MB P35: mcfg (0000E000, 00002000) 4 MB P36: modemst1 (00010000, 00004000) 8 MB P37: modemst2 (00014000, 00004000) 8 MB P38: devinfo (00018000, 00004000) 8 MB P39: devbk1 (0001C000, 00004000) 8 MB P40: dsp (00020000, 00008000) 16 MB P41: oops (00028000, 00008000) 16 MB P42: splash (00030000, 00010000) 32 MB P43: persist (00040000, 00020000) 64 MB P44: persistbak (00060000, 00020000) 64 MB P45: mdtp (00080000, 00010000) 32 MB P46: logdump (00090000, 00030000) 96 MB P47: boot (000C0000, 00020000) 64 MB P48: recovery (000E0000, 00020000) 64 MB P49: modem (00100000, 0002C000) 88 MB P50: logo (0012C000, 0000F800) 31 MB P51: dtbo (0013B800, 00004000) 8 MB P52: vbmeta (0013F800, 00000800) 1024 KB P53: miuidump (00140000, 00040000) 128 MB P54: cache (00180000, 00080000) 256 MB P55: oem (00200000, 00080000) 256 MB P56: cust (00280000, 001A0000) 832 MB P57: vendor (00420000, 00200000) 1024 MB P58: system (00620000, 00700000) 3584 MB P59: userdata (00D20000, 02D1DFDF) 22.56 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/hB8aP_fsg_0x9000_0x1000_19_09_2020_14_43_54.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/hB8aP_modemst1_0x10000_0x4000_19_09_2020_14_43_54. bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.1.1; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/hB8aP_modemst2_0x14000_0x4000_19_09_2020_14_43_54. bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 6422528 Number of sectors : 7340032 Device Manufacturer : xiaomi Build ID : PKQ1.181021.001 Display Build ID : PKQ1.181021.001 Release ID : 9 Device Model : Redmi 7 Device Name : onc Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : onc-user 9 PKQ1.181021.001 V11.0.2.0.PFLMIXM release-keys ---------------------------------------------------------------Selected file: C:/Users/Kristhian/Desktop/Redmi 7 (onclite) Redmi Y3 Bootloader Unlock File/Bootloader File/rawprogram0.xml. Selected file: C:/Users/Kristhian/Desktop/Redmi 7 (onclite) Redmi Y3 Bootloader Unlock File/Bootloader File/patch0.xml. Backuping. Please wait... Backuping finished. #grenWriting. Please wait... Write data verification is enabled. Writing partition 3... Done. Writing partition 4... Done. Writing partition 4... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 2.1.1; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC hB8aP Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68423861503E010727B8385661 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hB8aP Product revision : 0.1 Product serial number : (hex) 727B838 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/hB8aP_19_09_2020_14_45_47.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: fsc (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: dpo (00000048, 00000010) 8 KB P04: switch (00000058, 00000020) 16 KB P05: sec (00000078, 00000048) 36 KB P06: DDR (000000C0, 00000080) 64 KB P07: config (00000140, 00000080) 64 KB P08: limits (000001C0, 00000040) 32 KB P09: lksecapp (00000200, 00000100) 128 KB P10: lksecappbak (00000300, 00000100) 128 KB P11: devcfg (00000400, 00000200) 256 KB P12: devcfgbak (00000600, 00000200) 256 KB P13: apdp (00000800, 00000200) 256 KB P14: msadp (00000A00, 00000200) 256 KB P15: rpm (00000C00, 00000400) 512 KB P16: rpmbak (00001000, 00000400) 512 KB P17: mota (00001400, 00000400) 512 KB P18: keystore (00001800, 00000400) 512 KB P19: syscfg (00001C00, 00000400) 512 KB P20: misc (00002000, 00000800) 1024 KB P21: dip (00002800, 00000800) 1024 KB P22: sbl1 (00003000, 00000800) 1024 KB P23: sbl1bak (00003800, 00000800) 1024 KB P24: cmnlib (00004000, 00000800) 1024 KB P25: cmnlibbak (00004800, 00000800) 1024 KB P26: cmnlib64 (00005000, 00000800) 1024 KB P27: cmnlib64bak (00005800, 00000800) 1024 KB P28: keymaster (00006000, 00000800) 1024 KB P29: keymasterbak (00006800, 00000800) 1024 KB P30: aboot (00007000, 00001000) 2048 KB P31: abootbak (00008000, 00001000) 2048 KB P32: fsg (00009000, 00001000) 2048 KB P33: tz (0000A000, 00002000) 4 MB P34: tzbak (0000C000, 00002000) 4 MB P35: mcfg (0000E000, 00002000) 4 MB P36: modemst1 (00010000, 00004000) 8 MB P37: modemst2 (00014000, 00004000) 8 MB P38: devinfo (00018000, 00004000) 8 MB P39: devbk1 (0001C000, 00004000) 8 MB P40: dsp (00020000, 00008000) 16 MB P41: oops (00028000, 00008000) 16 MB P42: splash (00030000, 00010000) 32 MB P43: persist (00040000, 00020000) 64 MB P44: persistbak (00060000, 00020000) 64 MB P45: mdtp (00080000, 00010000) 32 MB P46: logdump (00090000, 00030000) 96 MB P47: boot (000C0000, 00020000) 64 MB P48: recovery (000E0000, 00020000) 64 MB P49: modem (00100000, 0002C000) 88 MB P50: logo (0012C000, 0000F800) 31 MB P51: dtbo (0013B800, 00004000) 8 MB P52: vbmeta (0013F800, 00000800) 1024 KB P53: miuidump (00140000, 00040000) 128 MB P54: cache (00180000, 00080000) 256 MB P55: oem (00200000, 00080000) 256 MB P56: cust (00280000, 001A0000) 832 MB P57: vendor (00420000, 00200000) 1024 MB P58: system (00620000, 00700000) 3584 MB P59: userdata (00D20000, 00000000) 0 b Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/hB8aP_fsg_0x9000_0x1000_19_09_2020_14_45_47.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/hB8aP_modemst1_0x10000_0x4000_19_09_2020_14_45_47. bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.1.1; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/hB8aP_modemst2_0x14000_0x4000_19_09_2020_14_45_47. bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 6422528 Number of sectors : 7340032 Device Manufacturer : xiaomi Build ID : PKQ1.181021.001 Display Build ID : PKQ1.181021.001 Release ID : 9 Device Model : Redmi 7 Device Name : onc Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : onc-user 9 PKQ1.181021.001 V11.0.2.0.PFLMIXM release-keys ---------------------------------------------------------------Disconnected. |
09-21-2020, 14:16 | #10 (permalink) |
Junior Member Join Date: May 2018 Location: china
Member: 2836173 Status: Offline Thanks Meter: 4 | I have already reflected that the problem has not been solved. . USERDATa 0b is a problem. It is also wrong for Qualcomm UFS to write the partition table of xml file. . Resizing during backup is also invalid. |
09-21-2020, 14:54 | #11 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As we mentioned higher, we'll fix the issue in next update |
The Following User Says Thank You to Medusa Box For This Useful Post: |
10-02-2020, 04:53 | #15 (permalink) |
Member: 2836173 Status: Offline Thanks Meter: 4 | Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Please use USB3.0 for better speed. Connected. Reading information. Manufacturer name: WDC Product name: SDINDDH4-64G Serial Number: 0041001800180028 OEM ID: Page size : 4096 B Block size : 4096 B Block count : 15628288 Size : 59.62 GB (61048.00 MB) AttrRefClkFreeq = 0 MaxDataInSize = 4096 MaxDataOutSize = 4096 Connect successful. HS Gear 1 Unable to select |
