06-10-2020, 12:04 | #1 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Tajikistan
Member: 2704006 Status: Offline Thanks Meter: 181 | Redmi 7 after write unlock files dead [Answered] When I flash full firmware, the speed stay 3kb/s whyle flash system. How to fix this problem Code: Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.0V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC hB8aP Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68423861503E01AD21362F6645 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hB8aP Product revision : 0.1 Product serial number : (hex) AD21362F Manufacturing date : 06/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 6422528 Number of sectors : 7340032 Device Manufacturer : xiaomi Build ID : PKQ1.181021.001 Display Build ID : PKQ1.181021.001 Release ID : 9 Device Model : Redmi 7 Device Name : onc Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : onc-user 9 PKQ1.181021.001 V11.0.2.0.PFLMIXM release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hB8aP_10_06_2020_13_33_29.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: fsc (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: dpo (00000048, 00000010) 8 KB P04: switch (00000058, 00000020) 16 KB P05: sec (00000078, 00000048) 36 KB P06: DDR (000000C0, 00000080) 64 KB P07: config (00000140, 00000080) 64 KB P08: limits (000001C0, 00000040) 32 KB P09: lksecapp (00000200, 00000100) 128 KB P10: lksecappbak (00000300, 00000100) 128 KB P11: devcfg (00000400, 00000200) 256 KB P12: devcfgbak (00000600, 00000200) 256 KB P13: apdp (00000800, 00000200) 256 KB P14: msadp (00000A00, 00000200) 256 KB P15: rpm (00000C00, 00000400) 512 KB P16: rpmbak (00001000, 00000400) 512 KB P17: mota (00001400, 00000400) 512 KB P18: keystore (00001800, 00000400) 512 KB P19: syscfg (00001C00, 00000400) 512 KB P20: misc (00002000, 00000800) 1024 KB P21: dip (00002800, 00000800) 1024 KB P22: sbl1 (00003000, 00000800) 1024 KB P23: sbl1bak (00003800, 00000800) 1024 KB P24: cmnlib (00004000, 00000800) 1024 KB P25: cmnlibbak (00004800, 00000800) 1024 KB P26: cmnlib64 (00005000, 00000800) 1024 KB P27: cmnlib64bak (00005800, 00000800) 1024 KB P28: keymaster (00006000, 00000800) 1024 KB P29: keymasterbak (00006800, 00000800) 1024 KB P30: aboot (00007000, 00001000) 2048 KB P31: abootbak (00008000, 00001000) 2048 KB P32: fsg (00009000, 00001000) 2048 KB P33: tz (0000A000, 00002000) 4 MB P34: tzbak (0000C000, 00002000) 4 MB P35: mcfg (0000E000, 00002000) 4 MB P36: modemst1 (00010000, 00004000) 8 MB P37: modemst2 (00014000, 00004000) 8 MB P38: devinfo (00018000, 00004000) 8 MB P39: devbk1 (0001C000, 00004000) 8 MB P40: dsp (00020000, 00008000) 16 MB P41: oops (00028000, 00008000) 16 MB P42: splash (00030000, 00010000) 32 MB P43: persist (00040000, 00020000) 64 MB P44: persistbak (00060000, 00020000) 64 MB P45: mdtp (00080000, 00010000) 32 MB P46: logdump (00090000, 00030000) 96 MB P47: boot (000C0000, 00020000) 64 MB P48: recovery (000E0000, 00020000) 64 MB P49: modem (00100000, 0002C000) 88 MB P50: logo (0012C000, 0000F800) 31 MB P51: dtbo (0013B800, 00004000) 8 MB P52: vbmeta (0013F800, 00000800) 1024 KB P53: miuidump (00140000, 00040000) 128 MB P54: cache (00180000, 00080000) 256 MB P55: oem (00200000, 00080000) 256 MB P56: cust (00280000, 001A0000) 832 MB P57: vendor (00420000, 00200000) 1024 MB P58: system (00620000, 00700000) 3584 MB P59: userdata (00D20000, 02D1DFDF) 22.56 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hB8aP_fsg_0x9000_0x1000_10_06_2020_13_33_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.9; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hB8aP_modemst1_0x10000_0x4000_10_06_2020_13_33_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.0.9; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hB8aP_modemst2_0x14000_0x4000_10_06_2020_13_33_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.0.9; FW: 1.24. Partition table has been found on device. Selected file: C:/Users/Ravshan/Desktop/step1/rawprogram0.xml. Selected file: C:/Users/Ravshan/Desktop/step1/rawprogram0.xml. Selected file: C:/Users/Ravshan/Desktop/step1/patch0.xml. Backuping. Please wait... Backuping finished. #grenWriting. Please wait... Write data verification is enabled. Writing partition 3... Done. Writing partition 4... Done. Writing partition 4... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 2.0.9; FW: 1.24. Disconnected. |
06-10-2020, 14:26 | #2 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | the speed is to slowly cause the partition are currupted to avoid that do next set voltage to 1.8 or 2.0v 1-make a full dump of your hanset 2-then wipe those partitions / system. vendor . userdata 3-disconnect and connect again and write a full dump 4-write your xml firmware and enjoy speed |
06-10-2020, 16:09 | #3 (permalink) | |
Member: 2704006 Status: Offline Thanks Meter: 181 | Quote:
I Need dump for Redmi 7... | |
06-11-2020, 08:50 | #6 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,041 | Just write files again and Unselect gpt (last option ) All will works fine |
The Following User Says Thank You to Fast Unlocker For This Useful Post: |
