11-06-2020, 14:07
#1 (permalink)
Member: 2105490
Thanks Meter: 29 | Repair boot phone condor T8 and increase memory volume from 8 to 16GB Repair bot phone condor T8 and increase memory volume from 8 to 16GB Quote:
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC Q823MB
Page size : 512 B
Block size : 512 B
Block count : 30535680
Size : 14.56 GB (14910.00 MB)
CID Info
CID : 150100513832334D420042DDF27C430D
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : Q823MB
Product revision : 0.0
Product serial number : (hex) 42DDF27C
Manufacturing date : 04/2016
CSD Info
CSD : D02701320F5903FFF6DBFFEF92404009
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 2048 Kbytes
Boot2 size : 2048 Kbytes
RPMB size : 512 Kbytes
Partition config : (0x08) 00001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 5087232 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q823MB_05_11_2020_17_51_27.bin.
Connect successful.
SW: 2.1.4; FW: 1.24.
---------------------------------------------------------------Searching Android build info...
Not found
---------------------------------------------------------------Repairing from file "F:/BOOT/CONDOR/PHONE/T8/CONDOR_T8.srf".
Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition... Done.
Switched to boot area partition 2.
Writing BOOT2 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing prodnv partition... Done.
Writing miscdata partition... Done.
Writing recovery partition... Done.
Writing misc partition... Done.
Writing trustos partition... Done.
Writing trustos_bak partition... Done.
Writing sml partition... Done.
Writing sml_bak partition... Done.
Writing uboot partition... Done.
Writing uboot_bak partition... Done.
Writing uboot_log partition... Done.
Writing logo partition... Done.
Writing fbootlogo partition... Done.
Writing w_fixnv1 partition... Done.
Writing w_fixnv2 partition... Done.
Writing w_runtimenv1 partition... Done.
Writing w_runtimenv2 partition... Done.
Writing persist partition... Done.
Writing gpsgl partition... Done.
Writing gpsbd partition... Done.
Writing wcnmodem partition... Done.
Writing w_modem partition... Done.
Writing w_deltanv partition... Done.
Writing w_gdsp partition... Done.
Writing pm_sys partition... Done.
Writing boot partition... Done.
Writing vendor partition... Done.
Writing vbmeta partition... Done.
Writing vbmeta_bak partition... Done.
Smart Repair is successfully complete.
Disconnected.
