Replacing EMMC on Philips W8510 [Answered] Hi, have a Philips W8510 with read only EMMC, in the phone Hynix H9TP32A8JDMC (4GB ROM 1GB RAM), I try to replace EMMC. From Aliexpress ordered the same Hynix: H9TP32A8JDMC 4GB ROM 1GB RAM, but here's what's interesting, on the old original EMMC, the boot1, boot2 and RPM partitions were 2MB each, but in EMMC ordering form Alliexpress came in with boot1 and boot2 1MB, and RPM is 128Kb. I tried changing the size of partitions using medusa pro, but on SKHynix EMMC didn't work, with medusa pro I flash Philips W8510 firmware via vendor on the new EMMC, put the new EMMC (with boot1 and boot2 1MB, and RPM 128Kb) in the phone, but the phone does not turn on, and the infinity box does not see EMMC. I try flash phone with infinity box and Flashtool, but both programs give errors. There I have a samsung EMMC also 4gb and 1gb ram, I think with Medusa Pro change CID to H9TP32A8 JDMC change boot1, boot2 and RPM partitions to 2MB and write firmware, but first I would like to receive answers to some questions. 1. It happens that 2 identical EMMCs (H9TP32A8JDMC) were with different volumes of the partitions boot1, boot 2 and RPM ???? 2. Is it possible to change these partitions on skHynix EMMC with Medusa Pro ???? 3. The volumes of these partitions are critical or not ?????? 4. Is it possible to change the configuration and CID of the Samsung EMMC under the SkHinyx and flash the appropriate firmware ??? Thank you in advance |
Hello. 2. What exactly You want to change, it's not clear?! 3. All must be set to original values, same as in log file 4. Yes, You can edit CID, but there is some eMMC where You can't do that |
Hi You dont answer 1. It happens that 2 identical EMMCs (H9TP32A8JDMC) were with different volumes of the partitions boot1, boot 2 and RPM ???? and 3. The volumes of these partitions are critical or not ?????? Thanks for Advance |
