07-13-2020, 05:18 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Maracaibo, Venezuela Age: 39
Member: 427174 Status: Offline Thanks Meter: 17 | Resizing Micron emmc from Redmi Note 8 [Answered] And Sometimes it hangs on Backuping. I must state that phone was perfect, I simply wrote some file to bypass Xiaomi account and then problems started. |
07-13-2020, 15:07 | #3 (permalink) |
Member: 427174 Status: Offline Thanks Meter: 17 | Welcome to Medusa Pro Software version 2.1.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Micron eMMC S0J9K8 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 13014E53304A394B381012FD3AEB863D Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : S0J9K8 Product revision : 1.0 Product serial number : (hex) 12FD3AEB Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D05F01328F5913FFFFFFFFEF964000A9 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 50 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20348928 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/S0J9K8_13_07_2020_10_01_37.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: switch (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: secdata (00000048, 00000040) 32 KB P04: limits (00000088, 00000040) 32 KB P05: multiimgoem (000000C8, 00000040) 32 KB P06: multiimgqti (00000108, 00000040) 32 KB P07: qupfw (00000148, 00000080) 64 KB P08: qupfwbak (000001C8, 00000080) 64 KB P09: vbmeta (00000248, 00000080) 64 KB P10: vbmetabak (000002C8, 00000080) 64 KB P11: xbl_config (00000348, 00000100) 128 KB P12: xbl_configbak (00000448, 00000100) 128 KB P13: devcfg (00000548, 00000100) 128 KB P14: devcfgbak (00000648, 00000100) 128 KB P15: bk0 (00000748, 000000B8) 92 KB P16: storsec (00000800, 00000100) 128 KB P17: fsc (00000900, 00000100) 128 KB P18: apdp (00000A00, 00000200) 256 KB P19: rpm (00000C00, 00000400) 512 KB P20: rpmbak (00001000, 00000400) 512 KB P21: hyp (00001400, 00000400) 512 KB P22: hypbak (00001800, 00000400) 512 KB P23: keymaster (00001C00, 00000400) 512 KB P24: keymasterbak (00002000, 00000400) 512 KB P25: cmnlib (00002400, 00000400) 512 KB P26: cmnlib64 (00002800, 00000400) 512 KB P27: cmnlibbak (00002C00, 00000400) 512 KB P28: cmnlib64bak (00003000, 00000400) 512 KB P29: keystore (00003400, 00000400) 512 KB P30: frp (00003800, 00000400) 512 KB P31: catefv (00003C00, 00000400) 512 KB P32: uefivarstore (00004000, 00000400) 512 KB P33: abl (00004400, 00000800) 1024 KB P34: ablbak (00004C00, 00000800) 1024 KB P35: ddr (00005400, 00000800) 1024 KB P36: bluetooth (00005C00, 00000800) 1024 KB P37: bluetoothbak (00006400, 00000800) 1024 KB P38: misc (00006C00, 00000800) 1024 KB P39: dip (00007400, 00000800) 1024 KB P40: toolsfv (00007C00, 00000800) 1024 KB P41: catecontentfv (00008400, 00000800) 1024 KB P42: imagefv (00008C00, 00001000) 2048 KB P43: imagefvbak (00009C00, 00001000) 2048 KB P44: uefisecapp (0000AC00, 00001000) 2048 KB P45: uefisecappbak (0000BC00, 00001000) 2048 KB P46: cateloader (0000CC00, 00001000) 2048 KB P47: modemst1 (0000DC00, 00001000) 2048 KB P48: modemst2 (0000EC00, 00001000) 2048 KB P49: xbl (0000FC00, 00001C00) 3584 KB P50: xblbak (00011800, 00001C00) 3584 KB P51: tz (00013400, 00002000) 4 MB P52: tzbak (00015400, 00002000) 4 MB P53: mdtpsecapp (00017400, 00002000) 4 MB P54: mdtpsecappbak (00019400, 00002000) 4 MB P55: spunvm (0001B400, 00004000) 8 MB P56: bk1 (0001F400, 00000C00) 1536 KB P57: devinfo (00020000, 00008000) 16 MB P58: logfs (00028000, 00004000) 8 MB P59: fsg (0002C000, 00005000) 10 MB P60: metadata (00031000, 00008000) 16 MB P61: bk2 (00039000, 00007000) 14 MB P62: oops (00040000, 00008000) 16 MB P63: dtbo (00048000, 0000C000) 24 MB P64: dtbobak (00054000, 0000C000) 24 MB P65: mdtp (00060000, 00010000) 32 MB P66: mdtpbak (00070000, 00010000) 32 MB P67: dsp (00080000, 00010000) 32 MB P68: dspbak (00090000, 00010000) 32 MB P69: persist (000A0000, 00020000) 64 MB P70: persistbak (000C0000, 00020000) 64 MB P71: logo (000E0000, 00010000) 32 MB P72: boot (000F0000, 00020000) 64 MB P73: bootbak (00110000, 00020000) 64 MB P74: splash (00130000, 00020000) 64 MB P75: logdump (00150000, 00020000) 64 MB P76: recovery (00170000, 00020000) 64 MB P77: rawdump (00190000, 00040000) 128 MB P78: minidump (001D0000, 00040000) 128 MB P79: exaid (00210000, 000C0000) 384 MB P80: modem (002D0000, 00080000) 256 MB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/S0J9K8_modemst1_0xdc00_0x1000_13_07_2020_10_01_37. bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/S0J9K8_modemst2_0xec00_0x1000_13_07_2020_10_01_37. bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.1; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/S0J9K8_fsg_0x2c000_0x5000_13_07_2020_10_01_37.bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.1.1; FW: 1.24. Here is the log after resizing, note that system and userdata partitions are gone And then I flash everything again from xml including gpt's and then resize hangs on backuping If I flash without the last 2 gpt files I can make a resizing, but same again, userdata wich is 0b and system disappear. I have tested 3 different firmwares downloaded from official site, so Im sure is not file problem. |
07-13-2020, 15:40 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Please, try to do next: 1. Write the firmware which You have. 2. Please, don't attempt to do any additional operations! 3. Turn on your device, the device should power on into Download Mode |
07-13-2020, 17:37 | #5 (permalink) |
Member: 427174 Status: Offline Thanks Meter: 17 | It doesn't work, I perform a full flash and then userdata partition appears but with 0bytes, phone turns on but I cannot perform a wipe, and I know is for that cause. I saved other Xiaomis with other box adjusting gpt, but this one other tool won't detect it, I think because i have the very old box, so my only chance is unbricking it with Medusa Pro, you should check qualcomm flashing via xml too on version 2.1.1 as I still having problems flashing full system partitions, it only flash 512mb of that partition, and if I install Medusa Pro 1.7.3 it flash sucessfully but with the same userdata in 0bytes. Last edited by Medusa Box; 07-14-2020 at 08:08. |
07-13-2020, 18:39 | #6 (permalink) |
Member: 427174 Status: Offline Thanks Meter: 17 | These are partition that always dissapear after a resizing P81: modembak (00350000, 00080000) 256 MB P82: cache (003D0000, 000C0000) 384 MB P83: gsort (00490000, 00008000) 16 MB P84: cust (00498000, 00200000) 1024 MB P85: vendor (00698000, 00300000) 1536 MB P86: system (00998000, 00900000) 4.5 GB P87: userdata (01298000, 00000000) 0 b |
07-14-2020, 11:22 | #8 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | To write redmi xml firmwares on last medusa update you need to uncheck the GPT main & backup to avoid getting userdata 0 |
The Following 4 Users Say Thank You to starkrimes For This Useful Post: |
07-14-2020, 18:27 | #9 (permalink) |
Member: 427174 Status: Offline Thanks Meter: 17 | Yes, I checked yesterday, another option I have found is that I made a full backup, and then after flashing firmware writing gpt from the backup back to the phone and userdata change from 0bytes to its real size, the only problem left would be that Medusa Pro flash partial files, but already answered, will be corrected in next update |
