09-24-2021, 20:12 | #1 (permalink) |
Junior Member Join Date: Sep 2020 Location: turkey Age: 39
Member: 2968254 Status: Offline Sonork: firat ayrılmazkardes Thanks Meter: 0 | Samsung a013g dump fİle help [Answered] i need a a013g dump fİle or .srf fİle for medusa. Please help me İf you have. |
09-27-2021, 10:01 | #3 (permalink) |
Member: 2968254 Status: Offline Sonork: firat ayrılmazkardes Thanks Meter: 0 | Welcome to Medusa Pro Software version 2.2.2. Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D4200BB90BAE2B7D1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) BB90BAE2 Manufacturing date : 11/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/FE62MB_27_09_2021_11_51_59.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 0000D000) 26 MB P02: para (0000F000, 00000400) 512 KB P03: efs (0000F400, 00004000) 8 MB P04: sec_efs (00013400, 00004000) 8 MB P05: bota (00017400, 0000E400) 28.5 MB P06: param (00025800, 00002000) 4 MB P07: up_param (00027800, 00002000) 4 MB P08: expdb (00029800, 0000A000) 20 MB P09: frp (00033800, 00000800) 1024 KB P10: nvcfg (00034000, 00010000) 32 MB P11: nvdata (00044000, 00020000) 64 MB P12: metadata (00064000, 00010000) 32 MB P13: protect1 (00074000, 00004000) 8 MB P14: protect2 (00078000, 00004000) 8 MB P15: seccfg (0007C000, 00004000) 8 MB P16: persist (00080000, 00018000) 48 MB P17: persistent (00098000, 00000400) 512 KB P18: misc (00098400, 00003C00) 7.5 MB P19: vbmeta_system (0009C000, 00004000) 8 MB P20: vbmeta_vendor (000A0000, 00004000) 8 MB P21: recovery (000A4000, 00010000) 32 MB P22: md_udc (000B4000, 0000C000) 24 MB P23: sec1 (000C0000, 00001000) 2048 KB P24: proinfo (000C1000, 00001800) 3072 KB P25: efuse (000C2800, 00000400) 512 KB P26: md1img (000C2C00, 00040000) 128 MB P27: spmfw (00102C00, 00000800) 1024 KB P28: dummy (00103400, 00000800) 1024 KB P29: mcupmfw (00103C00, 00000800) 1024 KB P30: nvram (00104400, 00020000) 64 MB P31: gz1 (00124400, 00008000) 16 MB P32: gz2 (0012C400, 00008000) 16 MB P33: lk (00134400, 00001000) 2048 KB P34: loader_ext1 (00135400, 00000080) 64 KB P35: loader_ext2 (00135480, 00000080) 64 KB P36: steady (00135500, 00002000) 4 MB P37: boot (00137500, 00010000) 32 MB P38: dtbo (00147500, 00004000) 8 MB P39: tee1 (0014B500, 00003000) 6 MB P40: reserved (0014E500, 00001C00) 3584 KB P41: super (00150100, 00468000) 2256 MB P42: vbmeta (005B8100, 00004000) 8 MB P43: prism (005BC100, 00019000) 50 MB P44: optics (005D5100, 0000A000) 20 MB P45: cache (005DF100, 0003E800) 125 MB P46: omr (0061D900, 0000C000) 24 MB P47: userdata (00629900, 03412700) 26.04 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FE62MB_efs_0xf400_0x4000_27_09_2021_11_51_59.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.2; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FE62MB_nvdata_0x44000_0x20000_27_09_2021_11_51_59. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.2; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found ------------- |
