05-11-2021, 08:58 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 36
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,307 | Here is tested .............. |
The Following 3 Users Say Thank You to Faheem Anjum For This Useful Post: |
05-12-2021, 13:50 | #6 (permalink) |
No Life Poster Join Date: Apr 2004 Location: POland
Member: 60746 Status: Offline Thanks Meter: 56 | its the msame pinout - i think that medusa users need some modification in pin connector Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : 12.5 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) |
05-13-2021, 10:36 | #8 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | Welcome to Medusa Pro Software version 2.2.0. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: O2Micro CCID SC Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC CUTA42 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 15010043555441343200D123D4448635 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CUTA42 Full name one from : KLMCG2UCTA-B041 Product revision : 0.0 Product serial number : (hex) D123D444 Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CUTA42_13_05_2021_11_35_03.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: bota1 (00004000, 00004000) 8 MB P03: efs (00008000, 0000A000) 20 MB P04: sec_efs (00012000, 0000A000) 20 MB P05: cpefs (0001C000, 00004000) 8 MB P06: bota2 (00020000, 00004000) 8 MB P07: cm (00024000, 00004000) 8 MB P08: m9kefs1 (00028000, 00002000) 4 MB P09: m9kefs2 (0002A000, 00002000) 4 MB P10: m9kefs3 (0002C000, 00002000) 4 MB P11: nad_refer (0002E000, 00000800) 1024 KB P12: param (0002E800, 00004000) 8 MB P13: up_param (00032800, 00004000) 8 MB P14: misc (00036800, 00001000) 2048 KB P15: boot (00037800, 00012000) 36 MB P16: recovery (00049800, 0001A800) 53 MB P17: dtb (00064000, 00004000) 8 MB P18: dtbo (00068000, 00004000) 8 MB P19: radio (0006C000, 00016800) 45 MB P20: persistent (00082800, 00000400) 512 KB P21: steady (00082C00, 00002000) 4 MB P22: vbmeta (00084C00, 00000400) 512 KB P23: bota3 (00085000, 00000400) 512 KB P24: reserved2 (00085400, 00002C00) 5.5 MB P25: system (00088000, 0099C000) 4.805 GB P26: vendor (00A24000, 00148000) 656 MB P27: product (00B6C000, 000F8000) 496 MB P28: cache (00C64000, 000C8000) 400 MB P29: omr (00D2C000, 00019000) 50 MB P30: cp_debug (00D45000, 00002800) 5 MB P31: nad_fw (00D47800, 0000A000) 20 MB P32: userdata (00D51800, 06728000) 51.58 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CUTA42_efs_0x8000_0xa000_13_05_2021_11_35_03.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.2.0; FW: 2.00. Backuping cpefs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CUTA42_cpefs_0x1c000_0x4000_13_05_2021_11_35_03.bi n file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.0; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 557056 Number of sectors : 10076160 Build ID : RP1A.200720.012 Display Build ID : RP1A.200720.012.A405FNXXU3CUC2 Release ID : 11 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a40xx-user 11 RP1A.200720.012 A405FNXXU3CUC2 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 7330. |
The Following 3 Users Say Thank You to zaskar For This Useful Post: |
