GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Medusa (https://forum.gsmhosting.com/vbb/f664/)
-   -   Samsung Galaxy A21s (SM-A217F) Read / Write Success ( Via ISP ) By Medusa Pro (https://forum.gsmhosting.com/vbb/f664/samsung-galaxy-a21s-sm-a217f-read-write-success-via-isp-medusa-pro-3012892/)
GSM AR 04-09-2022 12:45
Read Backup
https://i.ibb.co/DbwK4hj/a21s.png
Welcome to Medusa Pro Software version 2.2.4.2.
Started.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage  : 2.0V
Bus Mode  : 1 bit
Bus speed : Auto
Connecting...
Device      : Micron eMMC G1J9R8
Page size    : 512 B
Block size  : 512 B
Block count  : 122142720
Size        : 58.24 GB (59640.00 MB)
CID Info
CID                  : 13014E47314A395238100604816D7787
Manufacturer ID      : 0X13
Device/BGA            : BGA (Discrete embedded)
OEM/Application ID    : 0X4E
Product name          : G1J9R8
Product revision      : 1.0
Product serial number : (hex) 604816D
Manufacturing date    : 07/2020
CSD Info
CSD                  : D04F01328F5913FFFFFFFFEF8A400083
CSD structure        : CSD version No. 1.2
SPEC version          : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
                        4.51, 5.0, 5.01, 5.1
Data read access time1: 40 ms
TRAN speed            : 26 MHz
READ block length    : 512 Bytes
WP group enable      : YES
PERM_WRITE_PROTECT    : NO
TMP_WRITE_PROTECT    : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size      : 512 Kbytes
Boot1 size            : 4096 Kbytes
Boot2 size            : 4096 Kbytes
RPMB size            : 16384 Kbytes
Partition config      : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK              : Boot acknowledge sent during boot operation Bit
Boot bus conditions  : (0x01) 00000001
Boot bus width        : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions  : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode            : Use single data rate + backward compatible timings in boot operation (default)
RST_n function        : (0x01) RST_n signal is permanently enabled
Partitioning support  : Device supports partitioning features
Enhanced attribute    : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 20348928 Kbytes
Partitions attribute  : 0x0
Part setting completed: 0x0
GP partition 1 size  : 0 b
GP partition 2 size  : 0 b
GP partition 3 size  : 0 b
GP partition 4 size  : 0 b
Enhanced area size    : (0x0) 0 b
Enhanced area start  : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/G1J9R8_08_04_2022_19_44_34.bin.
Connect successful.
SW: 2.2.4.2; FW: 1.24.
P00: GPT              (00000000, 00002000)    4 MB
P01: efs              (00002000, 0000A000)    20 MB
P02: sec_efs          (0000C000, 0000A000)    20 MB
P03: reserved        (00016000, 00002000)    4 MB
P04: cpefs            (00018000, 00004000)    8 MB
P05: steady          (0001C000, 00002000)    4 MB
P06: param            (0001E000, 00004000)    8 MB
P07: bota            (00022000, 00012000)    36 MB
P08: ldfw            (00034000, 00004000)    8 MB
P09: tzsw            (00038000, 00000C00)    1536 KB
P10: tzar            (00038C00, 00003400)    6.5 MB
P11: keystorage      (0003C000, 00000400)    512 KB
P12: nad_refer        (0003C400, 00000800)    1024 KB
P13: up_param        (0003CC00, 00004000)    8 MB
P14: misc            (00040C00, 00001000)    2048 KB
P15: uh              (00041C00, 00001000)    2048 KB
P16: uhcfg            (00042C00, 00002000)    4 MB
P17: blcmd            (00044C00, 00000400)    512 KB
P18: boot            (00045000, 00012000)    36 MB
P19: recovery        (00057000, 0001A800)    53 MB
P20: dtb              (00071800, 00004000)    8 MB
P21: dtbo            (00075800, 00004000)    8 MB
P22: radio            (00079800, 00019000)    50 MB
P23: persistent      (00092800, 00000400)    512 KB
P24: vbmeta          (00092C00, 00000400)    512 KB
P25: vbmeta_samsung  (00093000, 00000400)    512 KB
P26: keyrefuge        (00093400, 00008000)    16 MB
P27: keydata          (0009B400, 00008000)    16 MB
P28: metadata        (000A3400, 00010000)    32 MB
P29: reserved2        (000B3400, 00000C00)    1536 KB
P30: super            (000B4000, 00A5A000)    5.176 GB
P31: prism            (00B0E000, 00190000)    800 MB
P32: optics          (00C9E000, 0000A000)    20 MB
P33: cache            (00CA8000, 00064000)    200 MB
P34: omr              (00D0C000, 0000A000)    20 MB
P35: cp_debug        (00D16000, 00002800)    5 MB
P36: spu              (00D18800, 00019000)    50 MB
P37: userdata        (00D31800, 06748000)    51.64 GB
Searching Android build info...
Ok
Disk/Image size    : 8f800000 bytes
Device sector size    : 512 bytes
Partition offset      : 737280
Number of sectors    : 10854400
Build ID              : RP1A.200720.012
Display Build ID      : RP1A.200720.012.A217FXXU6CUF5
Release ID            : 11
Architecture ABI      : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description    : a21snsxx-user 11 RP1A.200720.012 A217FXXU6CUF5 release-keys
Save to C:/Users/AR/Desktop/a21s dump/Micron eMMC G1J9R8_08_04_2022__19_44_52.mpt file...
Reading partition GPT...    Done.
Reading partition efs...    Done.
Reading partition sec_efs...    Done.
Reading partition reserved...    Done.
Reading partition cpefs...    Done.
Reading partition steady...    Done.
Reading partition param...    Done.
Reading partition bota...    Done.
Reading partition ldfw...    Done.
Reading partition tzsw...    Done.
Reading partition tzar...    Done.
Reading partition keystorage...    Done.
Reading partition nad_refer...    Done.
Reading partition up_param...    Done.
Reading partition misc...    Done.
Reading partition uh...    Done.
Reading partition uhcfg...    Done.
Reading partition blcmd...    Done.
Reading partition boot...    Done.
Reading partition recovery...    Done.
Reading partition dtb...    Done.
Reading partition dtbo...    Done.
Reading partition radio...    Done.
Reading partition persistent...    Done.
Reading partition vbmeta...    Done.
Reading partition vbmeta_samsung...    Done.
Reading partition keyrefuge...    Done.
Reading partition keydata...    Done.
Reading partition metadata...    Done.
Reading partition reserved2...    Done.
Reading partition prism...    Done.
Reading partition optics...    Done.
Reading partition cache...    Done.
Reading partition omr...    Done.
Reading partition cp_debug...    Done.
Reading partition spu...    Done.
Reading is finished.
Phone have booting Problem i,e only official released binaries are allowed to be flashed
https://i.ibb.co/x60N2ms/a21s.png
Recovered Done By Medusa Pro By Flashing AP_A217FXXU6CUF5
Model Settings:
Interface : eMMC
Voltage  : 2.0V
Bus Mode  : 1 bit
Bus speed : Auto
Connecting...
Page size    : 512 B
Block size  : 512 B
CID Info
CSD Info
TRAN speed            : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/G1J9R8_09_04_2022_09_01_42.bin.
Connect successful.
Ok
Release ID            : 11
Selected pit file: C:/Users/AR/Desktop/A21s/A21S_EUR_OPEN.pit
Open file: C:/Users/AR/Desktop/A21s/AP_A217FXXU6CUF5_CL21842546_QB41130486_REV00_user_low_ship_MULTI_CERT_meta_RKEY_OS11.tar.md5
Writing PIT
Write data verification is enabled.
Writing. Please wait...
Writing partition MISC...    from 40C00 to 6    Done.
Writing partition BOOT...    from 45000 to 8CA6    Done.
Writing partition RECOVERY...    from 57000 to F8EA    Done.
Writing partition DTBO...    from 75800 to 1EE    Done.
Writing partition VBMETA...    from 92C00 to 7    Done.
Writing partition VBMETA_SAMSUNG...    from 93000 to 6    Done.
Writing partition METADATA...    from A3400 to 3    Done.
Writing partition SUPER...    from B4000 to 5BB26F Done.
Writing finished.
Reconnect the device to see changes.
Disconnected.
https://i.ibb.co/SJDrYbL/A217f.jpg
ISP Pinout
https://i.ibb.co/VptshxP/a21ss.png
Special Thanks To My Big Bro @GulzaR Ahmed :)
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.10208 seconds with 6 queries
