07-17-2020, 13:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Samsung Galaxy J5 (SM-J500F) ERROR[012] [Answered] ERROR[012]: Write error. At sector 0. Attempting to write... Disconnected. Its need replace new emmc or somthing else ? Code: Welcome to Medusa Pro Software version 2.1.1. Started. Reader #0: Generic USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734752101034184271389 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 3418427 Manufacturing date : 01/2016 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G4u_17_07_2020_16_45_42.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000400) 512 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00006402) 12.5 MB P19: backup (00052402, 000037EE) 6.991 MB P20: fsc (00055BF0, 00001800) 3072 KB P21: ssd (000573F0, 00000010) 8 KB P22: persist (00057400, 00004000) 8 MB P23: persistent (0005B400, 00000400) 512 KB P24: persdata (0005B800, 00004800) 9 MB P25: system (00060000, 00410000) 2080 MB P26: cache (00470000, 00064000) 200 MB P27: hidden (004D4000, 00023000) 70 MB P28: userdata (004F7000, 00998FD8) 4.799 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G4u_fsg_0x283c0_0x1800_17_07_2020_16_45_42.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.1.1; FW: 1.24. Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G4u_efs_0x34000_0x7000_17_07_2020_16_45_42.bin file... Reading. Please wait... ERROR[011]: Read error. Attempting to read... Done. Elapsed time 00:00:39 SW: 2.1.1; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G4u_modemst1_0x3b000_0x1800_17_07_2020_16_45_42.bin file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.1.1; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G4u_modemst2_0x3c800_0x1800_17_07_2020_16_45_42.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------Partition table has been found on device. Partition table has been found on device. Save to C:/Users/Rayyan/Desktop/J500F/modem_security folder... Reading partition modem... Done. Reading partition fsg... Done. Reading partition efs... Done. Reading partition modemst1... Done. Reading partition modemst2... Done. Reading partition persist... Done. Reading partition persistent... Done. Reading partition persdata... Done. Reading is finished. SW: 2.1.1; FW: 1.24. Switched to boot area partition 1. Erasing. Please wait... Done. SW: 2.1.1; FW: 1.24. Switched to boot area partition 2. Erasing. Please wait... Done. SW: 2.1.1; FW: 1.24. Switched to user area. Erasing. Please wait... Done. SW: 2.1.1; FW: 1.24. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.1.1; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734752101034184271389 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 3418427 Manufacturing date : 01/2016 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G4u_17_07_2020_17_01_12.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Smart report info: Hash code: 0000000000000000000000000000000000000000000000000000000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 DEVICE_LIFE_TIME_EST_TYP_B : Exceeded its maximum estimated device life time DEVICE_LIFE_TIME_EST_TYP_A : 0% - 10% device life time used PRE_EOL_INFO : Urgent SW: 2.1.1; FW: 1.24. No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is set Creating HW partitions succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734752101034184271389 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 3418427 Manufacturing date : 01/2016 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G4u_17_07_2020_17_04_21.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Smart report info: Hash code: 0000000000000000000000000000000000000000000000000000000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 DEVICE_LIFE_TIME_EST_TYP_B : 0% - 10% device life time used DEVICE_LIFE_TIME_EST_TYP_A : 0% - 10% device life time used PRE_EOL_INFO : Normal SW: 2.1.1; FW: 1.24. Switched to boot area partition 1. Opening C:/Users/Rayyan/Desktop/SAMSUNG_SM-J500F_DD_emmc_direct_dump_520MB/EMMC_QN16MB_ROM2_000000000000_000000400000.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 2.1.1; FW: 1.24. Switched to boot area partition 2. Opening C:/Users/Rayyan/Desktop/SAMSUNG_SM-J500F_DD_emmc_direct_dump_520MB/EMMC_QN16MB_ROM3_000000000000_000000400000.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 2.1.1; FW: 1.24. Switched to user area. Opening C:/Users/Rayyan/Desktop/SAMSUNG_SM-J500F_DD_emmc_direct_dump_520MB/EMMC_QN16MB_ROM1_000000000000_000020000000.bin file... Write data verification is enabled. Writing. Please wait... ERROR[012]: Write error. At sector 0. Attempting to write... Disconnected. |
