01-09-2012, 23:49 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: turkey
Member: 251901 Status: Offline Thanks Meter: 80 | Step By Step i9003 jig making :) [IMG]http://forum.gsmhosting.com/vbb/[/IMG] [IMG]http://forum.gsmhosting.com/vbb/[/IMG] [IMG]http://forum.gsmhosting.com/vbb/[/IMG] [IMG]http://forum.gsmhosting.com/vbb/[/IMG] [IMG]http://forum.gsmhosting.com/vbb/[/IMG] END JTAG speed : 1000 KHz. Detected TAP ID: 2B89102F, IR Length = 6. VREF level : 1.82 V CPU : Texas Instruments OMAP3630 Core ID : 0B6D602F Flash device: Samsung KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9003_Re pair.mf" file... Repair restarted at last fail position. Writting BOOT section. Please wait... Canceled... Disconnected Selected device model: Samsung GT-I9003 Connecting. Please wait... JTAG speed : 1000 KHz. Detected TAP ID: 2B89102F, IR Length = 6. VREF level : 1.82 V CPU : Texas Instruments OMAP3630 Core ID : 0B6D602F Flash device: Samsung KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "D:\GSM\Medusa Files\SAMSUNG_GTI9003_Re pair.mf" file... Repair restarted at last fail position. Writting BOOT section. Please wait... Done Writting UPCH section. Please wait... Done Disconnected Repair done. |
The Following 3 Users Say Thank You to blue53 For This Useful Post: |
01-22-2013, 21:43 | #4 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | Here is my 3g powerbutton jig hahaha. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 2B89102F, IR Length = 6. JTAG speed : 1000 KHz. VREF level : 1.81 V CPU : Texas Instruments OMAP3630 Core ID : 0B6D602F Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. Sent from my MS2 |
The Following User Says Thank You to gee4234 For This Useful Post: |
01-23-2013, 02:14 | #5 (permalink) | |
Member: 86579 Status: Offline Thanks Meter: 70 | Quote:
Welcome to Medusa Box Software version 1.6.5 ERROR[043]: Unable to open drive E: for write. Please check write permission. Selected device model: Samsung GT-I9003 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. ERROR[030]: TDO is constant high. Please check target device connection. MI: Medusa JTAG init failed. Selected device model: Samsung GT-I9003 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. Selected device model: Samsung GT-I9003 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 2B89102F, IR Length = 6. MI: Found ICEPick TAP Router 2B89102F. MI: Enabling ARM Cortex core. MI: Halting target, attempt 1. JTAG speed : 100 KHz. VREF level : 1.80 V CPU : Texas Instruments OMAP3630 Core ID : 0B6D602F MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. Disconnected Selected device model: Samsung GT-I9003 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 2B89102F, IR Length = 6. MI: Found ICEPick TAP Router 2B89102F. MI: Enabling ARM Cortex core. MI: Halting target, attempt 1. JTAG speed : 100 KHz. VREF level : 1.80 V CPU : Texas Instruments OMAP3630 Core ID : 0B6D602F MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9003_Re pair.mf" file... Writting BOOT section. Please wait... MI: Server status 0xFFFFFFFF (not STAT_IDLE). ERROR[018]: Logical block operation failed at 6160 Kb (Hex address 0x00604000). Reason: Connection lost. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 2B89102F, IR Length = 6. MI: Found ICEPick TAP Router 2B89102F. MI: Enabling ARM Cortex core. MI: Halting target, attempt 1. JTAG speed : 100 KHz. VREF level : 1.80 V CPU : Texas Instruments OMAP3630 Core ID : 0B6D602F MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9003_Re pair.mf" file... Repair restarted at last fail position. Writting BOOT section. Please wait... Done Writting UPCH section. Please wait... Done Disconnected | |
I need info doc to make scripts for send.exe ThanksĦĦ | Bolo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-09-2000 11:49 |
have nokia lock 2 solution by cable | oskarcore | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:49 |
Need help to make a site for free software | hicom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-14-1999 22:57 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
