Samsung J700H got dead while flashing[Solved] After flashed the phone with with the help of 4files in odin it's got dead and now i'm trying to repair it with Medusa pro and also with Medusa it's not cummnicating see the logs below...... Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700H_EMMC_AJNB3R.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
Hello. Please, check soldering and make sure that You solder all wires according to the Software manual, also, please try to use search to know our recommendations in case of ERROR[001] |
Model Settings: Interface : eMMC Brand : Samsung Model : SM-J700H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700H_EMMC_AJNB3R.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 400073 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1101003430303037330029CCC6CEA2E9 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 400073 Product revision : 0.0 Product serial number : (hex) 29CCC6CE Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 507904 Number of sectors : 4308992 Device Manufacturer :samsung Device Platform :exynos5 Build ID :LMY48B Display Build ID :LMY48B.J700HXXU1AOGA Release ID :5.1.1 Device Model :SM-J700H Device Name :j7e3gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j7e3gxx-user 5.1.1 LMY48B J700HXXU1AOGA release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_04_04_2019_15_10_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.5; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: CDMA-RADIO (00045800, 00002000) 4 MB P14: RADIO (00047800, 0002C000) 88 MB P15: TOMBSTONES (00073800, 00000800) 1024 KB P16: DNT (00074000, 00000800) 1024 KB P17: PERSISTENT (00074800, 00000400) 512 KB P18: PERSDATA (00074C00, 00006000) 12 MB P19: RESERVED2 (0007AC00, 00001400) 2560 KB P20: SYSTEM (0007C000, 0041C000) 2104 MB P21: CACHE (00498000, 00064000) 200 MB P22: HIDDEN (004FC000, 00014000) 40 MB P23: USERDATA (00510000, 01848000) 12.14 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700H_EMMC_AJNB3R.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. |
Please, try to repeat Smart Repair operation with disabled options for Write Verification, after post here full Software log. |
Problem was solved by disabling the Write Verification option, boot repair done. |
