Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 04-04-2019, 15:26   #1 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Smile Samsung J700H got dead while flashing[Solved]
After flashed the phone with with the help of 4files in odin it's got dead and now i'm trying to repair it with Medusa pro and also with Medusa it's not cummnicating see the logs below......
Model Settings: Interface : eMMC
Brand : Samsung
Model : SM-J700H
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700H_EMMC_AJNB3R.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Old 04-04-2019, 16:11   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,059
Hello.
Please, check soldering and make sure that You solder all wires according to the Software manual, also, please try to use search to know our recommendations in case of ERROR[001]
Old 04-04-2019, 16:11   #3 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J700H
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Toshiba eMMC 400073
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 1101003430303037330029CCC6CEA2E9
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 400073
Product revision : 0.0
Product serial number : (hex) 29CCC6CE
Manufacturing date : 10/2015
CSD Info
CSD : D07E00320F5903FFFFFFFFE78A4000D1
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 8 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7696384 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : ab400000 bytes
Device sector size : 512 bytes
Partition offset : 507904
Number of sectors : 4308992
Device Manufacturer :samsung
Device Platform :exynos5
Build ID :LMY48B
Display Build ID :LMY48B.J700HXXU1AOGA
Release ID :5.1.1
Device Model :SM-J700H
Device Name :j7e3gxx
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Architecture ABI List :armeabi-v7a,armeabi
Build Description :j7e3gxx-user 5.1.1 LMY48B J700HXXU1AOGA release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/400073_04_04_2019_15_10_26.bin.
Connect successful.
SW: 1.7.5; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: BOTA1 (00004000, 00002000) 4 MB
P03: EFS (00006000, 0000A000) 20 MB
P04: CPEFS (00010000, 00004000) 8 MB
P05: m9kefs1 (00014000, 00002000) 4 MB
P06: m9kefs2 (00016000, 00002000) 4 MB
P07: m9kefs3 (00018000, 00002000) 4 MB
P08: CARRIER (0001A000, 00000800) 1024 KB
P09: PARAM (0001A800, 00004000) 8 MB
P10: BOOT (0001E800, 00010000) 32 MB
P11: RECOVERY (0002E800, 00013000) 38 MB
P12: OTA (00041800, 00004000) 8 MB
P13: CDMA-RADIO (00045800, 00002000) 4 MB
P14: RADIO (00047800, 0002C000) 88 MB
P15: TOMBSTONES (00073800, 00000800) 1024 KB
P16: DNT (00074000, 00000800) 1024 KB
P17: PERSISTENT (00074800, 00000400) 512 KB
P18: PERSDATA (00074C00, 00006000) 12 MB
P19: RESERVED2 (0007AC00, 00001400) 2560 KB
P20: SYSTEM (0007C000, 0041C000) 2104 MB
P21: CACHE (00498000, 00064000) 200 MB
P22: HIDDEN (004FC000, 00014000) 40 MB
P23: USERDATA (00510000, 01848000) 12.14 GB
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J700H_EMMC_AJNB3R.srf".
Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition...
Read/write verification error. Possible reasons: damaged or write protected eMMC.
Disconnected.
Old 04-05-2019, 11:00   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,059
Please, try to repeat Smart Repair operation with disabled options for Write Verification, after post here full Software log.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 04-09-2019, 15:25   #5 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 163
Problem was solved by disabling the Write Verification option, boot repair done.
Page generated in 0.23567 seconds with 7 queries
