12-30-2012, 07:03 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | samsung s5570 strange problem [Solved] i got a samsung galaxy mini ( samsung s5570) dead customer told me that he was playing with custom roms and became dead , it was not going in download mode so repaired its boot with medusa without any problem and then flashed, phone revived but when i switched it off it not started again , it was blinking then i checked it is going to download mode or not , download mode was ok then i flashed with another firmware phone was blinking in white screen after some time when i checked phone was totally dead , i checked its download mode it was also dead so i boot repaired again , i flashed with new gingerbread firmware phone was working well but problem was unknown baseband and no imei , later i came to know that to solve this problem i had to boot repair again so did the same and flashed too and there was imei and baseband ok , but when restarted mannually same blinking problem , please guide me what to do here is link of the same i posted in successfully repaired phones in medusa http://forum.gsmhosting.com/vbb/9055689-post475.html Last edited by Octopus box; 01-02-2013 at 09:53. |
12-31-2012, 10:39 | #2 (permalink) |
Product Supporter Join Date: Oct 2009 Location: Romania, Bucharest
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Yes, strange problem. The solutions is tested a lot of times. Here is another one successfully report: http://forum.gsmhosting.com/vbb/f664...ml#post8992780. Please try to make Erase Full flash and then Write Full flash file from the Support Area (in Advanced Mode). |
The Following User Says Thank You to Octopus box For This Useful Post: |
01-01-2013, 07:17 | #3 (permalink) |
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | yes i did as you said and it works Log started at 12/31/2012 5:29:20 PM ... Welcome to Medusa Box Software version 1.5.9 Selected device model: Samsung GT-S5570 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 203C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.47 V CPU : Qualcomm MSM7227T Core ID : 203C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. ERROR[028]: Target device has been disconnected ... Disconnected Selected device model: Samsung GT-S5570 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 203C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.47 V CPU : Qualcomm MSM7227T Core ID : 203C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. Opening "C:\Program Files\GsmServer\Medusa\SAMSUNG_GTS5570_FullFlash.m f" file... Writting BOOT section. Please wait... Done Writting FIRMWARE section. Please wait... Done after flash i repair imei with micro-box and then again upgraded to 2.3.6 with odin and now phone works perfectly |
