10-15-2018, 11:13 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Samsung SM-G532F Hang on logo repair and FRP erase done Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : H:/Installed Boxes/Medusa/Install/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN16BB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31364242006F8DD63CC4A3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN16BB Product revision : 0.0 Product serial number : (hex) 6F8DD63C Manufacturing date : 12/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer :samsung Device Platform :mt6737t Build ID :MMB29T Display Build ID :MMB29T.G532FXXU1APL1 Release ID :6.0.1 Device Model :SM-G532F Device Name :grandpplteser Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :grandpplteser-user 6.0.1 MMB29T G532FXXU1APL1 release-keys Backup EXT_CSD saved to file H:/Installed Boxes/Medusa/Install/Medusa Pro Software/EXT_CSD Backups/QN16BB_01_10_2018_19_04_39.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 00744000) 3720 MB Backuping FRP data... Opening H:/Installed Boxes/Medusa/Install/Medusa Pro Software/Backups/FRP_0x55400_0x400_01_10_2018_19_04_47.bin file... Reading. Please wait... Done. Repairing from file "H:/Installed Boxes/Medusa/Install/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.SRF". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing lk partition... Done. Writing BOTA1 partition... Done. Writing secro partition... Done. Writing seccfg partition... Done. Writing efuse partition... Done. Writing tee1 partition... Done. Writing BOTA2 partition... Done. Writing EFS partition... Done. Writing PARAM partition... Done. Writing recovery partition... Done. Writing boot partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Writing keystore partition... Done. Writing omekeystore partition... Done. Writing proinfo partition... Done. Writing para partition... Done. Writing PERSISTENT partition... Done. Writing STEADY partition... Done. Smart Repair is successfully complete. SW: 1.6.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : H:/Installed Boxes/Medusa/Install/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN16BB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31364242006F8DD63CC4A3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN16BB Product revision : 0.0 Product serial number : (hex) 6F8DD63C Manufacturing date : 12/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file H:/Installed Boxes/Medusa/Install/Medusa Pro Software/EXT_CSD Backups/QN16BB_01_10_2018_19_07_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 00744000) 3720 MB Backuping FRP data... Opening H:/Installed Boxes/Medusa/Install/Medusa Pro Software/Backups/FRP_0x55400_0x400_01_10_2018_19_07_32.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.7; FW: 1.24. Removing FRP. Please wait... Done. SW: 1.6.7; FW: 1.24. Disconnected. Last edited by Medusa Box; 10-15-2018 at 11:20. |
The Following 2 Users Say Thank You to gsmpointhrp For This Useful Post: |
