Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2014 Location: (pakistan)(chichawatni) Age: 36
Member: 2293727 Status: Offline Sonork: 100.1660528 Thanks Meter: 445 | ![]() ![]() Welcome to Medusa Pro Software version 1.4.2. Started. Reader #0: Broadcom Corp Contacted SmartCard 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Reader #3: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J106H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 90014A4838473474920107B2742CC3D7 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) 7B2742C Manufacturing date : 12/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_19_08_2017_16_00_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.2; FW: 1.20. Erasing. Please wait... Done. SW: 1.4.2; FW: 1.20. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing STEADY partition... Done. Writing persdata partition... Done. Writing CACHE partition... Done. Writing HIDDEN partition... Done. Smart Repair is successfully complete. SW: 1.4.2; FW: 1.20. Disconnected. Last edited by Medusa Box; 08-19-2017 at 13:47. |
The Following 8 Users Say Thank You to shabirahmad22 For This Useful Post: |
![]() | #4 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,336 | Hello. Pinout picture is inside of proper SRF (Smart Repair File). To look at pinout picture, do the following: 1. Run Software. 2. Download SRF "SAMSUNG_SM-J106H_EMMC.srf" from the Support Area via "Download *.srf" button in Software. 3. Select "eMMC" option in Software. 4. Select Samsung SM-J106H in Software list (model will appear in Software list after SFR installation). 5. Press "Pinout" button in Software. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
