01-16-2018, 14:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1886712 Status: Offline Thanks Meter: 53 | SM-N9005 dead boot repair question [Answered] Welcome to Medusa Pro Software version 1.4.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-N9005 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-N9005_EMMC_MB4GC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MBG4GC Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 1501004D4247344743008F00B607900B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MBG4GC Product revision : 0.0 Product serial number : (hex) 8F00B607 Manufacturing date : 09/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 376832 Number of sectors : 4718592 Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/MBG4GC_16_01_2018_18_08_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.7; FW: 1.22. P00: GPT (00000000, 00002000) P01: apnhlos (00002000, 00007800) P02: modem (00009800, 0001CB80) P03: sbl1 (00026380, 00000400) P04: dbi (00026780, 00000040) P05: ddr (000267C0, 00000040) P06: aboot (00026800, 00001000) P07: rpm (00027800, 00000400) P08: tz (00027C00, 00000400) P09: pad (00028000, 00005000) P10: param (0002D000, 00005000) P11: efs (00032000, 00007000) P12: modemst1 (00039000, 00001800) P13: modemst2 (0003A800, 00001800) P14: boot (0003C000, 00005800) P15: recovery (00041800, 00006800) P16: fota (00048000, 00006800) P17: backup (0004E800, 000037EE) P18: fsg (00051FEE, 00001800) P19: fsc (000537EE, 00000002) P20: ssd (000537F0, 00000010) P21: persist (00053800, 00004000) P22: persdata (00057800, 00004800) P23: system (0005C000, 00480000) P24: cache (004DC000, 00096000) P25: hidden (00572000, 00005000) P26: userdata (00577000, 034C6FDF) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-N9005_EMMC_MB4GC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing apnhlos partition... Done. Writing sbl1 partition... Done. Writing dbi partition... Done. Writing ddr partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing boot partition... Done. Smart Repair is successfully complete. SW: 1.4.7; FW: 1.22. Disconnected. Last edited by Medusa Box; 01-16-2018 at 14:33. |
01-16-2018, 14:33 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. The problem can be with version of phone's boot loaders. Boot loaders in SRF (Smart Repair File) "SAMSUNG_SM-N9005_EMMC_MB4GC.srf" may be not compatible (has lower version that should be) with your phone. Try to do "Factory Repair" ("Factory repair" tab in Software) using proper PIT file and latest original Samsung firmware for this device. Post here the result. Use the latest Medusa Pro Software version (https://medusabox.com/eng/download/software). |
The Following User Says Thank You to Medusa Box For This Useful Post: |
01-16-2018, 15:36 | #3 (permalink) |
Member: 1886712 Status: Offline Thanks Meter: 53 | still dead Welcome to Medusa Pro Software version 1.5.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-N9005 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-N9005_EMMC_MB4GC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MBG4GC Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D4247344743008F00B607900B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MBG4GC Product revision : 0.0 Product serial number : (hex) 8F00B607 Manufacturing date : 09/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/MBG4GC_16_01_2018_19_32_30.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: dbi (00026780, 00000040) 32 KB P05: ddr (000267C0, 00000040) 32 KB P06: aboot (00026800, 00001000) 2048 KB P07: rpm (00027800, 00000400) 512 KB P08: tz (00027C00, 00000400) 512 KB P09: pad (00028000, 00005000) 10 MB P10: param (0002D000, 00005000) 10 MB P11: efs (00032000, 00007000) 14 MB P12: modemst1 (00039000, 00001800) 3072 KB P13: modemst2 (0003A800, 00001800) 3072 KB P14: boot (0003C000, 00005800) 11 MB P15: recovery (00041800, 00006800) 13 MB P16: fota (00048000, 00006800) 13 MB P17: backup (0004E800, 000037EE) 6.991 MB P18: fsg (00051FEE, 00001800) 3072 KB P19: fsc (000537EE, 00000002) 1024 b P20: ssd (000537F0, 00000010) 8 KB P21: persist (00053800, 00004000) 8 MB P22: persdata (00057800, 00004800) 9 MB P23: system (0005C000, 005DC000) 3000 MB P24: cache (00638000, 000D7000) 430 MB P25: hidden (0070F000, 00019000) 50 MB P26: userdata (00728000, 03314000) 25.54 GB Selected pit file: E:/Z3X/FLASH FILE/N/N9005/CSB_signed_HLTE_EUR_OPEN_32G_0805.pit Open file "E:/Z3X/FLASH FILE/N/N9005/5.0/BTU/N9005XXUGBOK6_N9005BTUGBOJ1_N9005XXUGBOJ1_HOME.tar .md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition APNHLOS... Done. Writing partition SBL1... Done. Writing partition DBI... Done. Writing partition ABOOT... Done. Writing partition RPM... Done. Writing partition TZ... Done. Writing partition BOOT... Done. Writing is finished. SW: 1.5.2; FW: 1.22. |
