05-20-2022, 05:10 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 152445 Status: Offline Thanks Meter: 16 | Sm-g988b not connect gelo please [Answered] |
05-21-2022, 12:11 | #3 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 646 | Quote:
between chip and isp socket once more try if connection not successful share connection photo and exe photo you will must get result | |
The Following User Says Thank You to saleem5001 For This Useful Post: |
05-21-2022, 17:45 | #4 (permalink) |
Member: 152445 Status: Offline Thanks Meter: 16 | g988b Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Loading firmware. Please wait... Done. Selected UFS interface. Socket detected! Selected PIN - CONNECTOR. Model Settings: Interface : UFS Gear : PWM Gear 1 Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting in ISP mode... (it may take about 10 seconds) Connect unsuccessful. Selected PIN - CONNECTOR. Model Settings: Interface : UFS Gear : PWM Gear 2 Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting in ISP mode... (it may take about 10 seconds) Connect unsuccessful. Selected PIN - CONNECTOR. Model Settings: Interface : UFS Gear : PWM Gear 3 Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting in ISP mode... (it may take about 10 seconds) Connect unsuccessful. Selected PIN - CONNECTOR. Model Settings: Interface : UFS Gear : PWM Gear 4 Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting in ISP mode... (it may take about 10 seconds) Connect unsuccessful. Selected PIN - CONNECTOR. Model Settings: Interface : UFS Gear : HS Gear 1 Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting in ISP mode... (it may take about 10 seconds) Connect unsuccessful. |
05-25-2022, 09:43 | #8 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello Please, explain how did you connect in more details. Namely, the sequence. First, you connected USB and then pressed the ''connect'', or vice versa, first the ''connect'' and then USB? |
05-25-2022, 16:08 | #9 (permalink) |
Member: 152445 Status: Offline Thanks Meter: 16 | I have tried different methods connecting USB first then connect or connect then USB and tried connecting vcc and vccq and still the same problem no connection. with the same connection in other boxes if it detects them |
