ddilshod93 | 07-18-2017 12:27 | SM-T211 Boot repair via eMMC Factory repair Done! SM-T211 Boot repair via eMMC Factory repair Done! :D Code:
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : 10
Connecting...
Device : Samsung eMMC M8G1WA
Page size : 512 B
Block size : 512 B
Block count : 15269888
CID Info
CID : 1501004D3847315741006DE797A5A021
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : M8G1WA
Product revision : 0.0
Product serial number : (hex) 6DE797A5
Manufacturing date : 10/2013
CSD Info
CSD : D02701320F5903FFF6DBFFE18E404029
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.5 (for MMC v4.41)
Erase block size : 512 Kbytes
Boot1 size : 2048 Kbytes
Boot2 size : 2048 Kbytes
RPMB size : 128 Kbytes
Partition config : 01001000
Boot partition enable : Boot partition 1 (Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 2544640 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...Ok
Disk/Image size : d2000000 bytes
Device sector size : 512 bytes
Partition offset : 212992
Number of sectors : 2945024
Device Manufacturer : samsung
Device Platform : mrvl
Build ID : JZO54K
Display Build ID : JZO54K.T211XXAML1
Release ID : 4.1.2
Device Model : SM-T211
Device Name : lt023gxx
Architecture ABI : armeabi-v7a
Architecture ABI2 : armeabi
Build Description : lt023gxx-user 4.1.2 JZO54K T211XXAML1 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M8G1WA_18_07_2017_15_23_55.bin.
Connect successful.
SW: 1.3.9; FW: 1.19.
P00: GPT (00000000, 00002000)
P01: MRD (00002000, 00000800)
P02: MRD_BK (00002800, 00000800)
P03: BOTA0 (00003000, 00002000)
P04: SBL2 (00005000, 00002000)
P05: SBL (00007000, 00002000)
P06: EFS (00009000, 00006000)
P07: PARAM (0000F000, 00004000)
P08: MODEM (00013000, 00006000)
P09: KERNEL (00019000, 00006000)
P10: RECOVERY (0001F000, 00006000)
P11: MISC (00025000, 00005000)
P12: NVM (0002A000, 00008000)
P13: MEP (00032000, 00002000)
P14: SYSTEM (00034000, 002CF000)
P15: CACHE (00303000, 00064000)
P16: HIDDEN (00367000, 00064000)
P17: USER (003CB000, 00AC2000)
Selected pit file: C:/TEMP/T211XXBNI1/LT02.pit
Open file "C:/TEMP/T211XXBNI1/BL_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5".
Open file "C:/TEMP/T211XXBNI1/AP_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5".
Open file "C:/TEMP/T211XXBNI1/CP_T211XXBNI1_2667930_REV00_user_low_ship.tar.md5".
Open file "C:/TEMP/T211XXBNI1/CSC_OXE_T211OXEBNI1_2667930_REV00_user_low_ship.tar.md5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT
Write data verification is enabled.
Writing. Please wait...
Switched to boot area partition 1.
Writing partition PBL... Done.
Switched to user area.
Writing partition SBL2... Done.
Writing partition SBL... Done.
Writing partition PARAM... Done.
Writing partition MODEM... Done.
Writing partition KERNEL... Done.
Writing partition RECOVERY... Done.
Writing partition NVM... Done.
Writing partition CACHE... Done.
Writing partition HIDDEN... Done.
Writing is finished.
Disconnected.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1
Bus speed : 10
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Build ID : JZO54K
Release ID : 4.1.2
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M8G1WA_18_07_2017_15_59_43.bin.
Connect successful.
P01: mrd (00002000, 00000800)
P02: mrd_bk (00002800, 00000800)
P03: bota0 (00003000, 00002000)
P04: sbl2 (00005000, 00002000)
P05: sbl (00007000, 00002000)
P06: efs (00009000, 00006000)
P07: param (0000F000, 00004000)
P08: modem (00013000, 00006000)
P09: kernel (00019000, 00006000)
P10: recovery (0001F000, 00006000)
P11: misc (00025000, 00005000)
P12: nvm (0002A000, 00008000)
P13: mep (00032000, 00002000)
P14: system (00034000, 002CF000)
P15: cache (00303000, 00064000)
P16: hidden (00367000, 00064000)
P17: user (003CB000, 00AC3000)
Disconnected. |
