01-28-2021, 10:46 | #1 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Tajikistan
Member: 2704006 Status: Offline Thanks Meter: 181 | Oppo A5 2020 Reset lock and FRP done Code: Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC hC8aP Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68433861503E0351C8C914B631 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hC8aP Product revision : 0.3 Product serial number : (hex) 51C8C914 Manufacturing date : 11/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_28_01_2021_14_33_00.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.9; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00001000) 2048 KB P04: modemst2 (0000B028, 00001000) 2048 KB P05: opporeserve1 (0000C028, 00004000) 8 MB P06: opporeserve2 (00010028, 00020000) 64 MB P07: opporeserve3 (00030028, 00020000) 64 MB P08: oppo_sec (00050028, 00005000) 10 MB P09: xbl (00060000, 00001C00) 3584 KB P10: xblbak (00061C00, 00001C00) 3584 KB P11: xbl_config (00080000, 00000100) 128 KB P12: xbl_configbak (00080100, 00000100) 128 KB P13: tz (000A0000, 00002000) 4 MB P14: tzbak (000C0000, 00002000) 4 MB P15: rpm (000E0000, 00000400) 512 KB P16: rpmbak (00100000, 00000400) 512 KB P17: hyp (00120000, 00004000) 8 MB P18: hypbak (00140000, 00004000) 8 MB P19: boot (00144000, 00030000) 96 MB P20: bootbak (00174000, 00030000) 96 MB P21: cache (001A4000, 00080000) 256 MB P22: keymaster (00240000, 00000400) 512 KB P23: keymasterbak (00240400, 00000400) 512 KB P24: cmnlib (00240800, 00000400) 512 KB P25: cmnlib64 (00240C00, 00000400) 512 KB P26: cmnlibbak (00241000, 00000400) 512 KB P27: cmnlib64bak (00241400, 00000400) 512 KB P28: mdtpsecapp (00241800, 00002000) 4 MB P29: mdtpsecappbak (00243800, 00002000) 4 MB P30: mdtp (00245800, 00010000) 32 MB P31: mdtpbak (00255800, 00010000) 32 MB P32: modem (00265800, 00080000) 256 MB P33: dsp (002E5800, 00020000) 64 MB P34: dspbak (00305800, 00020000) 64 MB P35: abl (00325800, 00000800) 1024 KB P36: ablbak (00326000, 00000800) 1024 KB P37: ddr (00326800, 00000800) 1024 KB P38: bluetooth (00327000, 00000800) 1024 KB P39: bluetoothbak (00327800, 00000800) 1024 KB P40: ssd (00340000, 00000010) 8 KB P41: dtbo (00340010, 0000C000) 24 MB P42: dtbobak (0034C010, 0000C000) 24 MB P43: recovery (00360000, 00020000) 64 MB P44: recoverybak (00380000, 00020000) 64 MB P45: imagefv (003A0000, 00001000) 2048 KB P46: imagefvbak (003A1000, 00001000) 2048 KB P47: uefisecapp (003A2000, 00001000) 2048 KB P48: uefisecappbak (003A3000, 00001000) 2048 KB P49: persist (003A4000, 00010000) 32 MB P50: metadata (003B4000, 00008000) 16 MB P51: misc (003BC000, 00000800) 1024 KB P52: keystore (003BC800, 00000400) 512 KB P53: devcfg (003BCC00, 00000100) 128 KB P54: devcfgbak (003BCD00, 00000100) 128 KB P55: qupfw (003BCE00, 000000A0) 80 KB P56: qupfwbak (003BCEA0, 000000A0) 80 KB P57: frp (003BCF40, 00000400) 512 KB P58: rawdump (003BD340, 00040000) 128 MB P59: devinfo (00400000, 00000008) 4 KB P60: dip (00400008, 00000800) 1024 KB P61: apdp (00420000, 00000200) 256 KB P62: spunvm (00420200, 00004000) 8 MB P63: splash (00424200, 00010520) 32.64 MB P64: limits (00440000, 00000008) 4 KB P65: toolsfv (00440008, 00000800) 1024 KB P66: logfs (00460000, 00004000) 8 MB P67: cateloader (00464000, 00001000) 2048 KB P68: logdump (00465000, 00020000) 64 MB P69: vbmeta (004A0000, 00000080) 64 KB P70: vbmetabak (004A0080, 00000080) 64 KB P71: storsec (004A0100, 00000100) 128 KB P72: multiimgoem (004A0200, 00000040) 32 KB P73: multiimgqti (004A0240, 00000040) 32 KB P74: secdata (004A0280, 00000032) 25 KB P75: catefv (004A02B8, 00000400) 512 KB P76: catecontentfv (004A06B8, 00000800) 1024 KB P77: uefivarstore (004A0EB8, 00000400) 512 KB P78: DRIVER (004C0000, 00010000) 32 MB P79: fsg (004E0000, 00001000) 2048 KB P80: fsc (00500000, 00000100) 128 KB P81: system (00500100, 00C7E000) 6.246 GB P82: vendor (0117E100, 00322000) 1604 MB P83: odm (014A0100, 00080000) 256 MB P84: userdata (01520100, 05F5BEDF) 47.68 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_modemst1_0xa028_0x1000_28_01_2021_14_33_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.9; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_modemst2_0xb028_0x1000_28_01_2021_14_33_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.9; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_fsg_0x4e0000_0x1000_28_01_2021_14_33_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.9; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 5243136 Number of sectors : 13099008 Build ID : QKQ1.200209.002 Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi --------------------------------------------------------------- Reset operation finished Disconnected. |
The Following 4 Users Say Thank You to bestsoft.tj For This Useful Post: |
