Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-05-2018, 09:14   #1 (permalink)
Member: 772384
Thanks Meter: 40
H790 boot repair question [Answered]
dear my support team I have h790 with only qualcom driver ...tried smart repair but no download mode ?
Welcome to Medusa Pro Software version 1.6.0.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Reader #1: FT SCR2000 0
Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(EXT_CSD_LG H790) TOSHIBA EMMC 016G72.BIN.
Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(LG H790) TOSHIBA EMMC 016G72_FULL.RAR.
Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(LIVE_LOG LG H790) TOSHIBA EMMC 016G72.TXT.
Downloaded and installed file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : H790
SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Brand : LG
Model : H790
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Brand : LG
Model : H790
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Toshiba eMMC 032G74
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 110100303332473734009941B9C4720D
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 032G74
Product revision : 0.0
Product serial number : (hex) 9941B9C4
Manufacturing date : 07/2015
CSD Info
CSD : D02700320F5903FFFFFFFFE78640009B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15269888 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : 47c00000 bytes
Device sector size : 512 bytes
Partition offset : 1458176
Number of sectors : 6291456
Device Manufacturer :google
Device Platform :msm8992
Build ID :OPR4.170623.006
Display Build ID :OPR4.170623.006
Release ID :8.0.0
Device Model :Nexus 5X
Device Name :bullhead
Architecture ABI :arm64-v8a
Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi
Build Description :bullhead-user 8.0.0 OPR4.170623.006 4286358 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_05_06_2018_23_49_11.bin.
Connect successful.
SW: 1.6.0; FW: 1.23.
P00: GPT (00000000, 00004000) 8 MB
P01: modem (00004000, 0002B000) 86 MB
P02: pmic (00030000, 00000400) 512 KB
P03: sbl1 (00030400, 00000800) 1024 KB
P04: tz (00030C00, 00000800) 1024 KB
P05: sdi (00031400, 00000400) 512 KB
P06: hyp (00031800, 00000400) 512 KB
P07: rpm (00031C00, 00000400) 512 KB
P08: aboot (00032000, 00001000) 2048 KB
P09: sbl1bak (00033000, 00000800) 1024 KB
P10: pmicbak (00033800, 00000400) 512 KB
P11: tzbak (00033C00, 00000800) 1024 KB
P12: hypbak (00034400, 00000400) 512 KB
P13: rpmbak (00034800, 00000400) 512 KB
P14: abootbak (00034C00, 00001000) 2048 KB
P15: limits (00035C00, 00000400) 512 KB
P16: config (00036000, 00000400) 512 KB
P17: apdp (00036400, 00000400) 512 KB
P18: msadp (00036800, 00000400) 512 KB
P19: dpo (00036C00, 00000400) 512 KB
P20: fsc (00037000, 00000400) 512 KB
P21: ssd (00037400, 00000400) 512 KB
P22: sec (00037800, 00000400) 512 KB
P23: misc (00037C00, 00008000) 16 MB
P24: persist (0003FC00, 00010000) 32 MB
P25: modemst1 (0004FC00, 00000C00) 1536 KB
P26: modemst2 (00050800, 00000C00) 1536 KB
P27: fsg (00051400, 00000C00) 1536 KB
P28: DDR (00052000, 00001000) 2048 KB
P29: imgdata (00053000, 00001800) 3072 KB
P30: metadata (00054800, 00008000) 16 MB
P31: laf (0005C800, 00018000) 48 MB
P32: keymaster (00074800, 00000400) 512 KB
P33: cmnlib (00074C00, 00000400) 512 KB
P34: keymasterbak (00075000, 00000400) 512 KB
P35: cmnlibbak (00075400, 00000400) 512 KB
P36: oem (00078000, 00020000) 64 MB
P37: boot (00098000, 00010000) 32 MB
P38: recovery (000A8000, 00010000) 32 MB
P39: vendor (000B8000, 0007C000) 248 MB
P40: cache (00134000, 00030000) 96 MB
P41: system (00164000, 00600000) 3072 MB
P42: persistent (00764000, 00000400) 512 KB
P43: devinfo (00768000, 00000400) 512 KB
P44: keystore (00768400, 00000400) 512 KB
P45: userdata (0076C000, 032D1FDC) 25.41 GB
P46: grow (03A3DFDC, 00000003) 1536 b
Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf".
Write data verification is enabled.
Writing GPT partition... Done.
Writing modem partition... Done.
Writing pmic partition... Done.
Writing sbl1 partition... Done.
Writing tz partition... Done.
Writing sdi partition... Done.
Writing hyp partition... Done.
Writing rpm partition... Done.
Writing aboot partition... Done.
Writing limits partition... Done.
Writing config partition... Done.
Writing apdp partition... Done.
Writing msadp partition... Done.
Writing dpo partition... Done.
Writing fsc partition... Done.
Writing ssd partition... Done.
Writing sec partition... Done.
Writing misc partition... Done.
Writing persist partition... Done.
Writing modemst1 partition... Done.
Writing modemst2 partition... Done.
Writing fsg partition... Done.
Writing DDR partition... Done.
Writing imgdata partition... Done.
Writing metadata partition... Done.
Writing laf partition... Done.
Writing keymaster partition... Done.
Writing cmnlib partition... Done.
Writing keymasterbak partition... Done.
Writing cmnlibbak partition... Done.
Writing oem partition... Done.
Writing boot partition... Done.
Writing recovery partition... Done.
Writing persistent partition... Done.
Writing devinfo partition... Done.
Writing keystore partition... Done.
Smart Repair is successfully complete.
there is zip file emmc bin should i write to the phone ? please advice me
Old 06-05-2018, 14:07   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello
Does the device goes into Download (Emergency) Mode after "Smart Repair" operation? If no, unpack full flash and try to write it. Also You can try to do "Factory Repair" using the latest available original firmware for this device model.
Page generated in 0.17215 seconds with 8 queries
