02-07-2019, 17:37 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | G532M ERROR[007]: Command fail. [Answered] How Can I solve this problem below? Read Dump is working well I need write flash (In odin3 i have repartion error) Welcome to Octoplus Pro JTAG Software version 1.7.4. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532M SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q316BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333136424200CE68A8D7643B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q316BB Product revision : 0.0 Product serial number : (hex) CE68A8D7 Manufacturing date : 06/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q316BB_07_02_2019_09_46_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.4; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 0160E000) 11.03 GB Erasing. Please wait... error! ERROR[007]: Command fail. |
02-07-2019, 18:36 | #2 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Welcome to Octoplus Pro JTAG Software version . Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532M SRF : C:/Users/GilsonVeloso/Desktop/Ligtel/SAMSUNG_SM-G532M_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q316BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333136424200CE68A8D7643B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q316BB Product revision : 0.0 Product serial number : (hex) CE68A8D7 Manufacturing date : 06/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer :samsung Device Platform :mt6737t Build ID :MMB29T Display Build ID :MMB29T.G532MTVJU1ARL1 Release ID :6.0.1 Device Model :SM-G532MT Device Name :grandppltedtvvj Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :grandppltedtvvj-user 6.0.1 MMB29T G532MTVJU1ARL1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q316BB_07_02_2019_15_35_24.bin. Connect successful. --------------------------------------------------------------- SW: ; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 0160E000) 11.03 GB Repairing from file "C:/Users/GilsonVeloso/Desktop/Ligtel/SAMSUNG_SM-G532M_EMMC.SRF". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. |
02-07-2019, 18:46 | #3 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Save to C:/Users/GilsonVeloso/Desktop/Ligtel/g532m dump/Samsung eMMC Q316BB_qui fev 7 2019_15_40_50.mpt file... Reading partition GPT... Done. Reading partition BOTA0... Done. Reading partition nvram... Done. Reading partition lk... Done. Reading partition BOTA1... Done. Reading partition secro... Done. Reading partition seccfg... Done. Reading partition efuse... Done. Reading partition tee1... Done. Reading partition BOTA2... Done. Reading partition EFS... Done. Reading partition nvdata... Done. Reading partition PARAM... Done. Reading partition recovery... Done. Reading partition boot... Done. Reading partition md1img... Done. Reading partition md1dsp... Done. Reading partition keystore... Done. Reading partition omekeystore... Done. Reading partition proinfo... Done. Reading partition para... Done. Reading partition PERSISTENT... Done. Reading partition STEADY... Done. Reading partition protect1... Done. Reading partition protect2... Done. Reading partition RESERVE2... Done. Reading partition hidden... Done. Reading is finished. SW: ; FW: 1.24. Partition table has been found on device. EXT_CSD saved to file C:/Users/GilsonVeloso/Desktop/Ligtel/g532m dump/EXT_CSD_07_02_2019_15_45_48.bin. |
02-08-2019, 12:25 | #7 (permalink) | |
Member: 1789551 Status: Offline Thanks Meter: 90 | Quote:
How to solve this Error[007] ? I want write emmc for medusa. | |
02-08-2019, 13:09 | #8 (permalink) | |
Selected BOOT file: E:\FIRMAWARE SAMSUNG\G532MT-J2 PRIME\SM- G532MT_1_20181207154340_5nc78q3ztm_fac.zip.enc4sm \BL_G532MTVJU1ARL1_CL13785164_QB20945894_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected AP file: E:\FIRMAWARE SAMSUNG\G532MT-J2 PRIME\SM- G532MT_1_20181207154340_5nc78q3ztm_fac.zip.enc4sm \AP_G532MTVJU1ARL1_CL13785164_QB20945894_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected CP file: E:\FIRMAWARE SAMSUNG\G532MT-J2 PRIME\SM- G532MT_1_20181207154340_5nc78q3ztm_fac.zip.enc4sm \CP_G532MTVJU1ARG1_CL13785164_QB19009532_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected CSC file: E:\FIRMAWARE SAMSUNG\G532MT-J2 PRIME\SM- G532MT_1_20181207154340_5nc78q3ztm_fac.zip.enc4sm \CSC_ZTO_G532MTZTO1ARI1_CL14242197_QB19939382_REV0 0 _user_low_ship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G532M into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Escrevendo a secção BOOTLOADER... A secção BOOTLOADER foi escrita com êxito Escrevendo a secção lk... A secção lk foi escrita com êxito Escrevendo a secção PARAM... A secção PARAM foi escrita com êxito Writing Firmware Failed Performed by 2.7.7.4 Software version. | |
02-08-2019, 14:30 | #9 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | ERROR[007]: Command fail." usually arises when connection is not stable. If You are sure You have soldered wires good and as short as possible, try to connect Box to another PC USB port, don't use USB hubs, this is important. Try to use another USB A-B cable to connect Box to PC. Please, don't forget to use forum search button. Unfortunately, Medusa Pro Software doesn't have solution to solve issue with flashing. It was developed only for "boot repair "operations. As You can see your device are working properly (You have possibility to enter into DM). |
