06-29-2020, 18:13 | #1066 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Code: Selected PIN - CONNECTOR socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-E500H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-E500H_EMMC_Q316MB.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q316MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331364D42000250CA22127D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q316MB Product revision : 0.0 Product serial number : (hex) 250CA22 Manufacturing date : 01/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q316MB_29_06_2020_18_35_46.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 2.00. Whole proccess time: . P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001CB80) 57.44 MB P03: sbl1 (00026380, 00000400) 512 KB P04: ddr (00026780, 00000040) 32 KB P05: aboot (000267C0, 00001000) 2048 KB P06: rpm (000277C0, 00000400) 512 KB P07: qsee (00027BC0, 00000400) 512 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00002802) 5.001 MB P19: backup (0004E802, 000037EE) 6.991 MB P20: fsc (00051FF0, 00001800) 3072 KB P21: ssd (000537F0, 00000010) 8 KB P22: persist (00053800, 00004000) 8 MB P23: persdata (00057800, 00004800) 9 MB P24: system (0005C000, 004B0000) 2400 MB P25: cache (0050C000, 00064000) 200 MB P26: hidden (00570000, 0001E000) 60 MB P27: userdata (0058E000, 017CBFD8) 11.9 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q316MB_fsg_0x283c0_0x1800_29_06_2020_18_35_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 2.00. Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q316MB_efs_0x34000_0x7000_29_06_2020_18_35_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.1.1; FW: 2.00. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q316MB_modemst1_0x3b000_0x1800_29_06_2020_18_35_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q316MB_modemst2_0x3c800_0x1800_29_06_2020_18_35_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 376832 Number of sectors : 4915200 Device Manufacturer : samsung Device Platform : msm8916 Build ID : LMY47X Display Build ID : LMY47X.E500HXXS1BQD2 Release ID : 5.1.1 Device Model : SM-E500H Device Name : e53gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : e53gxx-user 5.1.1 LMY47X E500HXXS1BQD2 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 52. Parsing device... Image size in bytes: 2873098240 Volume system. Type: GPT. Partitions: 32. Total: 30769112 sectors. Canceling process... Warning: Unknown file system type. Details: Sector offset: 156544, Partition Type: sbl1 Parse finished. Whole proccess time: 51 minutes 0 seconds : 20 ms. Start extracting file userdata/data/com.android.providers.telephony/databases/mmssms.db . With index: 2 Extracted file. Whole proccess time: 1 seconds : 0 ms. Start extracting file userdata/data/com.android.providers.contacts/databases/contacts2.db . With index: 2 Extracted file. Whole proccess time: 4 seconds : 0 ms. Start extracting folder userdata/media/0/DCIM . Size: 4096 Extracted folder. Whole proccess time: 14 minutes 0 seconds : 49 ms. Start extracting folder userdata/media/0/Pictures . Size: 4096 Extracted folder. Whole proccess time: 9 seconds : 0 ms. Start extracting folder userdata/media/0/viber . Size: 4096Canceling process... Whole proccess time: 6 minutes 0 seconds : 9 ms. Start extracting folder userdata/media/0/viber/media/Viber Images . Size: 28672 Extracted folder. Whole proccess time: 11 minutes 0 seconds : 7 ms. |
07-14-2020, 18:26 | #1067 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | Programming KMQE60013M-B318 for Xiaomi Redmi 5A (riva) successfully done using Medusa Pro II with BGA221 socket. First connect: Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203AA74685215BD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) AA746852 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_14_07_2020_19_10_29.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 62630. Code: Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.1.1; FW: 2.00. Disconnected. Code: Smart report info: Hash code: 0000000000000000000000000000000000000000000000000000000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 DEVICE_LIFE_TIME_EST_TYP_B : 20% - 30% device life time used DEVICE_LIFE_TIME_EST_TYP_A : 20% - 30% device life time used PRE_EOL_INFO : Normal SW: 2.1.1; FW: 2.00. Code: Flash geometry successfully changed. Boot1, Boot2 size changed to 4 MB. RPMB size changed to 4 MB. Disconnected. Code: Writing EXT_CSD succesfully complete! Disconnected. Code: Repairing from file "C:/1/!medusaRedmi5A(Riva)/Xiaomi_Redmi 5a_SRF/Xiaomi_Redmi 5a.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing sbl1 partition... Done. Writing sbl1bak partition... Done. Writing rpm partition... Done. Writing rpmbak partition... Done. Writing tz partition... Done. Writing tzbak partition... Done. Writing devcfg partition... Done. Writing devcfgbak partition... Done. Writing dsp partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing DDR partition... Done. Writing fsg partition... Done. Writing sec partition... Done. Writing splash partition... Done. Writing aboot partition... Done. Writing abootbak partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing devinfo partition... Done. Writing persist partition... Done. Writing misc partition... Done. Writing keystore partition... Done. Writing config partition... Done. Writing oem partition... Done. Writing limits partition... Done. Writing mota partition... Done. Writing dip partition... Done. Writing mdtp partition... Done. Writing syscfg partition... Done. Writing mcfg partition... Done. Writing lksecapp partition... Done. Writing lksecappbak partition... Done. Writing cmnlib partition... Done. Writing cmnlibbak partition... Done. Writing cmnlib64 partition... Done. Writing cmnlib64bak partition... Done. Writing keymaster partition... Done. Writing keymasterbak partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Smart Repair is successfully complete. SW: 2.1.1; FW: 2.00. Disconnected. Code: Selected file: C:/1/riva_global_images_V10.1.2.0.OCKMIFI_20181210.0000.00_8.1_global/images/rawprogram0.xml. Selected file: C:/1/riva_global_images_V10.1.2.0.OCKMIFI_20181210.0000.00_8.1_global/images/patch0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. #grenWriting. Please wait... Write data verification is enabled. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition devcfg... Done. Writing partition devcfgbak... Done. Writing partition dsp... Done. Writing partition splash... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition system... Done. Writing partition cache... Done. Writing partition cmnlib... Done. Writing partition cmnlibbak... Done. Writing partition keymaster... Done. Writing partition keymasterbak... Done. Writing partition cust... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 2.1.1; FW: 2.00. Disconnected. Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Xiaomi Model : Redmi 5A SRF : C:/1/!medusaRedmi5A(Riva)/Xiaomi_Redmi 5a_SRF/Xiaomi_Redmi 5a.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4203AA74685215BD Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.3 Product serial number : (hex) AA746852 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_14_07_2020_20_12_51.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 2.00. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 0002A000) 84 MB P02: fsc (00060000, 00000002) 1024 b P03: ssd (00060002, 00000010) 8 KB P04: sbl1 (00060012, 00000400) 512 KB P05: sbl1bak (00060412, 00000400) 512 KB P06: rpm (00060812, 00000400) 512 KB P07: rpmbak (00060C12, 00000400) 512 KB P08: tz (00061012, 00001000) 2048 KB P09: tzbak (00062012, 00001000) 2048 KB P10: devcfg (00063012, 00000200) 256 KB P11: devcfgbak (00063212, 00000200) 256 KB P12: dsp (00063412, 00008000) 16 MB P13: modemst1 (0006B412, 00002000) 4 MB P14: modemst2 (0006D412, 00002000) 4 MB P15: DDR (00080000, 00000040) 32 KB P16: fsg (00080040, 00002000) 4 MB P17: sec (00082040, 00000020) 16 KB P18: splash (000A0000, 0000A000) 20 MB P19: aboot (000C0000, 00000800) 1024 KB P20: abootbak (000C0800, 00000800) 1024 KB P21: boot (000C1000, 00020000) 64 MB P22: recovery (000E1000, 00020000) 64 MB P23: devinfo (00101000, 00000800) 1024 KB P24: system (00101800, 00600000) 3072 MB P25: cache (00720000, 00080000) 256 MB P26: persist (007A0000, 00010000) 32 MB P27: misc (007B0000, 00000800) 1024 KB P28: keystore (007B0800, 00000400) 512 KB P29: config (007B0C00, 00000040) 32 KB P30: oem (007B0C40, 00020000) 64 MB P31: limits (007E0000, 00000040) 32 KB P32: mota (00800000, 00000400) 512 KB P33: dip (00800400, 00000800) 1024 KB P34: mdtp (00800C00, 00010000) 32 MB P35: syscfg (00810C00, 00000400) 512 KB P36: mcfg (00811000, 00002000) 4 MB P37: lksecapp (00820000, 00000100) 128 KB P38: lksecappbak (00820100, 00000100) 128 KB P39: cmnlib (00820200, 00000200) 256 KB P40: cmnlibbak (00820400, 00000200) 256 KB P41: cmnlib64 (00820600, 00000200) 256 KB P42: cmnlib64bak (00820800, 00000200) 256 KB P43: keymaster (00820A00, 00000200) 256 KB P44: keymasterbak (00820C00, 00000200) 256 KB P45: apdp (00840000, 00000200) 256 KB P46: msadp (00840200, 00000200) 256 KB P47: dpo (00840400, 00000010) 8 KB P48: cust (00860000, 00100000) 512 MB P49: userdata (00960000, 00000000) 0 b Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_modemst1_0x6b412_0x2000_14_07_2020_20_12_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_modemst2_0x6d412_0x2000_14_07_2020_20_12_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 2.00. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_fsg_0x80040_0x2000_14_07_2020_20_12_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.1; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1054720 Number of sectors : 6291456 Device Manufacturer : Xiaomi Device Platform : msm8937 Build ID : OPM1.171019.026 Display Build ID : CUSTOMER_VERSION_riva Release ID : 8.1.0 Device Model : Redmi 5A Device Name : riva Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : riva-user 8.1.0 OPM1.171019.026 V10.1.2.0.OCKMIFI release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 62630. |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
09-10-2020, 12:28 | #1068 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | Repair Huawei G620S-L01 successfully done: Code: Model Settings: Interface : USB Brand : Huawei Model : G620S-L01 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_G620S-L01_USB.srf Core : Qualcomm MSM8916 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_007050E1 Core : Qualcomm MSM8916 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) Connect successful. --------------------------------------------------------------- SW: 2.1.2; FW: . P00: GPT (00000000, 00004400) 17 KB P01: sbl1 (00004400, 00080000) 512 KB P02: hyp (00084400, 00080000) 512 KB P03: sec (00400000, 00008000) 32 KB P04: DDR (00408000, 00008000) 32 KB P05: rpm (00800000, 00080000) 512 KB P06: tz (00880000, 00080000) 512 KB P07: aboot (00900000, 004F0000) 4.938 MB P08: pad (00DF0000, 00100000) 1024 KB P09: oeminfo (00EF0000, 04000000) 64 MB P10: modemst1 (04EF0000, 00400000) 4 MB P11: modemst2 (052F0000, 00400000) 4 MB P12: modem (05800000, 06000000) 96 MB P13: fsg (0B800000, 00400000) 4 MB P14: fsc (0BC00000, 00200000) 2048 KB P15: ssd (0BE00000, 00200000) 2048 KB P16: log (0C000000, 04000000) 64 MB P17: persist (10000000, 02000000) 32 MB P18: boot (12000000, 01400000) 20 MB P19: recovery (13400000, 01800000) 24 MB P20: cust (14C00000, 30000000) 768 MB P21: cache (44C00000, 10000000) 256 MB P22: misc (54C00000, 00400000) 4 MB P23: system (55000000, 70000000) 1792 MB P24: userdata (C5000000, 10CFFBE00) 4.203 GB Backuping oeminfo partition... Opening C:/Program Files/Medusa Pro Software/Backups/_oeminfo_0x7780_0x20000_10_09_2020_14_18_31.bin file... Reading. Please wait... Done. Elapsed time 00:00:10 SW: 2.1.2; FW: . Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst1_0x27780_0x2000_10_09_2020_14_18_31.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.2; FW: . Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst2_0x29780_0x2000_10_09_2020_14_18_31.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.2; FW: . Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/_fsg_0x5c000_0x2000_10_09_2020_14_18_31.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.2; FW: . Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_G620S-L01_USB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing hyp partition... Done. Writing sec partition... Done. Writing DDR partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing aboot partition... Done. Writing pad partition... Done. Writing oeminfo partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing modem partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing log partition... Done. Writing persist partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing misc partition... Done. Smart Repair is successfully complete. SW: 2.1.2; FW: . Disconnected. |
09-10-2020, 15:25 | #1069 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | Repair other Huawei G620S-L01 by writing fullflash from support successfully done: Code: Model Settings: Interface : USB Brand : Huawei Model : G620S-L01 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_G620S-L01_USB.srf Core : Qualcomm MSM8916 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_007050E1 Core : Qualcomm MSM8916 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) Connect successful. --------------------------------------------------------------- SW: 2.1.2; FW: . P00: GPT (00000000, 00004400) 17 KB P01: sbl1 (00004400, 00080000) 512 KB P02: hyp (00084400, 00080000) 512 KB P03: sec (00400000, 00008000) 32 KB P04: DDR (00408000, 00008000) 32 KB P05: rpm (00800000, 00080000) 512 KB P06: tz (00880000, 00080000) 512 KB P07: aboot (00900000, 004F0000) 4.938 MB P08: pad (00DF0000, 00100000) 1024 KB --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- Opening C:/1/!g620s-l01/full/(Huawei G620S-L01) CoreID_007050E1_FULL.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 2.1.2; FW: . Disconnected. |
09-25-2020, 10:07 | #1070 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | cph1911 Connecting... Device : Hynix eMMC hDEaP3 Page size : 512 B Block size : 512 B Block count : 244285440 Size : 116.48 GB (119280.00 MB) --------------------------------------------------------------- CID Info CID : 90014A684445615033032F2A36E05647 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hDEaP3 Product revision : 0.3 Product serial number : (hex) 2F2A36E0 Manufacturing date : 05/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 40714240 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_21_09_2020_09_22_10.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00020000) 64 MB P03: para (00020840, 00000400) 512 KB P04: opporeserve1 (00020C40, 00004000) 8 MB P05: opporeserve2 (00024C40, 00020000) 64 MB P06: opporeserve3 (00044C40, 00020000) 64 MB P07: oppo_custom (00064C40, 00000800) 1024 KB P08: expdb (00065440, 0000A000) 20 MB P09: frp (0006F440, 00000800) 1024 KB P10: nvcfg (0006FC40, 00010000) 32 MB P11: nvdata (0007FC40, 00020000) 64 MB P12: metadata (0009FC40, 00010000) 32 MB P13: protect1 (000AFC40, 00004000) 8 MB P14: protect2 (000B3C40, 000043C0) 8.469 MB P15: seccfg (000B8000, 00004000) 8 MB P16: persist (000BC000, 00018000) 48 MB P17: sec1 (000D4000, 00001000) 2048 KB P18: proinfo (000D5000, 00001800) 3072 KB P19: md1img (000D6800, 00032000) 100 MB P20: spmfw (00108800, 00000800) 1024 KB P21: scp1 (00109000, 00003000) 6 MB P22: scp2 (0010C000, 00003000) 6 MB P23: sspm_1 (0010F000, 00000800) 1024 KB P24: sspm_2 (0010F800, 00000800) 1024 KB P25: cam_vpu1 (00110000, 00007800) 15 MB P26: cam_vpu2 (00117800, 00007800) 15 MB P27: cam_vpu3 (0011F000, 00007800) 15 MB P28: gz1 (00126800, 00008000) 16 MB P29: gz2 (0012E800, 00008000) 16 MB P30: nvram (00136800, 00020000) 64 MB P31: lk (00156800, 00002800) 5 MB P32: lk2 (00159000, 00002800) 5 MB P33: boot (0015B800, 00010000) 32 MB P34: logo (0016B800, 00008000) 16 MB P35: dtbo (00173800, 00008000) 16 MB P36: tee1 (0017B800, 00002800) 5 MB P37: tee2 (0017E000, 00006000) 12 MB P38: odm (00184000, 00080000) 256 MB P39: vendor (00204000, 00218000) 1072 MB P40: system (0041C000, 00A68000) 5.203 GB P41: cache (00E84000, 000D8000) 432 MB P42: userdata (00F5C000, 0D97E7DF) 108.7 GB P43: otp (0E8DA7DF, 00015800) 43 MB P44: flashinfo (0E8EFFDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hDEaP3_nvdata_0x7fc40_0x20000_21_09_2020_09_22_10. bin file... Reading. Please wait... Done. Elapsed time 00:00:47 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 1f000000 bytes Device sector size : 512 bytes Partition offset : 4308992 Number of sectors : 10911744 Build ID : QP1A.190711.020 Display Build ID : QP1A.190711.020 release-keys Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : full_oppo6771-user 10 QP1A.190711.020 d382deafd7252416 release-keys ---------------------------------------------------------------Repairing from file "D:/hÆ°áŧng dášŦn box/medusa/cap nhat/OPPO_F11 Pro_CPH1969_RESET_ISWrite data verification is enabled. Writing para partition... Done. Writing frp partition... Done. Smart Repair is successfully complete. SW: 2.1.1; FW: 1.24. Disconnected. |
The Following User Says Thank You to ngocdiemmobile For This Useful Post: |
09-26-2020, 17:00 | #1071 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: ALGERIA Age: 42
Member: 135661 Status: Offline Thanks Meter: 92 | CPH2015 OPPO A31 reset done Quote:
The Following User Says Thank You to zaki_barika For This Useful Post: |
10-19-2020, 19:43 | #1073 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | Condor P6 pro (PGN518) dead boot repaire done before repaire emmc error detected : Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 4 bits Bus speed : 12.5 MHz Full speed mode! Connecting... Device : Samsung eMMC Q823MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100513832334D4200C61DC2EC33A7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q823MB Product revision : 0.0 Product serial number : (hex) C61DC2EC Manufacturing date : 03/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q823MB_19_10_2020_19_16_58.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 2.00. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: nvram (00001C00, 00002800) 5 MB P03: protect1 (00004400, 00005000) 10 MB P04: protect2 (00009400, 00005000) 10 MB P05: seccfg (0000E400, 00000200) 256 KB P06: lk (0000E600, 00000300) 384 KB P07: boot (0000E900, 00008000) 16 MB P08: recovery (00016900, 00008000) 16 MB P09: para (0001E900, 00000400) 512 KB P10: logo (0001ED00, 00004000) 8 MB P11: expdb (00022D00, 00005000) 10 MB P12: frp (00027D00, 00000800) 1024 KB P13: nvdata (00028500, 00010000) 32 MB P14: metadata (00038500, 00013B00) 39.38 MB P15: oemkeystore (0004C000, 00001000) 2048 KB P16: secro (0004D000, 00003000) 6 MB P17: keystore (00050000, 00004000) 8 MB P18: system (00054000, 00468000) 2256 MB P19: cache (004BC000, 00080000) 256 MB P20: userdata (0053C000, 017DAC00) 11.93 GB P21: flashinfo (01D16C00, 00008000) 16 MB ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 344064 Number of sectors : 4620288 Device Manufacturer : condor Device Platform : mt6580 Build ID : MRA58K Display Build ID : PGN518 Release ID : 6.0 Device Model : PGN518 Device Name : PGN518 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : full_gionee6580_we_m-user 6.0 MRA58K 1474889623 release-keys ---------------------------------------------------------------RPMB: Authentication Key not yet programmed. --------------------------------------------------------------- Selected scatter file: E:/CONDOR/P6_Pro [PGN518]/P6 PRO BLUE BACK UP/MT6580__condor__PGN518__PGN518__6.0__WBW5616AC_0301_T8238/MT6580_Android_scatter.txt. Scatter file type 2. Opened input file: E:/CONDOR/P6_Pro [PGN518]/P6 PRO BLUE BACK UP/MT6580__condor__PGN518__PGN518__6.0__WBW5616AC_0301_T8238/preloader_gionee6580_we_m.bin Found 4 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : Q823MB eMMC CID : 150100513832334D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : Q72SMB eMMC CID : 150100513732534D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QE13MB eMMC CID : 150100514531334D42 eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : HAG4a2 eMMC CID : 90014A484147346132 Writing. Please wait... Writing MBR... ERROR[012]: Write error. At sector 0. Disconnected. emmc factory format Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... Device : Samsung eMMC Q823MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100513832334D4200C61DC2EC33A7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q823MB Product revision : 0.0 Product serial number : (hex) C61DC2EC Manufacturing date : 03/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q823MB_19_10_2020_19_17_54.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 2.00. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: nvram (00001C00, 00002800) 5 MB P03: protect1 (00004400, 00005000) 10 MB P04: protect2 (00009400, 00005000) 10 MB P05: seccfg (0000E400, 00000200) 256 KB P06: lk (0000E600, 00000300) 384 KB P07: boot (0000E900, 00008000) 16 MB P08: recovery (00016900, 00008000) 16 MB P09: para (0001E900, 00000400) 512 KB P10: logo (0001ED00, 00004000) 8 MB P11: expdb (00022D00, 00005000) 10 MB P12: frp (00027D00, 00000800) 1024 KB P13: nvdata (00028500, 00010000) 32 MB P14: metadata (00038500, 00013B00) 39.38 MB P15: oemkeystore (0004C000, 00001000) 2048 KB P16: secro (0004D000, 00003000) 6 MB P17: keystore (00050000, 00004000) 8 MB P18: system (00054000, 00468000) 2256 MB P19: cache (004BC000, 00080000) 256 MB P20: userdata (0053C000, 017DAC00) 11.93 GB P21: flashinfo (01D16C00, 00008000) 16 MB ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 344064 Number of sectors : 4620288 Device Manufacturer : condor Device Platform : mt6580 Build ID : MRA58K Display Build ID : PGN518 Release ID : 6.0 Device Model : PGN518 Device Name : PGN518 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : full_gionee6580_we_m-user 6.0 MRA58K 1474889623 release-keys ---------------------------------------------------------------RPMB: Authentication Key not yet programmed. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.1.4; FW: 2.00. Disconnected. Code: Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... Device : Samsung eMMC Q823MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100513832334D4200C61DC2EC33A7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q823MB Product revision : 0.0 Product serial number : (hex) C61DC2EC Manufacturing date : 03/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF92404009 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 5087232 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q823MB_19_10_2020_19_18_09.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------RPMB: Authentication Key not yet programmed. RPMB: Authentication Key not yet programmed. Flash geometry successfully changed. Boot1, Boot2 size changed to 4 MB. RPMB size changed to 4 MB.. Disconnected. Code: Selected scatter file: E:/CONDOR/P6_Pro [PGN518]/P6 PRO BLUE BACK UP/MT6580__condor__PGN518__PGN518__6.0__WBW5616AC_0301_T8238/MT6580_Android_scatter.txt. Scatter file type 2. Opened input file: E:/CONDOR/P6_Pro [PGN518]/P6 PRO BLUE BACK UP/MT6580__condor__PGN518__PGN518__6.0__WBW5616AC_0301_T8238/preloader_gionee6580_we_m.bin Found 4 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : Q823MB eMMC CID : 150100513832334D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : Q72SMB eMMC CID : 150100513732534D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QE13MB eMMC CID : 150100514531334D42 eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : HAG4a2 eMMC CID : 90014A484147346132 Writing. Please wait... Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Switched to boot area partition 1. Writing partition preloader... Write data verification is enabled. Done. Switched to user area. Writing partition lk... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition logo... Done. Writing partition secro... Done. Writing partition system... Cancelling operation. Please wait...Done. Writing checksums...Done. Writing finished. SW: 2.1.4; FW: 2.00. Disconnected. Last edited by rebainoor; 10-19-2020 at 19:52. |
11-05-2020, 12:12 | #1074 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Realme 5i Pattern Remove Code: Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Hynix eMMC hC9aP3 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A6843396150330100383CAF47DD Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hC9aP3 Product revision : 0.1 Product serial number : (hex) 383CAF Manufacturing date : 04/2020 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC9aP3_05_11_2020_15_32_50.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00001000) 2048 KB P04: modemst2 (0000B028, 00001000) 2048 KB P05: persist (0000C028, 00010000) 32 MB P06: opporeserve1 (0001C028, 00004000) 8 MB P07: opporeserve2 (00020028, 00020000) 64 MB P08: opporeserve3 (00040028, 00020000) 64 MB P09: xbl (00064000, 00001C00) 3584 KB P10: xbl_config (00068000, 00000100) 128 KB P11: tz (0006C000, 00002000) 4 MB P12: rpm (0006E000, 00000400) 512 KB P13: hyp (0006E400, 00000400) 512 KB P14: fsg (0006E800, 00001000) 2048 KB P15: fsc (00070000, 00000100) 128 KB P16: boot (00070100, 00020000) 64 MB P17: vm-kystore (00090100, 00000800) 1024 KB P18: vm-data (00090900, 00005000) 10 MB P19: vm-system (00095900, 00040000) 128 MB P20: vm-linux (000D8000, 00010000) 32 MB P21: keymaster (000E8000, 00000400) 512 KB P22: cmnlib (000E8400, 00000400) 512 KB P23: cmnlib64 (000E8800, 00000400) 512 KB P24: mdtpsecapp (000E8C00, 00002000) 4 MB P25: mdtp (000EAC00, 00010000) 32 MB P26: dsp (000FAC00, 00010000) 32 MB P27: abl (0010AC00, 00000800) 1024 KB P28: ddr (0010B400, 00000800) 1024 KB P29: bluetooth (0010BC00, 00000800) 1024 KB P30: ssd (00110000, 00000010) 8 KB P31: dtbo (00110010, 0000C000) 24 MB P32: LOGO (0011C010, 00010000) 32 MB P33: DRIVER (0012C010, 00010000) 32 MB P34: imagefv (0013C010, 00001000) 2048 KB P35: uefisecapp (0013D010, 00001000) 2048 KB P36: metadata (0013E010, 00008000) 16 MB P37: misc (00146010, 00000800) 1024 KB P38: keystore (00146810, 00000400) 512 KB P39: devcfg (00146C10, 00000100) 128 KB P40: qupfw (00146D10, 00000080) 64 KB P41: frp (00146D90, 00000400) 512 KB P42: rawdump (00147190, 00040000) 128 MB P43: devinfo (00188000, 00000008) 4 KB P44: dip (00188008, 00000800) 1024 KB P45: apdp (0018C000, 00000200) 256 KB P46: spunvm (0018C200, 00004000) 8 MB P47: splash (00190200, 00010520) 32.64 MB P48: limits (001A4000, 00000008) 4 KB P49: toolsfv (001A4008, 00000800) 1024 KB P50: logfs (001A8000, 00004000) 8 MB P51: cateloader (001AC000, 00001000) 2048 KB P52: logdump (001AD000, 00020000) 64 MB P53: multiimgoem (001D0000, 00000040) 32 KB P54: multiimgqti (001D0040, 00000040) 32 KB P55: secdata (001D0080, 00000032) 25 KB P56: catefv (001D00B8, 00000400) 512 KB P57: catecontentfv (001D04B8, 00000800) 1024 KB P58: uefivarstore (001D0CB8, 00000400) 512 KB P59: vbmeta (001D10B8, 00000080) 64 KB P60: recovery (001D1138, 00020000) 64 MB P61: modem (001F1138, 0005A000) 180 MB P62: cache (0024C000, 00080000) 256 MB P63: system (002CC000, 00986C00) 4.763 GB P64: vendor (00C52C00, 002B4800) 1385 MB P65: oppo_sec (00F07400, 00005000) 10 MB P66: storsec (00F10000, 00000100) 128 KB P67: userdata (00F14000, 06567FDF) 50.7 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC9aP3_modemst1_0xa028_0x1000_05_11_2020_15_32_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.4; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC9aP3_modemst2_0xb028_0x1000_05_11_2020_15_32_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.4; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC9aP3_fsg_0x6e800_0x1000_05_11_2020_15_32_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.4; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 2932736 Number of sectors : 9989120 Build ID : QKQ1.200209.002 Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Reset operation finished |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
11-14-2020, 14:09 | #1075 (permalink) | |
Member: 135661 Status: Offline Thanks Meter: 92 | REDMI 7A "the system has been destroyed " done by flashing Quote:
11-18-2020, 14:21 | #1076 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | Repair LG H961N successfully done: Code: Welcome to Medusa Pro Software version 2.1.5. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: USB CCID Smart Card Reader 0 Model Settings: Interface : USB Brand : LG Model : H961N SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_H961N_USB.srf Core : Qualcomm MSM8992 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_009690E1 Core : Qualcomm MSM8992 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) Connect successful. --------------------------------------------------------------- SW: 2.1.5; FW: . P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002B000) 86 MB P02: spare1 (0002F000, 00001000) 2048 KB P03: pmic (00030000, 00000400) 512 KB P04: sbl1 (00030400, 00000800) 1024 KB P05: tz (00030C00, 00000800) 1024 KB P06: sdi (00031400, 00000400) 512 KB P07: hyp (00031800, 00000400) 512 KB P08: rpm (00031C00, 00000400) 512 KB P09: aboot (00032000, 00001000) 2048 KB P10: sbl1bak (00033000, 00000800) 1024 KB P11: pmicbak (00033800, 00000400) 512 KB P12: hypbak (00033C00, 00000400) 512 KB P13: tzbak (00034000, 00000800) 1024 KB P14: rpmbak (00034800, 00000400) 512 KB P15: abootbak (00034C00, 00001000) 2048 KB P16: sdibak (00035C00, 00000400) 512 KB P17: limits (00036000, 00000400) 512 KB P18: apdp (00036400, 00000400) 512 KB P19: msadp (00036800, 00000400) 512 KB P20: dpo (00036C00, 00000400) 512 KB P21: spare2 (00037000, 00001000) 2048 KB P22: persistent (00038000, 00000400) 512 KB P23: devinfo (00038400, 00000800) 1024 KB P24: spare3 (00038C00, 00003400) 6.5 MB P25: misc (0003C000, 00008000) 16 MB P26: persist (00044000, 00010000) 32 MB P27: modemst1 (00054000, 00000C00) 1536 KB P28: modemst2 (00054C00, 00000C00) 1536 KB P29: fsg (00055800, 00000C00) 1536 KB P30: fsc (00056400, 00000400) 512 KB P31: ssd (00056800, 00000400) 512 KB P32: keystore (00056C00, 00000400) 512 KB P33: DDR (00057000, 00001000) 2048 KB P34: sec (00058000, 00000400) 512 KB P35: encrypt (00058400, 00000400) 512 KB P36: eksst (00058800, 00000400) 512 KB P37: rct (00058C00, 00000400) 512 KB P38: spare4 (00059000, 00003000) 6 MB P39: laf (0005C000, 00018000) 48 MB P40: boot (00074000, 00014000) 40 MB P41: recovery (00088000, 00014000) 40 MB P42: drm (0009C000, 00005000) 10 MB P43: sns (000A1000, 00003000) 6 MB P44: mpt (000A4000, 00010000) 32 MB P45: raw_resources (000B4000, 00002000) 4 MB P46: raw_resourcesbak (000B6000, 00002000) 4 MB P47: factory (000B8000, 00017000) 46 MB P48: spare5 (000CF000, 00001000) 2048 KB P49: fota (000D0000, 00005000) 10 MB P50: fau (000D5000, 00007000) 14 MB P51: system (000DC000, 0085E000) 4.184 GB P52: cust (0093A000, 00050000) 160 MB P53: cache (0098A000, 00268000) 1232 MB P54: userdata (00BF2000, 06889800) 52.27 GB P55: grow (0747B800, 000007DF) 1008 KB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst1_0x54000_0xc00_18_11_2020_13_46_37.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.5; FW: . Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst2_0x54c00_0xc00_18_11_2020_13_46_37.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.5; FW: . Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/_fsg_0x55800_0xc00_18_11_2020_13_46_37.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.5; FW: . --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 901120 Number of sectors : 8773632 Device Manufacturer : lge Device Platform : msm8992 Build ID : LMY47V Display Build ID : LMY47V Release ID : 5.1.1 Device Model : LG-H961N Device Name : pplus_global_com Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : pplus_global_com-user 5.1.1 LMY47V 1619611048cc4 release-keys --------------------------------------------------------------- Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_H961N_USB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing spare1 partition... Done. Writing pmic partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing hyp partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing sbl1bak partition... Done. Writing pmicbak partition... Done. Writing hypbak partition... Done. Writing tzbak partition... Done. Writing rpmbak partition... Done. Writing abootbak partition... Done. Writing sdibak partition... Done. Writing limits partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing spare2 partition... Done. Writing persistent partition... Done. Writing devinfo partition... Done. Writing spare3 partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing keystore partition... Done. Writing DDR partition... Done. Writing sec partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing rct partition... Done. Writing spare4 partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing mpt partition... Done. Writing raw_resources partition... Done. Writing raw_resourcesbak partition... Done. Writing factory partition... Done. Writing spare5 partition... Done. Writing fota partition... Done. Writing fau partition... Done. Writing grow partition... Done. Smart Repair is successfully complete. SW: 2.1.5; FW: . Disconnected. Code: 18.11.2020 14:40:24 > Platform: LG Qualcomm 18.11.2020 14:40:24 > Selected port: COM48 18.11.2020 14:40:24 > Selected model: H961N 18.11.2020 14:40:24 > Reading info... 18.11.2020 14:40:26 > Model ID: LG-H961N 18.11.2020 14:40:26 > IMEI: 353829-07-279607-6 18.11.2020 14:40:26 > Android version: 6.0 18.11.2020 14:40:26 > Battery level: 17% 18.11.2020 14:40:28 > Mode: Emergency 18.11.2020 14:40:28 > Initializing flash...OK 18.11.2020 14:40:31 > Platform: msm8992 18.11.2020 14:40:31 > SW version: LGH961NAT-00-V20t-GLOBAL-COM-DEC-15-2016+0 18.11.2020 14:40:31 > Android version: 6.0 18.11.2020 14:40:31 > LAF Version: 1.1 18.11.2020 14:40:31 > Product ID: YE02S160924001782 18.11.2020 14:40:31 > IMEI: 353829-07-279607-6 18.11.2020 14:40:31 > Target operator: GLOBAL 18.11.2020 14:40:31 > Hardware: rev_10 18.11.2020 14:40:31 > Performed by 3.0.6.02 Software version. 18.11.2020 14:40:31 > Elapsed Time: 0:00:08 |
12-04-2020, 16:11 | #1077 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | Repair LG VS986 done by USB: Code: Welcome to Medusa Pro Software version 2.1.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Gemalto e-gate Smart Card 0 Model Settings: Interface : USB Downloaded and installed file C:/Program Files/Medusa Pro Software/firmwareFolder/LG_VS986W_USB.srf. Model Settings: Interface : USB Brand : LG Model : VS986W SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_VS986W_USB.srf Core : Qualcomm MSM8992 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_009690E1 Core : Qualcomm MSM8992 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) Connect successful. --------------------------------------------------------------- SW: 2.1.7; FW: . P00: GPT (00000000, 00008000) 16 MB P01: modem (00008000, 0002B000) 86 MB P02: pmic (00038000, 00000400) 512 KB P03: sbl1 (00038400, 00000800) 1024 KB P04: tz (00038C00, 00000800) 1024 KB P05: sdi (00039400, 00000400) 512 KB P06: hyp (00039800, 00000400) 512 KB P07: rpm (00039C00, 00000400) 512 KB P08: aboot (0003A000, 00001000) 2048 KB P09: sbl1bak (0003B000, 00000800) 1024 KB P10: pmicbak (0003B800, 00000400) 512 KB P11: tzbak (0003BC00, 00000800) 1024 KB P12: hypbak (0003C400, 00000400) 512 KB P13: rpmbak (0003C800, 00000400) 512 KB P14: abootbak (0003CC00, 00001000) 2048 KB P15: sdibak (0003DC00, 00000400) 512 KB P16: limits (0003E000, 00000400) 512 KB P17: devinfo (0003E400, 00000400) 512 KB P18: apdp (0003E800, 00000400) 512 KB P19: msadp (0003EC00, 00000400) 512 KB P20: dpo (0003F000, 00000400) 512 KB P21: spare1 (0003F400, 00000C00) 1536 KB P22: misc (00040000, 00008000) 16 MB P23: persist (00048000, 00010000) 32 MB P24: modemst1 (00058000, 00000C00) 1536 KB P25: modemst2 (00058C00, 00000C00) 1536 KB P26: fsg (00059800, 00000C00) 1536 KB P27: fsc (0005A400, 00000400) 512 KB P28: ssd (0005A800, 00000400) 512 KB P29: keystore (0005AC00, 00000400) 512 KB P30: DDR (0005B000, 00001000) 2048 KB P31: sec (0005C000, 00000400) 512 KB P32: encrypt (0005C400, 00000400) 512 KB P33: eksst (0005C800, 00000400) 512 KB P34: rct (0005CC00, 00000400) 512 KB P35: persistent (0005D000, 00001000) 2048 KB P36: spare2 (0005E000, 00002000) 4 MB P37: laf (00060000, 00018000) 48 MB P38: boot (00078000, 00014000) 40 MB P39: recovery (0008C000, 00014000) 40 MB P40: drm (000A0000, 00004000) 8 MB P41: sns (000A4000, 00004000) 8 MB P42: mpt (000A8000, 00010000) 32 MB P43: factory (000B8000, 00017000) 46 MB P44: fota (000CF000, 00005000) 10 MB P45: raw_resources (000D4000, 00002000) 4 MB P46: raw_resourcesbak (000D6000, 00002000) 4 MB P47: system (000D8000, 00816000) 4.043 GB P48: cust (008EE000, 00080000) 256 MB P49: cache (00970000, 00268000) 1232 MB P50: userdata (00BD8000, 02E60000) 23.19 GB P51: grow (03A38000, 00005FDF) 11.98 MB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst1_0x58000_0xc00_04_12_2020_16_57_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.7; FW: . Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/_modemst2_0x58c00_0xc00_04_12_2020_16_57_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.7; FW: . Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/_fsg_0x59800_0xc00_04_12_2020_16_57_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.7; FW: . --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 884736 Number of sectors : 8478720 Device Manufacturer : lge Device Platform : msm8992 Build ID : MRA58K Display Build ID : MRA58K Release ID : 6.0 Device Model : LG-H815 Device Name : p1_global_com Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : p1_global_com-user 6.0 MRA58K 1601518232117 release-keys --------------------------------------------------------------- Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_VS986W_USB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing pmic partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing hyp partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing sbl1bak partition... Done. Writing pmicbak partition... Done. Writing tzbak partition... Done. Writing hypbak partition... Done. Writing rpmbak partition... Done. Writing abootbak partition... Done. Writing sdibak partition... Done. Writing limits partition... Done. Writing devinfo partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing spare1 partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing keystore partition... Done. Writing DDR partition... Done. Writing sec partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing rct partition... Done. Writing persistent partition... Done. Writing spare2 partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing mpt partition... Done. Writing eri partition... Done. Writing raw_resources partition... Done. Writing raw_resourcesbak partition... Done. Writing operatorlogging partition... Done. Writing carrier partition... Done. Writing felica partition... Done. Writing factory partition... Done. Writing spare3 partition... Done. Writing fota partition... Done. Writing spare4 partition... Done. Smart Repair is successfully complete. SW: 2.1.7; FW: . Disconnected. |
12-22-2020, 18:44 | #1078 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Samsung SGH-T999 Extracting images done: Code: Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: USB CCID Smart Card Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Your current activation is not fully compatible with present hardware and requires an upgrade. Some features may be disabled or slower than expected. Use Card Update Tool to activate your upgrade string. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Toshiba eMMC 016G92 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 110100303136473932300D8B5328CFD7 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G92 Product revision : 3.0 Product serial number : (hex) D8B5328 Manufacturing date : 12/2012 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7700480 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/016G92_22_12_2020_19_27_26.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.7; FW: 2.00. Whole proccess time: . P00: GPT (00000000, 00002000) 4 MB P01: modem (00002000, 0001E000) 60 MB P02: sbl1 (00020000, 00000100) 128 KB P03: sbl2 (00020100, 00000200) 256 KB P04: sbl3 (00020300, 00000400) 512 KB P05: aboot (00020700, 00001000) 2048 KB P06: rpm (00021700, 00000400) 512 KB P07: boot (00021B00, 00005000) 10 MB P08: tz (00026B00, 00000400) 512 KB P09: pad (00026F00, 00000400) 512 KB P10: param (00027300, 00005000) 10 MB P11: efs (0002C300, 00006D00) 13.62 MB P12: modemst1 (00033000, 00001800) 3072 KB P13: modemst2 (00034800, 00001800) 3072 KB P14: system (00036000, 002EE000) 1500 MB P15: userdata (00324000, 0187A000) 12.24 GB P16: persist (01B9E000, 00004000) 8 MB P17: cache (01BA2000, 001A4000) 840 MB P18: recovery (01D46000, 00005000) 10 MB P19: fota (01D4B000, 00005000) 10 MB P20: backup (01D50000, 00003000) 6 MB P21: fsg (01D53000, 00001800) 3072 KB P22: ssd (01D54800, 00000010) 8 KB P23: grow (01D54810, 00002800) 5 MB Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/016G92_efs_0x2c300_0x6d00_22_12_2020_19_27_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.1.7; FW: 2.00. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/016G92_modemst1_0x33000_0x1800_22_12_2020_19_27_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.7; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/016G92_modemst2_0x34800_0x1800_22_12_2020_19_27_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.7; FW: 2.00. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/016G92_fsg_0x1d53000_0x1800_22_12_2020_19_27_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.7; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 221184 Number of sectors : 3072000 Device Manufacturer : samsung Device Platform : msm8960 Build ID : KOT49H Display Build ID : cm_d2tmo-userdebug 4.4.2 KOT49H InstallerXNPQ09O release-keys Release ID : 4.4.2 Device Model : SGH-T999 Device Name : d2uc Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : d2uc-user 4.1.2 JZO54K T999UVDMD5 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Parsing device... Image size in bytes: 2873098240 Volume system. Type: GPT. Partitions: 28. Total: 30756880 sectors. Warning: Unknown file system type. Details: Sector offset: 131072, Partition Type: sbl1 Parse finished. Whole proccess time: 27 seconds : 0 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Parse finished. Whole proccess time: 29 seconds : 0 ms. Parse finished. Whole proccess time: 37 seconds : 0 ms. Parse finished. Whole proccess time: 38 seconds : 0 ms. Parse finished. Whole proccess time: 47 seconds : 0 ms. Parse finished. Whole proccess time: 55 seconds : 0 ms. Start extracting folder userdata/media/0/DCIM/Camera . Size: 12288 Extracted folder. Whole proccess time: 9 minutes 0 seconds : 25 ms. |
01-25-2021, 15:22 | #1080 (permalink) | |
Member: 135661 Status: Offline Thanks Meter: 92 | REDMI 9A (dandelion) dead boot repair done Quote:
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
