01-11-2024, 14:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | A20s A207f U5 Google Frp Remove Medusa Pro II ✅ Welcome to Medusa Pro Software version 2.2.5. Activation type: Used the activation FULL Started. Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC GD6BMB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100474436424D4201A56496C9966F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : GD6BMB Full name one from : KMGD6001BM-B421 Product revision : 0.1 Product serial number : (hex) A56496C9 Manufacturing date : 09/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GD6BMB_10_01_2024_21_15_31.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.5; FW: 2.00. P00: GPT (00000000, 00405000) 4.02 MB P01: sbl1 (00405000, 00080000) 512 KB P02: rpm (00485000, 00080000) 512 KB P03: tz (00505000, 00200000) 2048 KB P04: devcfg (00705000, 00040000) 256 KB P05: dsp (00745000, 01000000) 16 MB P06: mdtp (01745000, 02000000) 32 MB P07: sbl1bak (03745000, 00080000) 512 KB P08: rpmbak (037C5000, 00080000) 512 KB P09: tzbak (03845000, 00200000) 2048 KB P10: devcfgbak (03A45000, 005BB000) 5.73 MB P11: lksecapp (04000000, 00020000) 128 KB P12: cmnlib (04020000, 00100000) 1024 KB P13: cmnlib64 (04120000, 00100000) 1024 KB P14: keymaster (04220000, 00100000) 1024 KB P15: aboot (04320000, 00200000) 2048 KB P16: vbmeta (04520000, 00010000) 64 KB P17: reserved (04530000, 002D0000) 2880 KB P18: vk (04800000, 00200000) 2048 KB P19: em (04A00000, 00400000) 4 MB P20: bksecapp (04E00000, 00080000) 512 KB P21: btd (04E80000, 00180000) 1536 KB P22: lksecappbak (05000000, 00020000) 128 KB P23: cmnlibbak (05020000, 00100000) 1024 KB P24: cmnlib64bak (05120000, 00100000) 1024 KB P25: keymasterbak (05220000, 00100000) 1024 KB P26: abootbak (05320000, 00200000) 2048 KB P27: dtbo (05520000, 00800000) 8 MB P28: vbmetabak (05D20000, 00010000) 64 KB P29: apnhlos (05D30000, 06AD0000) 106.8 MB P30: fsc (0C800000, 00340000) 3328 KB P31: ssd (0CB40000, 00040000) 256 KB P32: mota (0CB80000, 00080000) 512 KB P33: dip (0CC00000, 00400000) 4 MB P34: ddr (0D000000, 00080000) 512 KB P35: sec (0D080000, 00040000) 256 KB P36: fsg (0D0C0000, 00A00000) 10 MB P37: limits (0DAC0000, 00008000) 32 KB P38: devinfo (0DAC8000, 00538000) 5.219 MB P39: pad (0E000000, 00040000) 256 KB P40: modemst1 (0E040000, 00400000) 4 MB P41: modemst2 (0E440000, 00400000) 4 MB P42: sec_efs (0E840000, 01000000) 16 MB P43: efs (0F840000, 01000000) 16 MB P44: splash (10840000, 00B00000) 11 MB P45: apdp (11340000, 00040000) 256 KB P46: msadp (11380000, 00040000) 256 KB P47: param (113C0000, 00C00000) 12 MB P48: persist (11FC0000, 02000000) 32 MB P49: misc (13FC0000, 00100000) 1024 KB P50: syscfg (140C0000, 00080000) 512 KB P51: mcfg (14140000, 00400000) 4 MB P52: dpo (14540000, 00002000) 8 KB P53: logdump (14542000, 04000000) 64 MB P54: keystore (18542000, 00080000) 512 KB P55: config (185C2000, 00008000) 32 KB P56: oem (185CA000, 10000000) 256 MB P57: boot (285CA000, 04000000) 64 MB P58: recovery (2C5CA000, 04000000) 64 MB P59: debug (305CA000, 00A36000) 10.21 MB P60: steady (31000000, 00400000) 4 MB P61: persistent (31400000, 00080000) 512 KB P62: bota (31480000, 02380000) 35.5 MB P63: system (33800000, F0000000) 3840 MB P64: vendor (123800000, 3D000000) 976 MB P65: product (160800000, 14800000) 328 MB P66: cache (175000000, 0D400000) 212 MB P67: omr (182400000, 03700000) 55 MB P68: modem (185B00000, 05D00000) 93 MB P69: userdata (18B800000, 5BC3FB000) 22.94 GB --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1687552 Number of sectors : 7864320 Build ID : RP1A.200720.012 Display Build ID : RP1A.200720.012.A207FXXS5CWF1 Release ID : 11 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a20sxx-user 11 RP1A.200720.012 A207FXXS5CWF1 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 178202. Switched to boot area partition 1. Opening C:/Users/Mathew_di/Videos/A207F U5 BEYOĞLU/1BOOTSamsung eMMC GD6BMB_10_01_2024_21_15_35.bin file...Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.5; FW: 2.00. Switched to boot area partition 2. Opening C:/Users/Mathew_di/Videos/A207F U5 BEYOĞLU/2BOOTSamsung eMMC GD6BMB_10_01_2024_21_15_35.bin file...Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.5; FW: 2.00. EXT_CSD saved to file C:/Users/Mathew_di/Videos/A207F U5 BEYOĞLU/EXT_CSD_10_01_2024_21_16_00.bin. Switched to user area. Opening C:/Users/Mathew_di/Videos/A207F U5 BEYOĞLU/1024MBSamsung eMMC GD6BMB_10_01_2024_21_16_09.bin file...Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.5; FW: 2.00. Opening C:/Users/Mathew_di/Videos/A207F U5 BEYOĞLU/1024MBSamsung eMMC GD6BMB_10_01_2024_21_16_26.bin file...Reading. Please wait... Done. Elapsed time 00:05:49 SW: 2.2.5; FW: 2.00. Erasing partition persistent... Done. Erasing is finished. SW: 2.2.5; FW: 2.00. Reading RPMB. Please wait... Done. Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC GD6BMB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100474436424D4201A56496C9966F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : GD6BMB Full name one from : KMGD6001BM-B421 Product revision : 0.1 Product serial number : (hex) A56496C9 Manufacturing date : 09/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GD6BMB_10_01_2024_21_25_04.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.5; FW: 2.00. P00: GPT (00000000, 00405000) 4.02 MB P01: sbl1 (00405000, 00080000) 512 KB P02: rpm (00485000, 00080000) 512 KB P03: tz (00505000, 00200000) 2048 KB P04: devcfg (00705000, 00040000) 256 KB P05: dsp (00745000, 01000000) 16 MB P06: mdtp (01745000, 02000000) 32 MB P07: sbl1bak (03745000, 00080000) 512 KB P08: rpmbak (037C5000, 00080000) 512 KB P09: tzbak (03845000, 00200000) 2048 KB P10: devcfgbak (03A45000, 005BB000) 5.73 MB P11: lksecapp (04000000, 00020000) 128 KB P12: cmnlib (04020000, 00100000) 1024 KB P13: cmnlib64 (04120000, 00100000) 1024 KB P14: keymaster (04220000, 00100000) 1024 KB P15: aboot (04320000, 00200000) 2048 KB P16: vbmeta (04520000, 00010000) 64 KB P17: reserved (04530000, 002D0000) 2880 KB P18: vk (04800000, 00200000) 2048 KB P19: em (04A00000, 00400000) 4 MB P20: bksecapp (04E00000, 00080000) 512 KB P21: btd (04E80000, 00180000) 1536 KB P22: lksecappbak (05000000, 00020000) 128 KB P23: cmnlibbak (05020000, 00100000) 1024 KB P24: cmnlib64bak (05120000, 00100000) 1024 KB P25: keymasterbak (05220000, 00100000) 1024 KB P26: abootbak (05320000, 00200000) 2048 KB P27: dtbo (05520000, 00800000) 8 MB P28: vbmetabak (05D20000, 00010000) 64 KB P29: apnhlos (05D30000, 06AD0000) 106.8 MB P30: fsc (0C800000, 00340000) 3328 KB P31: ssd (0CB40000, 00040000) 256 KB P32: mota (0CB80000, 00080000) 512 KB P33: dip (0CC00000, 00400000) 4 MB P34: ddr (0D000000, 00080000) 512 KB P35: sec (0D080000, 00040000) 256 KB P36: fsg (0D0C0000, 00A00000) 10 MB P37: limits (0DAC0000, 00008000) 32 KB P38: devinfo (0DAC8000, 00538000) 5.219 MB P39: pad (0E000000, 00040000) 256 KB P40: modemst1 (0E040000, 00400000) 4 MB P41: modemst2 (0E440000, 00400000) 4 MB P42: sec_efs (0E840000, 01000000) 16 MB P43: efs (0F840000, 01000000) 16 MB P44: splash (10840000, 00B00000) 11 MB P45: apdp (11340000, 00040000) 256 KB P46: msadp (11380000, 00040000) 256 KB P47: param (113C0000, 00C00000) 12 MB P48: persist (11FC0000, 02000000) 32 MB P49: misc (13FC0000, 00100000) 1024 KB P50: syscfg (140C0000, 00080000) 512 KB P51: mcfg (14140000, 00400000) 4 MB P52: dpo (14540000, 00002000) 8 KB P53: logdump (14542000, 04000000) 64 MB P54: keystore (18542000, 00080000) 512 KB P55: config (185C2000, 00008000) 32 KB P56: oem (185CA000, 10000000) 256 MB P57: boot (285CA000, 04000000) 64 MB P58: recovery (2C5CA000, 04000000) 64 MB P59: debug (305CA000, 00A36000) 10.21 MB P60: steady (31000000, 00400000) 4 MB P61: persistent (31400000, 00080000) 512 KB P62: bota (31480000, 02380000) 35.5 MB P63: system (33800000, F0000000) 3840 MB P64: vendor (123800000, 3D000000) 976 MB P65: product (160800000, 14800000) 328 MB P66: cache (175000000, 0D400000) 212 MB P67: omr (182400000, 03700000) 55 MB P68: modem (185B00000, 05D00000) 93 MB P69: userdata (18B800000, 5BC3FB000) 22.94 GB --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1687552 Number of sectors : 7864320 Build ID : RP1A.200720.012 Display Build ID : RP1A.200720.012.A207FXXS5CWF1 Release ID : 11 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a20sxx-user 11 RP1A.200720.012 A207FXXS5CWF1 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 178202. Erasing partition persistent... Done. Erasing is finished. SW: 2.2.5; FW: 2.00. Disconnected. |
The Following User Says Thank You to mathew_di For This Useful Post: |
