09-01-2011, 07:08 | #31 (permalink) |
Insane Poster Join Date: Jul 2011 Location: philippines
Member: 1625074 Status: Offline Sonork: 100.1594921 Thanks Meter: 114 | Samsung Anycall SPH-W5500 Dead Boot Tool's; -Meduza Box -Pinout Rj45 Procedure; - At the Software Image; Wella; Best Regard; Unlock ASAP |
The Following 2 Users Say Thank You to Unlock ASAP For This Useful Post: |
09-01-2011, 08:06 | #32 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 212116 Status: Offline Thanks Meter: 178 | HTC HD7 succesfully unlocked via reading code! Welcome to Medusa Box Software version 1.1.8 Selected device model: HTC HD7 (PD29110) Connecting. Please wait... Detected Core ID: 202400E1 VREF level : 2.60 V CPU : Qualcomm QSD8250 Core ID : 202400E1 Flash device: Samsung 512Mb Flash ID : 0066ECBC Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb HTC CID : T-MOB010 IMEI : 354004-04-****** Connect successful. Rading codes. Please wait... NCK Code : 05085742 Done Thanks, Medusa Team! |
The Following User Says Thank You to paffka For This Useful Post: |
09-01-2011, 11:58 | #33 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: Inside Samsung
Member: 392170 Status: Offline Sonork: 1587688 Thanks Meter: 150 | Sph-w5300 repair ok with medusa thanks support medusa box ! Quote:
The Following User Says Thank You to hoangtruongson For This Useful Post: |
09-08-2011, 00:02 | #36 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Sony Ericsson XPERIA X10 unlock Code: Welcome to Medusa Box Software version 1.1.9 Selected device model: Sony Ericsson XPERIA X10 Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. VREF = 0.0V is less than required level. Please check target device power supply. Detected Core ID: 1BA000E1 Detected Core ID: 202400E1 CPU : Qualcomm QSD8250 Core ID : 202400E1 Flash device: Micron 1024Mb Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 8192 Flash size : 1024 Mb Connect successful. Reading TA section. Please wait... Done TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson XPERIA X10 TA Backup 08-09-2011 10_36_37.mf". Unlocking. Please wait... Done Disconnected |
The Following 2 Users Say Thank You to dr_moosavi For This Useful Post: |
09-08-2011, 00:05 | #37 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Sony Ericsson XPERIA X10 unlock Code: Welcome to Medusa Box Software version 1.1.9 Selected device model: Sony Ericsson XPERIA X10 Connecting. Please wait... MI: RTCK reaction time 189 ns. Detected Core ID: 1BA000E1 Detected Core ID: 202400E1 VREF level : 2.67 V CPU : Qualcomm QSD8250 Core ID : 202400E1 MI: P15,C0,C0: 0x41069265 MI: Loading server. MI: Starting server. MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x0000007F. MI: Detailed server caps: FLASH, CFG, ECC, BASE, WDOG, DWP, SAFEW MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0x00552CB3. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 0000007F Flash device: Micron 1024Mb Flash ID : 00002CB3 Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 8192 Flash size : 1024 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Connect successful. Reading TA section. Please wait... Done TA section has been backed up to "C:\Program Files\GsmServer\Medusa\Firmware\Sony Ericsson XPERIA X10 TA Backup 08-09-2011 15_37_57.mf". Unlocking. Please wait... Done Disconnected |
09-08-2011, 14:44 | #39 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Succesfully Repaired boot samsung S5230 Log started at 08.09.2011 18:05:05 ... Welcome to Medusa Box Software version 1.1.9 Выбраная модель: Samsung GT-S5230 Соединение... MI: RTCK reaction time 126 ns. Найдено ЦПУ ID: 07926F0F Уровень VREF : 3.6 V ЦПУ : Broadcom BCM2133 ID ЦПУ : 07926F0F MI: Loading server. MI: Starting server. MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000035. MI: Detailed server caps: FLASH, ECC, WDOG, DWP MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0x0000ECBA. MI: Flash geometry set. MI: Recheking settings... ok Флаги сервера : 00000035 Тип флэш : Samsung KF92G16 ID флэш : 0000ECBA Размер страницы : 2048 bytes Размер блока : 64 страниц (128 Kb) Количество блоков : 2048 Общий размер флэш : 256 Mb Защита записи отключена. Открыт "C:\Program Files\GsmServer\Medusa\SAMSUNG_GTS5230_Repair.mf" файл... Запись BOOT секции. Пожалуйста, подождите... Завершено Отключено. Восстановление завершено. Last edited by Medusa Box; 09-08-2011 at 14:58. |
The Following User Says Thank You to Namangan For This Useful Post: |
09-08-2011, 14:45 | #40 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | Succedfully repaired boot samsung S5230m Выбраная модель: Samsung GT-S5230M Соединение... MI: RTCK reaction time 126 ns. Найдено ЦПУ ID: 07926F0F Уровень VREF : 3.5 V ЦПУ : Broadcom BCM2133 ID ЦПУ : 07926F0F MI: Loading server. MI: Starting server. MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000035. MI: Detailed server caps: FLASH, ECC, WDOG, DWP MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0x00002CBA. MI: Flash geometry set. MI: Recheking settings... ok Флаги сервера : 00000035 Тип флэш : Micron 256Mb ID флэш : 00002CBA Размер страницы : 2048 bytes Размер блока : 64 страниц (128 Kb) Количество блоков : 2048 Общий размер флэш : 256 Mb Защита записи отключена. Открыт "C:\Program Files\GsmServer\Medusa\SAMSUNG_GTS5230M_Repair.mf" файл... Запись BOOT секции. Пожалуйста, подождите... Завершено Отключено. |
09-09-2011, 10:44 | #41 (permalink) |
Freak Poster Join Date: Oct 2010 Location: vietnam
Member: 1431756 Status: Offline Thanks Meter: 43 | Read code ok HTC mytouch 4g By Medusa Box Welcome to Medusa Box Software version 1.1.9 Selected device model: HTC myTouch 4G (PD15100) Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. Selected device model: HTC myTouch 4G (PD15100) Connecting. Please wait... Resetting target. Please wait... Detected Core ID: 17B360E1 VREF level : 1.81 V CPU : Qualcomm MSM8255 Core ID : 105700E1 Storage Device: eMMC Block size : 512 bytes Blocks : 8388608 Storage size : 4 Gb HTC CID : T-MOB010 IMEI : 359637-03-136197 Connect successful. Rading codes. Please wait... NCK Code : 77910989 Done Disconnected |
The Following 2 Users Say Thank You to 0944055678 For This Useful Post: |
09-09-2011, 16:55 | #42 (permalink) |
Member: 1431756 Status: Offline Thanks Meter: 43 | Read code ok HTC Mytuoch 4g Welcome to Medusa Box Software version 1.1.9 Selected device model: HTC myTouch 4G (PD15100) Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. Selected device model: HTC myTouch 4G (PD15100) Connecting. Please wait... Resetting target. Please wait... Detected Core ID: 17B360E1 VREF level : 1.81 V CPU : Qualcomm MSM8255 Core ID : 105700E1 Storage Device: eMMC Block size : 512 bytes Blocks : 8388608 Storage size : 4 Gb HTC CID : T-MOB010 IMEI : 359637-03-136197 Connect successful. Rading codes. Please wait... NCK Code : 77910989 Done Disconnected |
09-13-2011, 12:35 | #44 (permalink) |
Member: 1625074 Status: Offline Sonork: 100.1594921 Thanks Meter: 114 | LG Cyon KU9100 Deadboot [Solve] Tool's; -Mebusa Box -Octopus Box Procedure; -Repair In Medusa Box First -Reflash In Octopus Box Wella; Salamat sa pagdala ng unit Bro Catac Best Regard; Unlock ASAP |
09-14-2011, 09:47 | #45 (permalink) |
Freak Poster Join Date: May 2006
Member: 280798 Status: Offline Thanks Meter: 70 | HTC Freestyle unlock ok Недостаточный уровень напряжения VREF = 0.0V. Пожалуйста, перепроверьте состояние питания устройства. Найдено ЦПУ ID: C01B30E1 Уровень VREF : 1.29 V ЦПУ : Qualcomm MSM7225 ID ЦПУ : C01B30E1 Тип флэш : Hynix H8BES0UQ0MCR Размер страницы : 2048 bytes Размер блока : 64 страниц (128 Kb) Количество блоков : 4096 Общий размер флэш : 512 Mb HTC CID : CWS__001 IMEI : 352441-04-036851 Соединение успешно. Rading codes. Please wait... NCK Code : 17197096 Done Отключено. |
The Following User Says Thank You to vardan76 For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
