12-19-2021, 04:27 | #1097 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Algeria
Member: 2900446 Status: Offline Thanks Meter: 279 | Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 8 bits Bus speed : Auto Operations with eMMC restricted(Bus Mode : 1b) Connecting... Device : Samsung eMMC GD6BMB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100474436424D4201513B061495A3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : GD6BMB Product revision : 0.1 Product serial number : (hex) 513B0614 Manufacturing date : 09/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GD6BMB_27_04_2021_16_14_41.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0.1; FW: 2.00. P00: GPT (00000000, 00008000) 32 KB P01: boot_para (00008000, 00100000) 1024 KB P02: recovery (00108000, 02000000) 32 MB P03: para (02108000, 00080000) 512 KB P04: expdb (02188000, 01400000) 20 MB P05: frp (03588000, 00100000) 1024 KB P06: nvcfg (03688000, 02000000) 32 MB P07: nvdata (05688000, 04000000) 64 MB P08: metadata (09688000, 02000000) 32 MB P09: protect1 (0B688000, 00800000) 8 MB P10: protect2 (0BE88000, 00978000) 9.469 MB P11: seccfg (0C800000, 00800000) 8 MB P12: sec1 (0D000000, 00200000) 2048 KB P13: proinfo (0D200000, 00300000) 3072 KB P14: md1img (0D500000, 06400000) 100 MB P15: spmfw (13900000, 00100000) 1024 KB P16: scp1 (13A00000, 00100000) 1024 KB P17: scp2 (13B00000, 00100000) 1024 KB P18: sspm_1 (13C00000, 00100000) 1024 KB P19: sspm_2 (13D00000, 00100000) 1024 KB P20: gz1 (13E00000, 01000000) 16 MB P21: gz2 (14E00000, 01000000) 16 MB P22: nvram (15E00000, 04000000) 64 MB P23: lk (19E00000, 00100000) 1024 KB P24: lk2 (19F00000, 00100000) 1024 KB P25: boot (1A000000, 02000000) 32 MB P26: logo (1C000000, 00800000) 8 MB P27: odmdtbo (1C800000, 01000000) 16 MB P28: tee1 (1D800000, 00500000) 5 MB P29: tee2 (1DD00000, 00B00000) 11 MB P30: vendor (1E800000, 32000000) 800 MB P31: system (50800000, D6000000) 3424 MB P32: cache (126800000, 1B000000) 432 MB P33: userdata (141800000, 6028FBE00) 24.04 GB P34: otp (7440FBE00, 02B00000) 43 MB P35: flashinfo (746BFBE00, 01000000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GD6BMB_nvdata_0x2b440_0x20000_27_04_2021_16_14_41.bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.0.1; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 2637824 Number of sectors : 7012352 Device Manufacturer : Condor Build ID : O11019 Display Build ID : SP638_V11_20190122 Release ID : 8.1.0 Device Model : Plume L3 Smart Device Name : SP638 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : SP638-user 8.1.0 O11019 1547692115 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Last edited by DZGSM-TEAM; 12-19-2021 at 04:35. |
The Following 4 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
12-19-2021, 04:30 | #1098 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | Samsung Gravity 2 [SGH-T469] Code: Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 1.56 MHz Full speed mode! Connecting... Device : Hynix eMMC H4G2a Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326111015886E65B3349 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2a Product revision : 0.1 Product serial number : (hex) 5886E65B Manufacturing date : 03/2016 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2a_24_07_2021_00_29_52.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. P00: GPT (00000000, 00100000) 1024 KB P01: prodnv (00100000, 00500000) 5 MB P02: miscdata (00600000, 00100000) 1024 KB P03: wmodem (00700000, 00800000) 8 MB P04: wdsp (00F00000, 00200000) 2048 KB P05: wfixnv1 (01100000, 00100000) 1024 KB P06: wfixnv2 (01200000, 00100000) 1024 KB P07: wruntimenv1 (01300000, 00100000) 1024 KB P08: wruntimenv2 (01400000, 00100000) 1024 KB P09: wcnmodem (01500000, 00100000) 1024 KB P10: wcnfixnv1 (01600000, 00100000) 1024 KB P11: wcnfixnv2 (01700000, 00100000) 1024 KB P12: wcnruntimenv1 (01800000, 00100000) 1024 KB P13: wcnruntimenv2 (01900000, 00100000) 1024 KB P14: logo (01A00000, 00200000) 2048 KB P15: fbootlogo (01C00000, 00100000) 1024 KB P16: boot (01D00000, 00B00000) 11 MB P17: system (02800000, 59000000) 1424 MB P18: cache (5B800000, 09600000) 150 MB P19: recovery (64E00000, 00C00000) 12 MB P20: misc (65A00000, 00100000) 1024 KB P21: userdata (65B00000, 5DC00000) 1500 MB P22: internalsd (C3700000, 25000000) 592 MB --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 81920 Number of sectors : 2916352 Device Manufacturer : CONDOR Device Platform : sc8830 Build ID : KOT49H Display Build ID : PHQ519_125A_V0_0_4 Release ID : 4.4.2 Device Model : PHQ519 Device Name : Q336 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Build Description : condor-user 4.4.2 KOT49H 14B_1432179957 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Last edited by DZGSM-TEAM; 12-19-2021 at 04:36. |
12-19-2021, 04:31 | #1099 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Kingston eMMC V10008 Page size : 512 B Block size : 512 B Block count : 14778368 Size : 7.05 GB (7216.00 MB) --------------------------------------------------------------- CID Info CID : 700100563130303038501F8D956C63FF Manufacturer ID : 0X70 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : V10008 Product revision : 5.0 Product serial number : (hex) 1F8D956C Manufacturing date : 06/2016 --------------------------------------------------------------- CSD Info CSD : D04F01320F5903FFFFFFFFEF8A400061 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 40 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1228800 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/V10008_19_02_2021_19_46_02.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0; FW: 2.00. P00: GPT (00000000, 00080000) 512 KB P01: proinfo (00080000, 00300000) 3072 KB P02: nvram (00380000, 00500000) 5 MB P03: protect1 (00880000, 00A00000) 10 MB P04: protect2 (01280000, 00A00000) 10 MB P05: lk (01C80000, 00080000) 512 KB P06: para (01D00000, 00080000) 512 KB P07: boot (01D80000, 01000000) 16 MB P08: recovery (02D80000, 01000000) 16 MB P09: logo (03D80000, 00800000) 8 MB P10: expdb (04580000, 00A00000) 10 MB P11: seccfg (04F80000, 00080000) 512 KB P12: oemkeystore (05000000, 00200000) 2048 KB P13: secro (05200000, 00600000) 6 MB P14: keystore (05800000, 00800000) 8 MB P15: tee1 (06000000, 00500000) 5 MB P16: tee2 (06500000, 00500000) 5 MB P17: frp (06A00000, 00100000) 1024 KB P18: nvdata (06B00000, 02000000) 32 MB P19: metadata (08B00000, 02500000) 37 MB P20: system (0B000000, C0000000) 3072 MB P21: cache (CB000000, 19000000) 400 MB P22: userdata (E4000000, DDF80000) 3552 MB P23: flashinfo (1C1F80000, 01000000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/V10008_nvdata_0x35800_0x10000_19_02_2021_19_46_02.bin file... Reading. Please wait... Done. Elapsed time 00:00:10 SW: 2.2.0; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : c3000000 bytes Device sector size : 512 bytes Partition offset : 360448 Number of sectors : 6291456 Device Manufacturer : Condor Device Platform : mt6737m Build ID : MRA58K Display Build ID : PAM524_V10_20161215 Release ID : 6.0 Device Model : PAM524 Device Name : Griffe_G5_Plus Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : full_rlk6737m_35g_c_m0-user 6.0 MRA58K 1481773781 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Last edited by DZGSM-TEAM; 12-19-2021 at 04:37. |
12-19-2021, 04:31 | #1100 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | Code: Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 50 MHz Full speed mode! Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147326505075726CC42336F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.7 Product serial number : (hex) 5726CC42 Manufacturing date : 03/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG2e_19_02_2021_18_00_17.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0; FW: 2.00. P00: GPT (00000000, 00100000) 1024 KB P01: prodnv (00100000, 00500000) 5 MB P02: miscdata (00600000, 00100000) 1024 KB P03: l_fixnv1 (00700000, 00100000) 1024 KB P04: l_fixnv2 (00800000, 00100000) 1024 KB P05: l_runtimenv1 (00900000, 00100000) 1024 KB P06: l_runtimenv2 (00A00000, 00100000) 1024 KB P07: l_modem (00B00000, 01300000) 19 MB P08: l_ldsp (01E00000, 00300000) 3072 KB P09: l_gdsp (02100000, 00300000) 3072 KB P10: l_warm (02400000, 00300000) 3072 KB P11: pm_sys (02700000, 00100000) 1024 KB P12: logo (02800000, 00100000) 1024 KB P13: fbootlogo (02900000, 00100000) 1024 KB P14: wcnfdl (02A00000, 00100000) 1024 KB P15: wcnmodem (02B00000, 00A00000) 10 MB P16: boot (03500000, 01400000) 20 MB P17: system (04900000, A8C00000) 2700 MB P18: persist (AD500000, 00200000) 2048 KB P19: sysinfo (AD700000, 00600000) 6 MB P20: cache (ADD00000, 09600000) 150 MB P21: recovery (B7300000, 01400000) 20 MB P22: misc (B8700000, 00100000) 1024 KB P23: userdata (B8800000, 2F2FFBE00) 11.8 GB --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 149504 Number of sectors : 5529600 Device Manufacturer : Condor Device Platform : sc8830 Build ID : MRA58K Display Build ID : PHQ526_V11.0_20161108 Release ID : 6.0 Device Model : PHQ526 Device Name : PHQ526 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : zsl859pb_condor-user 6.0 MRA58K 1478610627 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Last edited by DZGSM-TEAM; 12-19-2021 at 04:38. |
12-19-2021, 04:32 | #1101 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | Code: Welcome to Medusa Pro Software version 2.2.0. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected BGA 221 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Failed to connect Operations with eMMC restricted(Bus Mode : 1b) Connecting... Device : Micron eMMC Q2J36C Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 13014E51324A33364310006201907289 Manufacturer ID : 0X13 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : Q2J36C Product revision : 1.0 Product serial number : (hex) 620190 Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5913FFFFFFFFEF924000A3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q2J36C_12_02_2021_01_28_48.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0; FW: 2.00. P00: GPT (00000000, 00080000) 512 KB P01: proinfo (00080000, 00300000) 3072 KB P02: nvram (00380000, 00500000) 5 MB P03: protect1 (00880000, 00A00000) 10 MB P04: protect2 (01280000, 00A00000) 10 MB P05: lk (01C80000, 00080000) 512 KB P06: para (01D00000, 00080000) 512 KB P07: boot (01D80000, 01000000) 16 MB P08: recovery (02D80000, 01000000) 16 MB P09: logo (03D80000, 00800000) 8 MB P10: expdb (04580000, 00A00000) 10 MB P11: seccfg (04F80000, 00080000) 512 KB P12: oemkeystore (05000000, 00200000) 2048 KB P13: secro (05200000, 00600000) 6 MB P14: keystore (05800000, 00800000) 8 MB P15: tee1 (06000000, 00500000) 5 MB P16: tee2 (06500000, 00500000) 5 MB P17: frp (06A00000, 00100000) 1024 KB P18: nvdata (06B00000, 02000000) 32 MB P19: metadata (08B00000, 02000000) 32 MB P20: teksunhw (0AB00000, 00500000) 5 MB P21: system (0B000000, A2800000) 2600 MB P22: cache (AD800000, 19000000) 400 MB P23: userdata (C6800000, 2E3B80000) 11.56 GB P24: flashinfo (3AA380000, 01000000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q2J36C_nvdata_0x35800_0x10000_12_02_2021_01_28_48.bin file... Reading. Please wait... Done. Elapsed time 00:00:10 SW: 2.2.0; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 360448 Number of sectors : 5324800 Device Manufacturer : Condor Device Platform : mt6737m Build ID : NRD90M Display Build ID : SP622_V15_20190611 Release ID : 7.0 Device Model : Plume L1 Device Name : SP622 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : full_t856be_v1_g_js_lx5501_hd-user 7.0 NRD90M 1560250013 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 0. Last edited by DZGSM-TEAM; 12-19-2021 at 04:41. |
12-19-2021, 04:32 | #1102 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Full speed mode! Connecting... Device : Samsung eMMC FNX2MB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100464E58324D42014AA7EE0444F7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FNX2MB Product revision : 0.1 Product serial number : (hex) 4AA7EE04 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/FNX2MB_10_06_2021_14_32_13.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. P00: GPT (00000000, 00000800) 1024 KB P01: prodnv (00000800, 00002800) 5 MB P02: miscdata (00003000, 00000800) 1024 KB P03: l_fixnv1 (00003800, 00000800) 1024 KB P04: l_fixnv2 (00004000, 00000800) 1024 KB P05: l_runtimenv1 (00004800, 00000800) 1024 KB P06: l_runtimenv2 (00005000, 00000800) 1024 KB P07: l_modem (00005800, 00009800) 19 MB P08: l_ldsp (0000F000, 00001800) 3072 KB P09: l_gdsp (00010800, 00001800) 3072 KB P10: l_warm (00012000, 00001800) 3072 KB P11: pm_sys (00013800, 00000800) 1024 KB P12: logo (00014000, 00000800) 1024 KB P13: fbootlogo (00014800, 00000800) 1024 KB P14: wcnfdl (00015000, 00000800) 1024 KB P15: wcnmodem (00015800, 00005000) 10 MB P16: boot (0001A800, 0000A000) 20 MB P17: trustos (00024800, 00000800) 1024 KB P18: vmm (00025000, 00000800) 1024 KB P19: persist (00025800, 00001000) 2048 KB P20: system (00026800, 00500000) 2560 MB P21: sysinfo (00526800, 00003000) 6 MB P22: cache (00529800, 0004B000) 150 MB P23: recovery (00574800, 0000A000) 20 MB P24: misc (0057E800, 00000800) 1024 KB P25: userdata (0057F000, 00910FDF) 4.533 GB --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 157696 Number of sectors : 5242880 Device Manufacturer : Condor Device Platform : sc8830 Build ID : NRD90M Display Build ID : NRD90M release-keys Release ID : 7.0 Device Model : Griffe T2 Device Name : SP530 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : zsl866_condor-user 7.0 NRD90M 6303 release-keys --------------------------------------------------------------- RPMB: Authentication Key not yet programmed. Last edited by DZGSM-TEAM; 12-19-2021 at 04:42. |
12-19-2021, 04:33 | #1103 (permalink) |
Member: 2900446 Status: Offline Thanks Meter: 279 | Samsung Gravity 2 [SGH-T469] Samsung Gravity 2 [SGH-T469] Old but still fun Code: Model Settings: Interface : JTAG Core : Qualcomm MSM6246 Voltage : 2700 Reset : RESET, Halt After 100 ms Tap : Auto Speed : Auto Connecting... Vref level is 2.62V. Scan successfull, number of TAPs = 1. TAP 0: Id code = 401200E1, IR length = 4. TAP 0: CPU name "Qualcomm MSM6246", interface type = 10. Initializing interface... JTAG speed : Auto (RTCK) Protocol ver : 3.0 Buffer size : 0x8440 bytes Storage type : OneNAND Storage ID : 00EC:0044 Storage size : 256 MB Device : Samsung OneNAND KFH2G16Q2M Page size : 2048 B Block size : 131072 B Block count : 2048 Size : 256.00 MB Connect successful. --------------------------------------------------------------- SW: 2.2.3.1; FW: 1.24. P00: 0:MIBIB (00000000, 00100000) 1024 KB P01: 0:SIM_SECURE (00100000, 00060000) 384 KB P02: 0:QCSBL (00160000, 00060000) 384 KB P03: 0:OEMSBL1 (001C0000, 000C0000) 768 KB P04: 0:OEMSBL2 (00280000, 00080000) 512 KB P05: 0:AMSS (00300000, 03BA0000) 59.62 MB P06: 0:FOTA (03EA0000, 00120000) 1152 KB P07: 0:FTL (03FC0000, 00900000) 9 MB P08: 0:EFS2 (048C0000, 0B740000) 183.2 MB Code: (FULL SAMSUNG SGH-T469) SAMSUNG OneNAND KFH2G16Q2M_BY_DZGSM_TEAM.bin (LIVE_LOG_SAMSUNG SGH-T469) SAMSUNG OneNAND KFH2G16Q2M.txt SAMSUNG_SGH-T469_SAMSUNG OneNAND KFH2G16Q2M_BY_DZGSM_TEAM.srf |
01-17-2022, 12:15 | #1104 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | oPPo A37F Password Locked / USB Damaged, Reset Via ISP Success By Medusa Pro Code: Welcome to Medusa Pro Software version 2.2.3. Started. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420DAF009B945499 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Full name one from : KMQE10013M-B318 Product revision : 0.13 Product serial number : (hex) AF009B94 Manufacturing date : 05/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_17_01_2022_14_49_00.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.3; FW: 1.24. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 00020000) 64 MB P02: DDR (00040000, 00000040) 32 KB P03: fsg (00040040, 00000C00) 1536 KB P04: sec (00040C40, 00000020) 16 KB P05: fsc (00060000, 00000002) 1024 b P06: ssd (00060002, 00000010) 8 KB P07: sbl1 (00060012, 00000400) 512 KB P08: sbl1bak (00060412, 00000400) 512 KB P09: aboot (00080000, 00000800) 1024 KB P10: abootbak (00080800, 00000800) 1024 KB P11: rpm (000A0000, 00000400) 512 KB P12: rpmbak (000A0400, 00000400) 512 KB P13: tz (000A0800, 00000400) 512 KB P14: tzbak (000A0C00, 00000400) 512 KB P15: hyp (000A1000, 00000400) 512 KB P16: hypbak (000A1400, 00000400) 512 KB P17: modemst1 (000A1800, 00000C00) 1536 KB P18: modemst2 (000A2400, 00000C00) 1536 KB P19: oppodycnvbk (000A3000, 00005000) 10 MB P20: oppostanvbk (000A8000, 00005000) 10 MB P21: LOGO (000AD000, 00008000) 16 MB P22: boot (000C0000, 00010000) 32 MB P23: recovery (000D0000, 00010000) 32 MB P24: system (000E0000, 00580000) 2816 MB P25: devinfo (00660000, 00000800) 1024 KB P26: cache (00680000, 00040000) 128 MB P27: persist (006C0000, 00010000) 32 MB P28: misc (006D0000, 00000800) 1024 KB P29: keystore (006D0800, 00000400) 512 KB P30: config (006D0C00, 00000040) 32 KB P31: oem (006D0C40, 00020000) 64 MB P32: DRIVER (006F0C40, 00010000) 32 MB P33: reserve1 (00700C40, 00001000) 2048 KB P34: reserve2 (00701C40, 00008000) 16 MB P35: reserve3 (00709C40, 00001000) 2048 KB P36: reserve4 (0070AC40, 00008000) 16 MB P37: reserve_exp1 (00712C40, 00001000) 2048 KB P38: userdata (00713C40, 0160B39F) 11.02 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE13MB_fsg_0x40040_0xc00_17_01_2022_14_49_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE13MB_modemst1_0xa1800_0xc00_17_01_2022_14_49_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE13MB_modemst2_0xa2400_0xc00_17_01_2022_14_49_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.3; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 917504 Number of sectors : 5767168 Device Manufacturer : OPPO Device Platform : msm8916 Build ID : LMY47V Display Build ID : A37fEX_11_190711 Release ID : 5.1.1 Device Model : A37f Device Name : A37f Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : msm8916_64-user 5.1.1 LMY47V eng.root.20190711.032745 release-keys --------------------------------------------------------------- Reset operation finished Backuping FRP data... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x6d0c00_0x40_17_01_2022_14_49_33.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.3; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.2.3; FW: 1.24. Disconnected. |
The Following 2 Users Say Thank You to GSM AR For This Useful Post: |
02-07-2022, 14:20 | #1105 (permalink) |
Member: 2608490 Status: Offline Thanks Meter: 921 | Realme C1 / C2 RMX1805EX / RMX1811 Write Flash Success By Medusa Pro Code: Welcome to Medusa Pro Software version 2.2.2. Started. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4206E0E5077CB571 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Full name one from : KMQE60013M-B318 Product revision : 0.6 Product serial number : (hex) E0E5077C Manufacturing date : 11/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_07_02_2022_11_08_02.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00000C00) 1536 KB P04: modemst2 (0000AC28, 00000C00) 1536 KB P05: persist (0000B828, 00010000) 32 MB P06: opporeserve1 (0001B828, 00004000) 8 MB P07: opporeserve2 (0001F828, 00020000) 64 MB P08: fsc (0003F828, 00000002) 1024 b P09: ssd (0003F830, 00000010) 8 KB P10: sbl1 (0003F840, 00000400) 512 KB P11: rpm (0003FC40, 00000400) 512 KB P12: tz (00040040, 00001000) 2048 KB P13: devcfg (00041040, 00000200) 256 KB P14: sbl1bak (00041240, 00000400) 512 KB P15: rpmbak (00041640, 00000400) 512 KB P16: tzbak (00041A40, 00001000) 2048 KB P17: devcfgbak (00042A40, 00000200) 256 KB P18: dsp (00042C40, 00008000) 16 MB P19: DDR (0004C000, 00000040) 32 KB P20: fsg (0004C040, 00002000) 4 MB P21: sec (0004E040, 00000020) 16 KB P22: aboot (0004E060, 00000800) 1024 KB P23: abootbak (0004E860, 00000800) 1024 KB P24: modem (0004F060, 00040000) 128 MB P25: dtbo (0008F060, 00004000) 8 MB P26: vbmeta (00093060, 00000080) 64 KB P27: boot (000930E0, 00020000) 64 MB P28: recovery (000B30E0, 00020000) 64 MB P29: devinfo (000D30E0, 00000800) 1024 KB P30: splash (000D4000, 00005800) 11 MB P31: LOGO (000D9800, 00010000) 32 MB P32: DRIVER (000E9800, 00010000) 32 MB P33: cache (000F9800, 00080000) 256 MB P34: misc (00179800, 00000800) 1024 KB P35: keystore (0017A000, 00000400) 512 KB P36: config (0017A400, 00000040) 32 KB P37: log (0017A440, 00020000) 64 MB P38: oem (0019A440, 00000800) 1024 KB P39: limits (0019C000, 00000040) 32 KB P40: mota (001A0000, 00000400) 512 KB P41: dip (001A0400, 00000800) 1024 KB P42: mdtp (001A0C00, 00010000) 32 MB P43: syscfg (001B0C00, 00000400) 512 KB P44: mcfg (001B1000, 00002000) 4 MB P45: lksecapp (001B4000, 00000100) 128 KB P46: cmnlib (001B4100, 00000800) 1024 KB P47: cmnlib64 (001B4900, 00000800) 1024 KB P48: keymaster (001B5100, 00000800) 1024 KB P49: lksecappbak (001B5900, 00000100) 128 KB P50: cmnlibbak (001B5A00, 00000800) 1024 KB P51: cmnlib64bak (001B6200, 00000800) 1024 KB P52: keymasterbak (001B6A00, 00000800) 1024 KB P53: apdp (001B8000, 00000200) 256 KB P54: msadp (001B8200, 00000200) 256 KB P55: dpo (001B8400, 00000010) 8 KB P56: logdump (001B8410, 00020000) 64 MB P57: vm-kystore (001D8410, 00000800) 1024 KB P58: vm-data (001D8C10, 00005000) 10 MB P59: hyp (001E0000, 00004000) 8 MB P60: vm-system (001E4000, 00020000) 64 MB P61: vm-linux (00204000, 00010000) 32 MB P62: system (00214000, 006B4800) 3433 MB P63: vendor (008C8800, 0020FB00) 1055 MB P64: userdata (00ADC000, 01242FDF) 9.131 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst1_0xa028_0xc00_07_02_2022_11_08_02.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_modemst2_0xac28_0xc00_07_02_2022_11_08_02.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_fsg_0x4c040_0x2000_07_02_2022_11_08_02.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.2; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 2179072 Number of sectors : 7030784 Build ID : PKQ1.190319.001 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : S88051AA1-user 9 PKQ1.190319.001 eng.root.20191113.124726 release-keys --------------------------------------------------------------- Selected file: C:/Users/AR/Desktop/realme c2/RMX1805EX-RMX1811_11_A.62_191113_4d8c29bb/Extracted/rawprogram0.xml. Selected file: C:/Users/AR/Desktop/realme c2/RMX1805EX-RMX1811_11_A.62_191113_4d8c29bb/Extracted/patch0.xml. Switched to user area. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. Writing. Please wait... Write data verification is enabled. Writing partition oppodycnvbk... Done. Writing partition oppostanvbk... Done. Writing partition persist... Done. Writing partition opporeserve1... Done. Writing partition opporeserve2... Done. Writing partition sbl1... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition devcfg... Done. Writing partition sbl1bak... Done. Writing partition rpmbak... Done. Writing partition tzbak... Done. Writing partition devcfgbak... Done. Writing partition dsp... Done. File C:/Users/AR/Desktop/realme c2/RMX1805EX-RMX1811_11_A.62_191113_4d8c29bb/Extracted/sec.dat open failed. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition modem... Done. Writing partition dtbo... Done. Writing partition vbmeta... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition LOGO... Done. Writing partition DRIVER... Done. Writing partition cache... Done. Writing partition mdtp... Done. Writing partition lksecapp... Done. Writing partition cmnlib... Done. Writing partition cmnlib64... Done. Writing partition keymaster... Done. Writing partition lksecappbak... Done. Writing partition cmnlibbak... Done. Writing partition cmnlib64bak... Done. Writing partition keymasterbak... Done. Writing partition apdp... Done. Writing partition system... Done. Writing partition vendor... Done. Writing partition userdata... Done. Switched to user area. Writing MBR...Done. Writing primary GPT...Done. Writing partition BackupGPT... Done. Writing finished. SW: 2.2.2; FW: 1.24. Disconnected. |
The Following User Says Thank You to GSM AR For This Useful Post: |
03-04-2022, 18:52 | #1106 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | Oppo a15 s cph2179_11_a.25 rpmb read done Code: Welcome to Medusa Pro Software version 2.2.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Please, power phone OFF (press and hold 'Vol+' or 'Vol-' button) and connect USB cable. Connecting... Detecting Chip Version... MT6765 HW Version : 8A00.CA00.0000.0000 Brom Version: 5 Trying to download resource files... Please, be patient! Sending Download Agent... DA successfully sent Synchronizing with DA... Initializing Memory Flash... Initialization completed Sending Loader... EMMC rpmb size : 16 Mb EMMC boot1 size : 4 Mb EMMC boot2 size : 4 Mb EMMC gp1 size : 0 Mb EMMC gp2 size : 0 Mb EMMC gp3 size : 0 Mb EMMC gp4 size : 0 Mb EMMC user area size : 59640 Mb Device : Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) Connect successful. --------------------------------------------------------------- SW: 2.2.4; FW: . P00: GPT (00000000, 00008000) 32 KB P01: boot_para (00008000, 00100000) 1024 KB P02: recovery (00108000, 06200000) 98 MB P03: para (06308000, 00080000) 512 KB P04: opporeserve1 (06388000, 00800000) 8 MB P05: opporeserve2 (06B88000, 08000000) 128 MB P06: opporeserve3 (0EB88000, 04000000) 64 MB P07: oppo_custom (12B88000, 00100000) 1024 KB P08: expdb (12C88000, 01400000) 20 MB P09: vbmeta_system (14088000, 00800000) 8 MB P10: vbmeta_vendor (14888000, 00800000) 8 MB P11: frp (15088000, 00100000) 1024 KB P12: nvcfg (15188000, 02000000) 32 MB P13: nvdata (17188000, 04000000) 64 MB P14: md_udc (1B188000, 0169A000) 22.6 MB P15: metadata (1C822000, 02000000) 32 MB P16: protect1 (1E822000, 00800000) 8 MB P17: protect2 (1F022000, 00FDE000) 15.87 MB P18: seccfg (20000000, 00800000) 8 MB P19: persist (20800000, 03000000) 48 MB P20: sec1 (23800000, 00200000) 2048 KB P21: proinfo (23A00000, 00300000) 3072 KB P22: md1img (23D00000, 06400000) 100 MB P23: spmfw (2A100000, 00100000) 1024 KB P24: scp1 (2A200000, 00100000) 1024 KB P25: scp2 (2A300000, 00100000) 1024 KB P26: sspm_1 (2A400000, 00100000) 1024 KB P27: sspm_2 (2A500000, 00100000) 1024 KB P28: gz1 (2A600000, 01000000) 16 MB P29: gz2 (2B600000, 01000000) 16 MB P30: nvram (2C600000, 04000000) 64 MB P31: cdt_engineering (30600000, 00800000) 8 MB P32: ocdt (30E00000, 00800000) 8 MB P33: special_preload (31600000, 1C000000) 448 MB P34: my_custom (4D600000, 04000000) 64 MB P35: lk (51600000, 00400000) 4 MB P36: lk2 (51A00000, 00400000) 4 MB P37: boot (51E00000, 02000000) 32 MB P38: logo (53E00000, 00800000) 8 MB P39: dtbo (54600000, 00800000) 8 MB P40: tee1 (54E00000, 00500000) 5 MB P41: tee2 (55300000, 00500000) 5 MB P42: super (55800000, 1F2000000) 7.781 GB P43: vbmeta (247800000, 00800000) 8 MB P44: cache (248000000, 1B000000) 432 MB P45: userdata (263000000, C28CFBE00) 48.64 GB P46: otp (E8BCFBE00, 02B00000) 43 MB P47: flashinfo (E8E7FBE00, 01000000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/_nvdata_0xb8c40_0x20000_04_03_2022_18_20_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:10 SW: 2.2.4; FW: . Partition table has been found on device. Switched to RPMB. Opening H:/OPPO/_04_03_2022_18_21_08.bin file... Reading. Please wait... Please, disconnect device to see changes!. Disconnected. Done. Elapsed time 00:04:03 SW: 2.2.4; FW: . |
The Following User Says Thank You to rebainoor For This Useful Post: |
03-11-2022, 19:13 | #1107 (permalink) |
Junior Member Join Date: Aug 2013 Location: Morocco
Member: 1994122 Status: Offline Sonork: 100.1618421 Thanks Meter: 11 | A20s u3 FRP done in reset FRP tap failed solution erase persistent ----------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1687552 Number of sectors : 7864320 Build ID : RP1A.200720.012 Display Build ID : RP1A.200720.012.A207FXXU3CUL1 Release ID : 11 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a20sxx-user 11 RP1A.200720.012 A207FXXU3CUL1 release-keys --------------------------------------------------------------- Save to C:/Program Files (x86)/Medusa Pro Software/frp/New folder/Samsung eMMC GD6BMB_11_03_2022__18_33_45.mpt file... Reading partition persistent... Done. Reading is finished. SW: 2.2.4; FW: 1.24. Erasing partition persistent... Done. Erasing is finished. SW: 2.2.4; FW: 1.24. |
The Following 2 Users Say Thank You to abdo-gsm For This Useful Post: |
06-26-2022, 20:21 | #1108 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Xiaomi Redmi 7 onclite Unlock bootloader successfully done. First connect: Code: Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Hynix eMMC hB8aP Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68423861503E016D3529814697 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hB8aP Product revision : 0.1 Product serial number : (hex) 6D352981 Manufacturing date : 04/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hB8aP_26_06_2022_21_13_13.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.7; FW: 2.00. P00: GPT (00000000, 00000028) 20 KB P01: fsc (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: dpo (00000048, 00000010) 8 KB P04: switch (00000058, 00000020) 16 KB P05: sec (00000078, 00000048) 36 KB P06: DDR (000000C0, 00000080) 64 KB P07: config (00000140, 00000080) 64 KB P08: limits (000001C0, 00000040) 32 KB P09: lksecapp (00000200, 00000100) 128 KB P10: lksecappbak (00000300, 00000100) 128 KB P11: devcfg (00000400, 00000200) 256 KB P12: devcfgbak (00000600, 00000200) 256 KB P13: apdp (00000800, 00000200) 256 KB P14: msadp (00000A00, 00000200) 256 KB P15: rpm (00000C00, 00000400) 512 KB P16: rpmbak (00001000, 00000400) 512 KB P17: mota (00001400, 00000400) 512 KB P18: keystore (00001800, 00000400) 512 KB P19: syscfg (00001C00, 00000400) 512 KB P20: misc (00002000, 00000800) 1024 KB P21: dip (00002800, 00000800) 1024 KB P22: sbl1 (00003000, 00000800) 1024 KB P23: sbl1bak (00003800, 00000800) 1024 KB P24: cmnlib (00004000, 00000800) 1024 KB P25: cmnlibbak (00004800, 00000800) 1024 KB P26: cmnlib64 (00005000, 00000800) 1024 KB P27: cmnlib64bak (00005800, 00000800) 1024 KB P28: keymaster (00006000, 00000800) 1024 KB P29: keymasterbak (00006800, 00000800) 1024 KB P30: aboot (00007000, 00001000) 2048 KB P31: abootbak (00008000, 00001000) 2048 KB P32: fsg (00009000, 00001000) 2048 KB P33: tz (0000A000, 00002000) 4 MB P34: tzbak (0000C000, 00002000) 4 MB P35: mcfg (0000E000, 00002000) 4 MB P36: modemst1 (00010000, 00004000) 8 MB P37: modemst2 (00014000, 00004000) 8 MB P38: devinfo (00018000, 00004000) 8 MB P39: devbk1 (0001C000, 00004000) 8 MB P40: dsp (00020000, 00008000) 16 MB P41: oops (00028000, 00008000) 16 MB P42: splash (00030000, 00010000) 32 MB P43: persist (00040000, 00020000) 64 MB P44: persistbak (00060000, 00020000) 64 MB P45: mdtp (00080000, 00010000) 32 MB P46: logdump (00090000, 00030000) 96 MB P47: boot (000C0000, 00020000) 64 MB P48: recovery (000E0000, 00020000) 64 MB P49: modem (00100000, 0002C000) 88 MB P50: logo (0012C000, 0000F800) 31 MB P51: dtbo (0013B800, 00004000) 8 MB P52: vbmeta (0013F800, 00000800) 1024 KB P53: miuidump (00140000, 00040000) 128 MB P54: cache (00180000, 00080000) 256 MB P55: oem (00200000, 00080000) 256 MB P56: cust (00280000, 001A0000) 832 MB P57: vendor (00420000, 00200000) 1024 MB P58: system (00620000, 00700000) 3584 MB P59: userdata (00D20000, 02D1DFDF) 22.56 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hB8aP_fsg_0x9000_0x1000_26_06_2022_21_13_13.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.7; FW: 2.00. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hB8aP_modemst1_0x10000_0x4000_26_06_2022_21_13_13.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.4.7; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hB8aP_modemst2_0x14000_0x4000_26_06_2022_21_13_13.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.4.7; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 6422528 Number of sectors : 7340032 Device Manufacturer : Xiaomi Build ID : QKQ1.191008.001 Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description 2 : V11.0.2.0.QFLMIXM --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 93530. Disconnected. Code: Switched to boot area partition 1. Opening C:/1/7/boot1/Hynix eMMC hB8aP_26_06_2022_21_13_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.7; FW: 2.00. Switched to boot area partition 2. Opening C:/1/7/b2/Hynix eMMC hB8aP_26_06_2022_21_14_12.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.7; FW: 2.00. Switched to user area. Opening C:/1/7/Hynix eMMC hB8aP_26_06_2022_21_14_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.7; FW: 2.00. Opening C:/1/7/Hynix eMMC hB8aP_26_06_2022_21_14_45.bin file... Reading. Please wait... Code: Switched to boot area partition 1. Added partition BOOT1 to constructor file. Switched to boot area partition 2. Added partition BOOT2 to constructor file. Switched to user area. Added partition GPT to constructor file. Added partition fsc to constructor file. Added partition ssd to constructor file. Added partition dpo to constructor file. Added partition switch to constructor file. Added partition sec to constructor file. Added partition DDR to constructor file. Added partition config to constructor file. Added partition limits to constructor file. Added partition lksecapp to constructor file. Added partition lksecappbak to constructor file. Added partition devcfg to constructor file. Added partition devcfgbak to constructor file. Added partition apdp to constructor file. Added partition msadp to constructor file. Added partition rpm to constructor file. Added partition rpmbak to constructor file. Added partition mota to constructor file. Added partition keystore to constructor file. Added partition syscfg to constructor file. Added partition misc to constructor file. Added partition dip to constructor file. Added partition sbl1 to constructor file. Added partition sbl1bak to constructor file. Added partition cmnlib to constructor file. Added partition cmnlibbak to constructor file. Added partition cmnlib64 to constructor file. Added partition cmnlib64bak to constructor file. Added partition keymaster to constructor file. Added partition keymasterbak to constructor file. Added partition aboot to constructor file. Added partition abootbak to constructor file. Added partition tz to constructor file. Added partition tzbak to constructor file. Added partition mcfg to constructor file. Added partition devinfo to constructor file. Added partition devbk1 to constructor file. Added partition dsp to constructor file. Added partition oops to constructor file. Added partition splash to constructor file. Added partition persist to constructor file. Added partition persistbak to constructor file. Added partition mdtp to constructor file. Added partition logdump to constructor file. Added partition boot to constructor file. Added partition recovery to constructor file. Added partition modem to constructor file. Added partition logo to constructor file. Added partition dtbo to constructor file. Added partition vbmeta to constructor file. Added partition miuidump to constructor file. SRF "C:/1/7/srf/Xiaomi_Redmi 7.srf" has been installed successfully. Code: Selected file: C:/1/Bootloader File/Redmi7 unlock boot/step1/rawprogram0.xml Selected file: C:/1/Bootloader File/Redmi7 unlock boot/step1/patch0.xml. Selected rawprogram XML file: C:/1/Bootloader File/Redmi7 unlock boot/step1/rawprogram0.xml. Switched to user area. Backuping. Please wait... Backuping finished. Writing. Please wait... Write data verification is enabled. Writing partition 3... Done. Writing partition 4... Done. Writing partition 4... Done. Switched to user area. Writing MBR...Done. Writing primary GPT...Done. Writing finished. SW: 2.2.4.7; FW: 2.00. Disconnected. Code: c:\adb>fastboot oem device-info ... (bootloader) Device tampered: false (bootloader) Device unlocked: true (bootloader) Device critical unlocked: true (bootloader) Charger screen enabled: true (bootloader) Display panel: (bootloader) Device Verity Mode: enforcing (bootloader) Debug policy enable: false OKAY [ 0.075s] finished. total time: 0.076s |
The Following 3 Users Say Thank You to Dr_Wolodya For This Useful Post: |
12-03-2022, 21:06 | #1109 (permalink) |
Junior Member Join Date: Aug 2020 Location: reynosa Age: 23
Member: 2964745 Status: Offline Thanks Meter: 1 | Remove mdm payjoy and frp after deleting these partitions flash firmware in download mode Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 737280 Number of sectors : 10854400 Build ID : RP1A.200720.012 Display Build ID : RP1A.200720.012.A217FXXU5CUD4 Release ID : 11 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a21snsxx-user 11 RP1A.200720.012 A217FXXU5CUD4 release-keys --------------------------------------------------------------- Partition table has been found on device. Erasing partition param... Done. Erasing partition misc... Done. Erasing partition persistent... Done. Erasing is finished. SW: 2.2.4.7; FW: 1.24. |
12-03-2022, 21:06 | #1110 (permalink) |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
