02-11-2021, 19:44 | #1 (permalink) |
Freak Poster Join Date: Aug 2017
Member: 2748254 Status: Offline Thanks Meter: 87 | User Data Extraction Help! On NOKIA TA-1024 [Answered] Today I got liquid damaged NOKIA TA-1024 that is completely dead! the owner wanted from me to extract all pictures and data if is possible! I removed the EMMC chip and with Medusa i make extraction of userdata.bin but i cannot open it! So seems that is encrypted! Is there any method to make extract this data from the userdata.bin file? In Medusa Software there is no info if the memory is encrypted or no! And will be good idea to add info message on every reading of EMMC/UFS Chip to show it is encrypted or not! In my case is not showing nothing! In this case is it possible to solder this EMMC on other same model working motherboard in order to start the phone and make extract the data? Hopefully you can help me! The data is so needed to my customer! Here is the Log: Model Settings: Interface : eMMC Voltage : 2.4V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A5357810A5A40B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.5 Product serial number : (hex) 357810A5 Manufacturing date : 10/2017 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG4a2_11_02_2021_19_21_33.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0; FW: 1.24. P00: GPT (00000000, 00001000) 2048 KB P01: modemst1 (00001000, 00000C00) 1536 KB P02: modemst2 (00002000, 00000C00) 1536 KB P03: fsg (00003000, 00000C00) 1536 KB P04: fsc (00004000, 00000002) 1024 b P05: securefs (00004002, 00004000) 8 MB P06: rf_nv (00008002, 00001000) 2048 KB P07: deviceinfo (00009002, 00000800) 1024 KB P08: modem (00020000, 0002A000) 84 MB P09: ssd (00060000, 00000010) 8 KB P10: sbl1 (00060010, 00000400) 512 KB P11: sbl1bak (00060410, 00000400) 512 KB P12: rpm (00060810, 00000400) 512 KB P13: rpmbak (00060C10, 00000400) 512 KB P14: tz (00061010, 00001000) 2048 KB P15: tzbak (00062010, 00001000) 2048 KB P16: devcfg (00063010, 00000200) 256 KB P17: devcfgbak (00063210, 00000200) 256 KB P18: dsp (00063410, 00008000) 16 MB P19: DDR (00080000, 00000040) 32 KB P20: sec (00080040, 00000020) 16 KB P21: splash (000A0000, 00005800) 11 MB P22: aboot (000C0000, 00000800) 1024 KB P23: abootbak (000C0800, 00000800) 1024 KB P24: boot (000C1000, 00020000) 64 MB P25: recovery (000E1000, 00020000) 64 MB P26: devinfo (00101000, 00000800) 1024 KB P27: reserved (00120000, 00008000) 16 MB P28: ftmboot (00128000, 00020000) 64 MB P29: cust_nv (00148000, 00001000) 2048 KB P30: default_nv (00149000, 00001000) 2048 KB P31: hwcfg (0014A000, 00000800) 1024 KB P32: sutinfo (0014A800, 00000002) 1024 b P33: systeminfo (0014A802, 00000200) 256 KB P34: ftmlog (0014AA02, 00010000) 32 MB P35: box (0015AA02, 00004000) 8 MB P36: multi_splash (0015EA02, 00008000) 16 MB P37: hidden (00166A02, 00014000) 40 MB P38: cda (0017AA02, 00004000) 8 MB P39: reserved_bak (0017EA02, 00008000) 16 MB P40: persist (00186A02, 00010000) 32 MB P41: misc (00196A02, 00000800) 1024 KB P42: keystore (00197202, 00000400) 512 KB P43: config (00197602, 00000040) 32 KB P44: oem (00197642, 00080000) 256 MB P45: limits (00220000, 00000040) 32 KB P46: mota (00240000, 00000400) 512 KB P47: dip (00240400, 00000800) 1024 KB P48: mdtp (00240C00, 00010000) 32 MB P49: syscfg (00250C00, 00000400) 512 KB P50: mcfg (00251000, 00002000) 4 MB P51: cmnlib (00260000, 00000200) 256 KB P52: cmnlibbak (00260200, 00000200) 256 KB P53: cmnlib64 (00260400, 00000200) 256 KB P54: cmnlib64bak (00260600, 00000200) 256 KB P55: keymaster (00260800, 00000200) 256 KB P56: keymasterbak (00260A00, 00000200) 256 KB P57: apdp (00280000, 00000200) 256 KB P58: msadp (00280200, 00000200) 256 KB P59: dpo (00280400, 00000010) 8 KB P60: system (002A0000, 007FF800) 4095 MB P61: cache (00AA0000, 00080000) 256 MB P62: logdump (00B20000, 00020000) 64 MB P63: userdata (00B40000, 01219FDF) 9.051 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst1_0x1000_0xc00_11_02_2021_19_21_33.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.0; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_modemst2_0x2000_0xc00_11_02_2021_19_21_33.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.0; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG4a2_fsg_0x3000_0xc00_11_02_2021_19_21_33.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.0; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 2752512 Number of sectors : 8386560 Device Manufacturer : FIH Build ID : PKQ1.181105.001 Display Build ID : 00WW_6_19B Release ID : 9 Device Model : FIH-D1C-FIH Device Name : D1C_00WW_FIH Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : TA-1024_00WW-user 9 PKQ1.181105.001 00WW_6_19B release-keys --------------------------------------------------------------- |
02-11-2021, 20:12 | #2 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Russia,Yekaterinburg
Member: 1363017 Status: Offline Thanks Meter: 44 | The data is encrypted by a specific processor. Re-soldering only the memory chip will not give a result, you need to transfer a pair of processor-memory to the working board |
