04-03-2020, 23:32 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: algeria
Member: 1480336 Status: Offline Sonork: 100.1606959 Thanks Meter: 76 | xiaomi offline flash i try redmi 8a write firmware but stuck in com9008 Welcome to Medusa Pro Software version 2.0.6. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QD63MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100514436334D420196929B0496F7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QD63MB Product revision : 0.1 Product serial number : (hex) 96929B04 Manufacturing date : 09/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 3014656 Number of sectors : 8388608 Device Manufacturer : Xiaomi Build ID : PKQ1.190319.001 Display Build ID : ZQL2116-olivelite-build-20191219025522 Release ID : 9 Device Model : Redmi 8A Device Name : olivelite Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : olivelite-user 9 PKQ1.190319.001 V11.0.3.0.PCPMIXM release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QD63MB_03_04_2020_01_07_55.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.6; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: fsc (00000028, 00000010) 8 KB P02: ssd (00000038, 00000010) 8 KB P03: dpo (00000048, 00000010) 8 KB P04: sec (00000058, 00000020) 16 KB P05: DDR (00000078, 00000040) 32 KB P06: limits (000000B8, 00000040) 32 KB P07: config (000000F8, 00000040) 32 KB P08: bk1 (00000138, 00000048) 36 KB P09: bk2 (00000180, 00000080) 64 KB P10: vbmeta (00000200, 00000080) 64 KB P11: vbmetabak (00000280, 00000080) 64 KB P12: bk3 (00000300, 00000100) 128 KB P13: devcfg (00000400, 00000200) 256 KB P14: devcfgbak (00000600, 00000200) 256 KB P15: apdp (00000800, 00000200) 256 KB P16: msadp (00000A00, 00000200) 256 KB P17: sbl1 (00000C00, 00000400) 512 KB P18: sbl1bak (00001000, 00000400) 512 KB P19: rpm (00001400, 00000400) 512 KB P20: rpmbak (00001800, 00000400) 512 KB P21: mota (00001C00, 00000400) 512 KB P22: keystore (00002000, 00000400) 512 KB P23: syscfg (00002400, 00000400) 512 KB P24: cmnlib (00002800, 00000800) 1024 KB P25: cmnlibbak (00003000, 00000800) 1024 KB P26: cmnlib64 (00003800, 00000800) 1024 KB P27: cmnlib64bak (00004000, 00000800) 1024 KB P28: keymaster (00004800, 00000800) 1024 KB P29: keymasterbak (00005000, 00000800) 1024 KB P30: misc (00005800, 00000800) 1024 KB P31: aboot (00006000, 00000800) 1024 KB P32: abootbak (00006800, 00000800) 1024 KB P33: dip (00007000, 00000800) 1024 KB P34: bk4 (00007800, 00000800) 1024 KB P35: tz (00008000, 00001000) 2048 KB P36: tzbak (00009000, 00001000) 2048 KB P37: mcfg (0000A000, 00002000) 4 MB P38: devinfo (0000C000, 00004000) 8 MB P39: dtbo (00010000, 00004000) 8 MB P40: dtbobak (00014000, 00004000) 8 MB P41: modemst1 (00018000, 00004000) 8 MB P42: modemst2 (0001C000, 00004000) 8 MB P43: fsg (00020000, 00004000) 8 MB P44: gsort (00024000, 00004000) 8 MB P45: splash (00028000, 00008000) 16 MB P46: dsp (00030000, 00008000) 16 MB P47: dspbak (00038000, 00008000) 16 MB P48: persist (00040000, 00010000) 32 MB P49: persistbak (00050000, 00010000) 32 MB P50: mdtp (00060000, 00010000) 32 MB P51: mdtpbak (00070000, 00010000) 32 MB P52: boot (00080000, 00020000) 64 MB P53: recovery (000A0000, 00020000) 64 MB P54: logdump (000C0000, 00020000) 64 MB P55: exaid (000E0000, 000C0000) 384 MB P56: minidump (001A0000, 00040000) 128 MB P57: cache (001E0000, 000C0000) 384 MB P58: modem (002A0000, 00040000) 128 MB P59: system (002E0000, 00800000) 4 GB P60: vendor (00AE0000, 00200000) 1024 MB P61: cust (00CE0000, 001A0000) 832 MB P62: userdata (00E80000, 02BBDFDF) 21.87 GB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/QD63MB_modemst1_0x18000_0x4000_03_04_2020_01_07_55 .bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.0.6; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/QD63MB_modemst2_0x1c000_0x4000_03_04_2020_01_07_55 .bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.0.6; FW: 1.24. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/QD63MB_fsg_0x20000_0x4000_03_04_2020_01_07_55.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.0.6; FW: 1.24. Partition table has been found on device. Selected file: D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/rawprogram0_BLANK.xml. Selected file: D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/rawprogram0.xml. Partition table has been found on device. Partition table is found from file D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/gpt_main0.bin. Partition table was not found in file D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/config.bin. Partition table was not found in file D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/gpt_backup0.bin. Partition table was not found in file D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/NON-HLOS.bin. Selected file: D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/rawprogram0.xml. Selected file: D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/partition.xml. Please select file. Selected file: D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/rawprogram0.xml. Selected file: D:/flash/redmi/redmi 8a/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn_81a70913b5/olivelite_images_V11.0.8.0.PCPCNXM_20200225.0000.0 0_9.0_cn/images/patch0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. #grenWriting. Please wait... Write data verification is enabled. Writing partition sec... Done. Writing partition vbmeta... Done. Writing partition vbmetabak... Done. Writing partition devcfg... Done. Writing partition devcfgbak... Done. Writing partition apdp... Done. Writing partition msadp... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition cmnlib... Done. Writing partition cmnlibbak... Done. Writing partition cmnlib64... Done. Writing partition cmnlib64bak... Done. Writing partition keymaster... Done. Writing partition keymasterbak... Done. Writing partition misc... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition dtbo... Done. Writing partition dtbobak... Done. Writing partition splash... Done. Writing partition dsp... Done. Writing partition dspbak... Done. Writing partition mdtp... Done. Writing partition mdtpbak... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition cache... Done. Writing partition modem... Done. Writing partition system... Done. Writing partition vendor... Done. Writing partition cust... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 2.0.6; FW: 1.24. Disconnected. |
The Following User Says Thank You to fethirx For This Useful Post: |
