11-19-2020, 21:06 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Sandisk eMMC DF4032 full Smart report done Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Operations with eMMC restricted(Bus Mode : 1b) Connecting... Device : Sandisk eMMC DF4032 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 450100444634303332019B8A809CA30F Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DF4032 Product revision : 0.1 Product serial number : (hex) 9B8A809C Manufacturing date : 10/2016 --------------------------------------------------------------- CSD Info CSD : D00F00328F5903FFFFFFFFEF8A404023 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 9584640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DF4032_19_11_2020_20_40_08.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.6; FW: 2.00. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 0000C000) 24 MB P03: para (0000C840, 00000400) 512 KB P04: expdb (0000CC40, 0000A000) 20 MB P05: frp (00016C40, 00000800) 1024 KB P06: nvcfg (00017440, 00004000) 8 MB P07: nvdata (0001B440, 00010000) 32 MB P08: metadata (0002B440, 00010000) 32 MB P09: protect1 (0003B440, 00004000) 8 MB P10: protect2 (0003F440, 00004BC0) 9.469 MB P11: seccfg (00044000, 00004000) 8 MB P12: persist (00048000, 00018000) 48 MB P13: sec1 (00060000, 00001000) 2048 KB P14: proinfo (00061000, 00001800) 3072 KB P15: efuse (00062800, 00000400) 512 KB P16: md1img (00062C00, 00020000) 64 MB P17: md1dsp (00082C00, 00008000) 16 MB P18: spmfw (0008AC00, 00000800) 1024 KB P19: mcupmfw (0008B400, 00000800) 1024 KB P20: gz1 (0008BC00, 00008000) 16 MB P21: gz2 (00093C00, 00008000) 16 MB P22: nvram (0009BC00, 00002800) 5 MB P23: lk (0009E400, 00000800) 1024 KB P24: lk2 (0009EC00, 00000800) 1024 KB P25: loader_ext1 (0009F400, 00000080) 64 KB P26: loader_ext2 (0009F480, 00000080) 64 KB P27: boot (0009F500, 0000C000) 24 MB P28: logo (000AB500, 00004000) 8 MB P29: odmdtbo (000AF500, 00008000) 16 MB P30: tee1 (000B7500, 00002800) 5 MB P31: tee2 (000B9D00, 00006300) 12.38 MB P32: vendor (000C0000, 000CC000) 408 MB P33: system (0018C000, 00228000) 1104 MB P34: cache (003B4000, 00038000) 112 MB P35: userdata (003EC000, 03649FDF) 27.14 GB P36: flashinfo (03A35FDF, 00008000) 16 MB --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1622016 Number of sectors : 2260992 Device Manufacturer : Condor Build ID : O11019 Display Build ID : Plume_L1_Plus Release ID : 8.1.0 Device Model : Plume L1 Plus Device Name : Plume_L1_Plus Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : full_k39tv1_bsp_1g-user 8.1.0 O11019 1522249311 release-keys --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 7249. Smart report info: Average Erase Cycles Enhanced : 0 Average Erase Cycles SLC : 423 Average Erase Cycles MLC : 12 Read reclaim count Enhanced : 0 Read reclaim count SLC : 0 Read reclaim count MLC : 5865 Bad Block Manufactory : 22 Bad Block Runtime Enhanced : 0 Bad Block Runtime SLC : 0 Bad Block Runtime MLC : 0 Patch Trial Count : 0 Patch Release Date : JUN 15 2016 Patch Release Time : 07:06:43 Cumulative Write data size : 4585 Number of occurrences of VCC voltage drops : 511 Number of occurrences of VCC voltage droops : 1 Number of failures recover new host data after Power Loss : 0 Total Recovery Operations After Voltage Droop : 0 Cumulative write data size in SmartSLC mode : 4553 Cumulative write data size in SLC mode on MLC-designated blocks : 166 Indication that cumulative hybrid written data crossed its allowed limit : 0 Average erased count of hybrid blocks : 1 DEVICE_LIFE_TIME_EST_TYP_B : 0% - 10% device life time used DEVICE_LIFE_TIME_EST_TYP_A : 0% - 10% device life time used PRE_EOL_INFO : Normal SW: 2.1.6; FW: 2.00. |
The Following 4 Users Say Thank You to rebainoor For This Useful Post: |
