pls help me p1010 repair can't connect p1010 soft ware open ok noproblem after conect jtag cable scan software unknow cpuid=0................. what problem pls help me my p1010 dead after flash p1000 firmware BR ANW |
You have problem in JTAG connections most likely Check your jtag connections and do solderings accordingly to it Best regards |
my ort tool v1.69 open see 1.vref=0.330v 2.TCK=00RTCK 3.IOVolt not seen its problem? help me BR ANW |
need conect battery and usb cable ? BR ANW |
check your connection ,yes use battery and usb cable ... |
bro pls upload omap 3630 driver. BR ANW hi after conect battry found new hardware and need OMAP3630 driver????? BR ANW pls step by step guide because i am new user.help me BR ANW |
thanks bro reply ort software open ok no problem after 1.connect usb cable with computer 2.check jtag connection ok 3.jtag cable join ort box after scan<unknow> 4.reconnect ort box not found bro need power on button? WBR ANW |
You have to connect usb cable , if you connected usb cable and battery It should work on scanning at least you should read some CPU ID ! Otherwise there is problem with your connections . Best Regards Oz |
bro need press power button? BR ANW |
1-soldering all pin of G-tag cable to PCB 2-insert usb cable to PCB 3-connect battrie or any power adapter ......... 4-copy you repaire file to phone folder 4-OPEN software ort-plus 1.69 5-insert ort-cable to you box (ort-j-tag) 6-make SCAN if enjoy you show info about your CPU then chouse (one bouton repaire) TAB then chouse you model and select your repaire file then make repaire all enjoy and if get unknown CPU try this: just if attach battrie in same time make scan then retry many time |
bro pls upload picture jtag colour cable pinout which pin1 which pin2? really not exprence jtag box. pls help me bro BR ANW |
this cable or box? BR ANW |
this is cable pinout !!!! |
