S5560i can't repair! new security ? the phone connects only by selecting MSM7227: Code: Vref:3.062V found bad block 0 found bad block 1 found bad block 2 ..etc I think this one has new security should I try full dump 256mb ? thanks |
Do not select MSM7227 it is a broadcomm phone ! Connect USB Cable and HOLD the power on button while doing it . Best Regards |
thank you for answer should I select autobrand ? and what should I select in TCK ? please tell me all step by step Note :I already did erase selecting 256MB |
someone tell me all step by step |
I selected model autobrand,and tck:rtck,02mhz,04mhz...always with usb connected but phone can't connect ! it only connects selecting s5660 or msm7227 anytrick to get it connected ? |
You just have to keep it in auto model ! Make JTAG Connections , Connect Battery , Connect USB Cable , if need power on phone Click Scan ! After phone being detected , you just write the appropiate dump ! It is very easy operations and i think you fail with your connections ? Br |
