a015g u5 dead i try to remove frp with easy jtag tool, after remove frp phone not on, only detect to pc as qualcom hs-usb qdloader 9008, how to revive phone |
i tried by witting the bl file with the same binary, after writing the phone not going to download mode, still in brick mode |
Arrange dump then write latest binary bl |
i already tried with latest binary bl file but there is no change 3/17/2023 4:32:32 PM> 3/17/2023 4:32:32 PM> eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) 3/17/2023 4:32:36 PM> Microsoft Windows 8 (64 bit) build 7600 (10.0.19041.1741) 3/17/2023 4:32:36 PM> 3/17/2023 4:32:36 PM> Looking for EasyJTAG box... 3/17/2023 4:32:36 PM> EasyJTAG API ver. 3403 3/17/2023 4:32:39 PM> OpenUSB returned = 0 3/17/2023 4:32:40 PM> EasyJTAG Box Serial = 1414110FBFBA99FD 3/17/2023 4:32:41 PM> Card Serial = AA5D6F3E 3/17/2023 4:32:41 PM> EasyJTAG Box Firmware = 1.6300 3/17/2023 4:32:41 PM> 3/17/2023 4:32:55 PM> Failed to connect to the server 3/17/2023 4:34:08 PM> 3/17/2023 4:34:08 PM> Looking for EasyJTAG box... 3/17/2023 4:34:08 PM> EasyJTAG API ver. 3403 3/17/2023 4:34:08 PM> Setting IO Levels to 1.8V 3/17/2023 4:34:08 PM> Setting frequence to 21 MHz 3/17/2023 4:34:09 PM> EasyJTAG Box Serial = 1414110FBFBA99FD 3/17/2023 4:34:09 PM> EasyJTAG Box Firmware = 1.6300 3/17/2023 4:34:12 PM> HiPower mode is ON 3/17/2023 4:34:12 PM> Setting frequence to 21 MHz 3/17/2023 4:34:12 PM> CMD Pullup Level: 1907 mV 3/17/2023 4:34:12 PM> CMD Active Level: 2083 mV 3/17/2023 4:34:12 PM> eMMC Init returned = 0 3/17/2023 4:34:12 PM> EMMC Device Information : 3/17/2023 4:34:12 PM> EMMC CID: 150100514536334D4200D98B68BC37DC 3/17/2023 4:34:12 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 3/17/2023 4:34:12 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D98B68BC , rev. 0x00 3/17/2023 4:34:12 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2020 3/17/2023 4:34:12 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 3/17/2023 4:34:12 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/17/2023 4:34:12 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 110808 , Response: Not Clean 3/17/2023 4:34:12 PM> EMMC Permanent Write Protection: No 3/17/2023 4:34:12 PM> EMMC Temporary Write Protection: No 3/17/2023 4:34:12 PM> Extended CSD Information : 3/17/2023 4:34:12 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/17/2023 4:34:12 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 3/17/2023 4:34:12 PM> Boot Bus Config: 0x00 , width 1bit 3/17/2023 4:34:12 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 3/17/2023 4:34:12 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/17/2023 4:34:12 PM> Device supports partitioning features 3/17/2023 4:34:12 PM> Device can have enhanced technological features in partitions and user data area 3/17/2023 4:34:12 PM> Device can have extended partitions attribute 3/17/2023 4:34:12 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/17/2023 4:34:12 PM> Backup saved: QE63MB_D98B68BC_20230317_163412.extcsd 3/17/2023 4:34:12 PM> EMMC Init completed. 3/17/2023 4:34:12 PM> 3/17/2023 4:35:17 PM> Looking for EasyJTAG box... 3/17/2023 4:35:17 PM> EasyJTAG API ver. 3403 3/17/2023 4:35:17 PM> Setting IO Levels to 1.8V 3/17/2023 4:35:17 PM> Setting frequence to 21 MHz 3/17/2023 4:35:18 PM> EasyJTAG Box Serial = 1414110FBFBA99FD 3/17/2023 4:35:18 PM> EasyJTAG Box Firmware = 1.6300 3/17/2023 4:35:20 PM> HiPower mode is ON 3/17/2023 4:35:21 PM> Setting frequence to 21 MHz 3/17/2023 4:35:21 PM> CMD Pullup Level: 1907 mV 3/17/2023 4:35:21 PM> CMD Active Level: 2093 mV 3/17/2023 4:35:21 PM> eMMC Init returned = 0 3/17/2023 4:35:21 PM> EMMC Device Information : 3/17/2023 4:35:21 PM> EMMC CID: 150100514536334D4200D98B68BC37DC 3/17/2023 4:35:21 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 3/17/2023 4:35:21 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D98B68BC , rev. 0x00 3/17/2023 4:35:21 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2020 3/17/2023 4:35:21 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 3/17/2023 4:35:21 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/17/2023 4:35:21 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 110808 , Response: Not Clean 3/17/2023 4:35:21 PM> EMMC Permanent Write Protection: No 3/17/2023 4:35:21 PM> EMMC Temporary Write Protection: No 3/17/2023 4:35:21 PM> Extended CSD Information : 3/17/2023 4:35:21 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/17/2023 4:35:21 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 3/17/2023 4:35:21 PM> Boot Bus Config: 0x00 , width 1bit 3/17/2023 4:35:21 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 3/17/2023 4:35:21 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/17/2023 4:35:21 PM> Device supports partitioning features 3/17/2023 4:35:21 PM> Device can have enhanced technological features in partitions and user data area 3/17/2023 4:35:21 PM> Device can have extended partitions attribute 3/17/2023 4:35:21 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/17/2023 4:35:21 PM> Backup saved: QE63MB_D98B68BC_20230317_163521.extcsd 3/17/2023 4:35:21 PM> EMMC Init completed. 3/17/2023 4:35:21 PM> 3/17/2023 4:35:21 PM> Operation: Find table from emmc 3/17/2023 4:35:21 PM> 3/17/2023 4:35:21 PM> Vendor: Samsung 3/17/2023 4:35:21 PM> Searching GPT ... 3/17/2023 4:35:21 PM> GPT header is found and is valid 3/17/2023 4:35:21 PM> Checking for ROM2 ... 3/17/2023 4:35:26 PM> ROM2 is blank 3/17/2023 4:35:26 PM> Checking for ROM3 ... 3/17/2023 4:35:31 PM> ROM3 is blank 3/17/2023 4:35:31 PM> GPT header successfully parsed 3/17/2023 4:35:31 PM> 3/17/2023 4:35:31 PM> EFS backup is performed. Please wait... 3/17/2023 4:35:56 PM> EFS saved to: 3/17/2023 4:35:56 PM> \Backups\EFS\efs_20230317_163539.bin 3/17/2023 4:35:56 PM> \Backups\EFS\efs_for_z3x_oldtype_20230317_163539.t ar 3/17/2023 4:35:56 PM> \Backups\EFS\efs_for_z3x_newtype_20230317_163539.t ar 3/17/2023 4:35:56 PM> 3/17/2023 4:35:56 PM> All Done 3/17/2023 4:35:56 PM> 3/17/2023 4:58:57 PM> Looking for EasyJTAG box... 3/17/2023 4:58:57 PM> EasyJTAG API ver. 3403 3/17/2023 4:58:57 PM> Setting IO Levels to 1.8V 3/17/2023 4:58:57 PM> Setting frequence to 21 MHz 3/17/2023 4:58:59 PM> EasyJTAG Box Serial = 1414110FBFBA99FD 3/17/2023 4:58:59 PM> EasyJTAG Box Firmware = 1.6300 3/17/2023 4:59:01 PM> HiPower mode is ON 3/17/2023 4:59:01 PM> Setting frequence to 21 MHz 3/17/2023 4:59:01 PM> CMD Pullup Level: 1897 mV 3/17/2023 4:59:01 PM> CMD Active Level: 2093 mV 3/17/2023 4:59:02 PM> eMMC Init returned = 0 3/17/2023 4:59:02 PM> EMMC Device Information : 3/17/2023 4:59:02 PM> 3/17/2023 4:59:02 PM> Error: First select the Pit-file 3/17/2023 4:59:02 PM> 3/17/2023 4:59:02 PM> EMMC CID: 150100514536334D4200D98B68BC37DC 3/17/2023 4:59:02 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 3/17/2023 4:59:02 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D98B68BC , rev. 0x00 3/17/2023 4:59:02 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2020 3/17/2023 4:59:02 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 3/17/2023 4:59:02 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/17/2023 4:59:02 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 110808 , Response: Not Clean 3/17/2023 4:59:02 PM> EMMC Permanent Write Protection: No 3/17/2023 4:59:02 PM> EMMC Temporary Write Protection: No 3/17/2023 4:59:02 PM> Extended CSD Information : 3/17/2023 4:59:02 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/17/2023 4:59:02 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 3/17/2023 4:59:02 PM> Boot Bus Config: 0x00 , width 1bit 3/17/2023 4:59:02 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 3/17/2023 4:59:02 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/17/2023 4:59:02 PM> Device supports partitioning features 3/17/2023 4:59:02 PM> Device can have enhanced technological features in partitions and user data area 3/17/2023 4:59:02 PM> Device can have extended partitions attribute 3/17/2023 4:59:02 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/17/2023 4:59:02 PM> Backup saved: QE63MB_D98B68BC_20230317_165902.extcsd 3/17/2023 4:59:02 PM> EMMC Init completed. 3/17/2023 4:59:03 PM> 3/17/2023 4:59:03 PM> Opening file: E:\Samsung\A015G\Samfw.com_SM-A015G_SLK_A015GXXS5BVA2_fac\A01Q_EUR_OPEN_PRISM200 M.pit 3/17/2023 4:59:03 PM> 3/17/2023 4:59:03 PM> Pit: A01Q_EUR_OPEN_PRISM200M.pit 3/17/2023 4:59:03 PM> Entry count: 82 3/17/2023 4:59:03 PM> 3/17/2023 4:59:03 PM> The size of the last section has been updated 3/17/2023 4:59:12 PM> Selected file: E:\Samsung\A015G\Samfw.com_SM-A015G_SLK_A015GXXS5BVA2_fac\BL_A015GXXS5BVA2_CL225 71000_QB48826113_REV00_user_low_ship_MULTI_CERT.ta r.md5 3/17/2023 4:59:12 PM> 3/17/2023 4:59:12 PM> BL_A015GXXS5BVA2_CL22571000_QB48826113_REV00_user_ low_ship_MULTI_CERT.tar.md5 3/17/2023 4:59:12 PM> The list of files in the firmware: 3/17/2023 4:59:12 PM> aboot.mbn.lz4 3/17/2023 4:59:12 PM> sbl1.mbn.lz4 3/17/2023 4:59:12 PM> rpm.mbn.lz4 3/17/2023 4:59:12 PM> tz.mbn.lz4 3/17/2023 4:59:12 PM> devcfg.mbn.lz4 3/17/2023 4:59:12 PM> cmnlib_30.mbn.lz4 3/17/2023 4:59:12 PM> cmnlib64_30.mbn.lz4 3/17/2023 4:59:12 PM> km4.mbn.lz4 3/17/2023 4:59:12 PM> apdp.mbn.lz4 3/17/2023 4:59:12 PM> msadp.mbn.lz4 3/17/2023 4:59:12 PM> non-hlos.bin.lz4 3/17/2023 4:59:12 PM> sec.dat.lz4 3/17/2023 4:59:12 PM> adspso.bin.lz4 3/17/2023 4:59:12 PM> bksecapp.mbn.lz4 3/17/2023 4:59:12 PM> vaultkeeper.mbn.lz4 3/17/2023 4:59:12 PM> 3/17/2023 4:59:22 PM> Looking for EasyJTAG box... 3/17/2023 4:59:22 PM> EasyJTAG API ver. 3403 3/17/2023 4:59:22 PM> Setting IO Levels to 1.8V 3/17/2023 4:59:22 PM> Setting frequence to 21 MHz 3/17/2023 4:59:23 PM> EasyJTAG Box Serial = 1414110FBFBA99FD 3/17/2023 4:59:23 PM> EasyJTAG Box Firmware = 1.6300 3/17/2023 4:59:25 PM> HiPower mode is ON 3/17/2023 4:59:25 PM> Setting frequence to 21 MHz 3/17/2023 4:59:25 PM> CMD Pullup Level: 1887 mV 3/17/2023 4:59:25 PM> CMD Active Level: 2083 mV 3/17/2023 4:59:26 PM> eMMC Init returned = 0 3/17/2023 4:59:26 PM> EMMC Device Information : 3/17/2023 4:59:26 PM> EMMC CID: 150100514536334D4200D98B68BC37DC 3/17/2023 4:59:26 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C 3/17/2023 4:59:26 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: D98B68BC , rev. 0x00 3/17/2023 4:59:26 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2020 3/17/2023 4:59:26 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 3/17/2023 4:59:26 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 3/17/2023 4:59:26 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 110808 , Response: Not Clean 3/17/2023 4:59:26 PM> EMMC Permanent Write Protection: No 3/17/2023 4:59:26 PM> EMMC Temporary Write Protection: No 3/17/2023 4:59:26 PM> Extended CSD Information : 3/17/2023 4:59:26 PM> Extended CSD rev: 1.8 (MMC 5.1) 3/17/2023 4:59:26 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 3/17/2023 4:59:26 PM> Boot Bus Config: 0x00 , width 1bit 3/17/2023 4:59:26 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 3/17/2023 4:59:26 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 3/17/2023 4:59:26 PM> Device supports partitioning features 3/17/2023 4:59:26 PM> Device can have enhanced technological features in partitions and user data area 3/17/2023 4:59:26 PM> Device can have extended partitions attribute 3/17/2023 4:59:26 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 3/17/2023 4:59:26 PM> Backup saved: QE63MB_D98B68BC_20230317_165926.extcsd 3/17/2023 4:59:26 PM> EMMC Init completed. 3/17/2023 4:59:26 PM> 3/17/2023 4:59:26 PM> Operation: Write by vendor (Samsung) 3/17/2023 4:59:26 PM> 3/17/2023 4:59:26 PM> Creating GPT-partitioninig 3/17/2023 4:59:26 PM> Writing PrimaryGPT at address: 000000000000 3/17/2023 4:59:26 PM> Writing BackupGPT at address: 0003AB3FBE00 3/17/2023 4:59:26 PM> Writing PIT at address: 000000004400 3/17/2023 4:59:26 PM> GPT-partitioning done 3/17/2023 4:59:26 PM> 3/17/2023 4:59:26 PM> Unpacking file: sbl1.mbn 3/17/2023 4:59:26 PM> Unpacking Lz4: sbl1.mbn.lz4 3/17/2023 4:59:26 PM> Unpacking file: rpm.mbn 3/17/2023 4:59:26 PM> Unpacking Lz4: rpm.mbn.lz4 3/17/2023 4:59:26 PM> Unpacking file: tz.mbn 3/17/2023 4:59:26 PM> Unpacking Lz4: tz.mbn.lz4 3/17/2023 4:59:26 PM> Unpacking file: devcfg.mbn 3/17/2023 4:59:26 PM> Unpacking Lz4: devcfg.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: adspso.bin 3/17/2023 4:59:27 PM> Unpacking Lz4: adspso.bin.lz4 3/17/2023 4:59:27 PM> Unpacking file: sbl1.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: sbl1.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: rpm.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: rpm.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: tz.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: tz.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: devcfg.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: devcfg.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: cmnlib_30.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: cmnlib_30.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: cmnlib64_30.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: cmnlib64_30.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: km4.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: km4.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: aboot.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: aboot.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: vaultkeeper.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: vaultkeeper.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: bksecapp.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: bksecapp.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: cmnlib_30.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: cmnlib_30.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: cmnlib64_30.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: cmnlib64_30.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: km4.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: km4.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: aboot.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: aboot.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: sec.dat 3/17/2023 4:59:27 PM> Unpacking Lz4: sec.dat.lz4 3/17/2023 4:59:27 PM> Unpacking file: apdp.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: apdp.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: msadp.mbn 3/17/2023 4:59:27 PM> Unpacking Lz4: msadp.mbn.lz4 3/17/2023 4:59:27 PM> Unpacking file: non-hlos.bin 3/17/2023 4:59:27 PM> Unpacking Lz4: non-hlos.bin.lz4 3/17/2023 4:59:27 PM> 3/17/2023 4:59:27 PM> Partition name: SBL1 3/17/2023 4:59:27 PM> Filename: sbl1.mbn , Offset: 000000405000 , filesize: 398808 bytes 3/17/2023 4:59:27 PM> eMMC switching to ROM1 3/17/2023 4:59:28 PM> Erasing partition... 3/17/2023 4:59:29 PM> Writing partition... 3/17/2023 4:59:30 PM> Done writing partition. Write speed: 414.23 KB/s 3/17/2023 4:59:30 PM> Partition name: RPM 3/17/2023 4:59:30 PM> Filename: rpm.mbn , Offset: 000000485000 , filesize: 169604 bytes 3/17/2023 4:59:30 PM> eMMC switching to ROM1 3/17/2023 4:59:30 PM> Erasing partition... 3/17/2023 4:59:31 PM> Writing partition... 3/17/2023 4:59:31 PM> Done writing partition. Write speed: 645.36 KB/s 3/17/2023 4:59:31 PM> Partition name: TZ 3/17/2023 4:59:31 PM> Filename: tz.mbn , Offset: 000000505000 , filesize: 1528192 bytes 3/17/2023 4:59:31 PM> eMMC switching to ROM1 3/17/2023 4:59:32 PM> Erasing partition... 3/17/2023 4:59:33 PM> Writing partition... 3/17/2023 4:59:35 PM> Done writing partition. Write speed: 698.69 KB/s 3/17/2023 4:59:35 PM> Partition name: DEVCFG 3/17/2023 4:59:35 PM> Filename: devcfg.mbn , Offset: 000000705000 , filesize: 38572 bytes 3/17/2023 4:59:35 PM> eMMC switching to ROM1 3/17/2023 4:59:35 PM> Erasing partition... 3/17/2023 4:59:36 PM> Writing partition... 3/17/2023 4:59:36 PM> Done writing partition. Write speed: 734.91 KB/s 3/17/2023 4:59:36 PM> Partition name: DSP 3/17/2023 4:59:36 PM> Filename: adspso.bin , Offset: 000000745000 , filesize: 16777216 bytes 3/17/2023 4:59:36 PM> eMMC switching to ROM1 3/17/2023 4:59:36 PM> Erasing partition... 3/17/2023 4:59:38 PM> Writing partition... 3/17/2023 5:00:01 PM> Done writing partition. Write speed: 721.60 KB/s 3/17/2023 5:00:01 PM> Partition name: SBL1BAK 3/17/2023 5:00:01 PM> 3/17/2023 5:00:01 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\sbl1.mbn 3/17/2023 5:00:01 PM> Partition name: RPMBAK 3/17/2023 5:00:01 PM> 3/17/2023 5:00:01 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\rpm.mbn 3/17/2023 5:00:01 PM> Partition name: TZBAK 3/17/2023 5:00:01 PM> 3/17/2023 5:00:01 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\tz.mbn 3/17/2023 5:00:01 PM> Partition name: DEVCFGBAK 3/17/2023 5:00:01 PM> 3/17/2023 5:00:01 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\devcfg.mbn 3/17/2023 5:00:01 PM> Partition name: CMNLIB 3/17/2023 5:00:01 PM> Filename: cmnlib_30.mbn , Offset: 000004020000 , filesize: 206184 bytes 3/17/2023 5:00:01 PM> eMMC switching to ROM1 3/17/2023 5:00:02 PM> Erasing partition... 3/17/2023 5:00:02 PM> Writing partition... 3/17/2023 5:00:03 PM> Done writing partition. Write speed: 554.52 KB/s 3/17/2023 5:00:03 PM> Partition name: CMNLIB64 3/17/2023 5:00:03 PM> Filename: cmnlib64_30.mbn , Offset: 000004120000 , filesize: 265528 bytes 3/17/2023 5:00:03 PM> eMMC switching to ROM1 3/17/2023 5:00:03 PM> Erasing partition... 3/17/2023 5:00:04 PM> Writing partition... 3/17/2023 5:00:04 PM> Done writing partition. Write speed: 586.03 KB/s 3/17/2023 5:00:04 PM> Partition name: KEYMASTER 3/17/2023 5:00:04 PM> Filename: km4.mbn , Offset: 000004220000 , filesize: 320240 bytes 3/17/2023 5:00:04 PM> eMMC switching to ROM1 3/17/2023 5:00:04 PM> Erasing partition... 3/17/2023 5:00:05 PM> Writing partition... 3/17/2023 5:00:06 PM> Done writing partition. Write speed: 643.02 KB/s 3/17/2023 5:00:06 PM> Partition name: ABOOT 3/17/2023 5:00:06 PM> Filename: aboot.mbn , Offset: 000004320000 , filesize: 1799764 bytes 3/17/2023 5:00:06 PM> eMMC switching to ROM1 3/17/2023 5:00:06 PM> Erasing partition... 3/17/2023 5:00:07 PM> Writing partition... 3/17/2023 5:00:09 PM> Done writing partition. Write speed: 641.39 KB/s 3/17/2023 5:00:09 PM> Partition name: VK 3/17/2023 5:00:09 PM> Filename: vaultkeeper.mbn , Offset: 000004530000 , filesize: 1080024 bytes 3/17/2023 5:00:09 PM> eMMC switching to ROM1 3/17/2023 5:00:10 PM> Erasing partition... 3/17/2023 5:00:10 PM> Writing partition... 3/17/2023 5:00:12 PM> Done writing partition. Write speed: 604.59 KB/s 3/17/2023 5:00:12 PM> Partition name: BKSECAPP 3/17/2023 5:00:12 PM> Filename: bksecapp.mbn , Offset: 000004B30000 , filesize: 45568 bytes 3/17/2023 5:00:12 PM> eMMC switching to ROM1 3/17/2023 5:00:13 PM> Erasing partition... 3/17/2023 5:00:13 PM> Writing partition... 3/17/2023 5:00:13 PM> Done writing partition. Write speed: 447.84 KB/s 3/17/2023 5:00:13 PM> Partition name: CMNLIBBAK 3/17/2023 5:00:13 PM> 3/17/2023 5:00:13 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\cmnlib_30.mbn 3/17/2023 5:00:13 PM> Partition name: CMNLIB64BAK 3/17/2023 5:00:13 PM> 3/17/2023 5:00:13 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\cmnlib64_30.mbn 3/17/2023 5:00:13 PM> Partition name: KEYMASTERBAK 3/17/2023 5:00:13 PM> 3/17/2023 5:00:14 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\km4.mbn 3/17/2023 5:00:14 PM> Partition name: ABOOTBAK 3/17/2023 5:00:14 PM> 3/17/2023 5:00:14 PM> Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\aboot.mbn 3/17/2023 5:00:14 PM> Partition name: SEC 3/17/2023 5:00:14 PM> Filename: sec.dat , Offset: 00000D080000 , filesize: 948 bytes 3/17/2023 5:00:14 PM> eMMC switching to ROM1 3/17/2023 5:00:14 PM> Erasing partition... 3/17/2023 5:00:14 PM> Writing partition... 3/17/2023 5:00:14 PM> Done writing partition. Write speed: 65.02 KB/s 3/17/2023 5:00:14 PM> Partition name: APDP 3/17/2023 5:00:14 PM> Filename: apdp.mbn , Offset: 000011340000 , filesize: 13760 bytes 3/17/2023 5:00:15 PM> eMMC switching to ROM1 3/17/2023 5:00:15 PM> Erasing partition... 3/17/2023 5:00:15 PM> Writing partition... 3/17/2023 5:00:15 PM> Done writing partition. Write speed: 340.19 KB/s 3/17/2023 5:00:15 PM> Partition name: MSADP 3/17/2023 5:00:15 PM> Filename: msadp.mbn , Offset: 000011380000 , filesize: 13760 bytes 3/17/2023 5:00:15 PM> eMMC switching to ROM1 3/17/2023 5:00:16 PM> Erasing partition... 3/17/2023 5:00:16 PM> Writing partition... 3/17/2023 5:00:16 PM> Done writing partition. Write speed: 558.21 KB/s 3/17/2023 5:00:16 PM> Partition name: APNHLOS 3/17/2023 5:00:16 PM> Filename: non-hlos.bin , Offset: 000031480000 , filesize: 67109376 bytes 3/17/2023 5:00:16 PM> eMMC switching to ROM1 3/17/2023 5:00:17 PM> Erasing partition... 3/17/2023 5:00:23 PM> Writing partition... 3/17/2023 5:02:04 PM> Done writing partition. Write speed: 652.86 KB/s 3/17/2023 5:02:04 PM> 3/17/2023 5:02:04 PM> Partition CACHE : formatting as EXT4. Please wait ... 3/17/2023 5:02:06 PM> Formatting completed 3/17/2023 5:02:45 PM> Partition USERDATA : formatting as EXT4. Please wait ... 3/17/2023 5:02:58 PM> Formatting completed 3/17/2023 5:02:58 PM> 3/17/2023 5:02:58 PM> Check BootConfig for the selected vendor 3/17/2023 5:02:58 PM> 3/17/2023 5:02:58 PM> All done time: [00:03:30:627] 3/17/2023 5:02:58 PM> |
Someone have any experience in this kind of problem, and know how repair this phone |
i tried shorting the clk resistor but phone not on, only detect as qualcomm in pc |
