Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Moderator ![]() Join Date: Nov 2009 Location: Proud to represent of B.D Age: 38
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 10,642 ![]() | A10 | A105F ''U3'' 🔒 MDM Lock 📲 No Download Mode 💾 No Wipe Data 🗝 Solution 🛠 ![]() Brief preview ![]() Log:- Code: 7/1/2020 10:27:34 PM> eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) 7/1/2020 10:27:37 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) 7/1/2020 10:27:37 PM> 7/1/2020 10:27:37 PM> Looking for EasyJTAG box... 7/1/2020 10:27:37 PM> EasyJTAG API ver. 3401 7/1/2020 10:27:38 PM> OpenUSB returned = 0 7/1/2020 10:27:38 PM> EasyJTAG Box Serial = F6F272D292237F2E 7/1/2020 10:27:39 PM> Card Serial = AA2778BA 7/1/2020 10:27:39 PM> EasyJTAG Box Firmware = 2.5201 7/1/2020 10:28:35 PM> Looking for EasyJTAG box... 7/1/2020 10:28:35 PM> EasyJTAG API ver. 3401 7/1/2020 10:28:35 PM> Setting IO Levels to 1.8V 7/1/2020 10:28:35 PM> Setting frequence to 1 MHz 7/1/2020 10:28:35 PM> EasyJTAG Box Serial = F6F272D292237F2E 7/1/2020 10:28:35 PM> EasyJTAG Box Firmware = 2.5201 7/1/2020 10:28:36 PM> Setting interface to EasyJtag2/ISP_HiPower 7/1/2020 10:28:36 PM> Setting bus width to 1 Bit 7/1/2020 10:28:36 PM> HiPower mode is ON 7/1/2020 10:28:36 PM> Setting frequence to 1 MHz 7/1/2020 10:28:36 PM> CMD Pullup Level: 462 mV 7/1/2020 10:28:36 PM> CMD Active Level: 1673 mV 7/1/2020 10:28:37 PM> eMMC Init returned = 0 7/1/2020 10:28:37 PM> EMMC Device Information : 7/1/2020 10:28:37 PM> EMMC CID: 150100424A5444345200767B4703270F 7/1/2020 10:28:37 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 7/1/2020 10:28:37 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 767B4703 , rev. 0x00 7/1/2020 10:28:37 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2020 7/1/2020 10:28:37 PM> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 7/1/2020 10:28:37 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 7/1/2020 10:28:37 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 470 , Response: Not Clean 7/1/2020 10:28:37 PM> EMMC Permanent Write Protection: No 7/1/2020 10:28:37 PM> EMMC Temporary Write Protection: No 7/1/2020 10:28:37 PM> Extended CSD Information : 7/1/2020 10:28:37 PM> Extended CSD rev: 1.8 (MMC 5.1) 7/1/2020 10:28:37 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 7/1/2020 10:28:37 PM> Boot Bus Config: 0x01 , width 4bit 7/1/2020 10:28:37 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 7/1/2020 10:28:37 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 7/1/2020 10:28:37 PM> Device supports partitioning features 7/1/2020 10:28:37 PM> Device can have enhanced technological features in partitions and user data area 7/1/2020 10:28:37 PM> Device can have extended partitions attribute 7/1/2020 10:28:37 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 7/1/2020 10:28:37 PM> Backup saved: BJTD4R_767B4703_20200701_222837.extcsd 7/1/2020 10:28:37 PM> EMMC Init completed. 7/1/2020 10:28:37 PM> 7/1/2020 10:28:37 PM> Operation: Write by vendor (Samsung) 7/1/2020 10:28:37 PM> 7/1/2020 10:28:37 PM> Creating GPT-partitioninig 7/1/2020 10:28:37 PM> Writing PrimaryGPT at address: 000000000000 7/1/2020 10:28:37 PM> Writing BackupGPT at address: 000747BFBE00 7/1/2020 10:28:38 PM> Writing PIT at address: 000000004400 7/1/2020 10:28:38 PM> GPT-partitioning done 7/1/2020 10:28:38 PM> 7/1/2020 10:28:38 PM> Unpacking file: sboot.bin 7/1/2020 10:28:38 PM> Unpacking file: cm.bin 7/1/2020 10:28:38 PM> Unpacking file: nad_refer.bin 7/1/2020 10:28:38 PM> Unpacking file: param.bin 7/1/2020 10:28:38 PM> Unpacking file: boot.img 7/1/2020 10:28:38 PM> Unpacking file: recovery.img 7/1/2020 10:28:39 PM> Unpacking file: dt.img 7/1/2020 10:28:39 PM> Unpacking file: dtbo.img 7/1/2020 10:28:39 PM> Unpacking file: modem.bin 7/1/2020 10:28:40 PM> Unpacking file: vbmeta.img 7/1/2020 10:28:40 PM> Unpacking file: system.img 7/1/2020 10:29:18 PM> Unpacking file: vendor.img 7/1/2020 10:29:22 PM> Unpacking file: product.img 7/1/2020 10:29:22 PM> Unpacking file: cache.img 7/1/2020 10:29:22 PM> Unpacking file: modem_debug.bin 7/1/2020 10:29:22 PM> Unpacking file: nad_fw.bin 7/1/2020 10:29:24 PM> Unpacking file: userdata.img 7/1/2020 10:29:26 PM> 7/1/2020 10:29:26 PM> Partition name: BOOTLOADER 7/1/2020 10:29:26 PM> Filename: sboot.bin , Offset: 000000000000 , filesize: 4194304 bytes 7/1/2020 10:29:26 PM> eMMC switching to ROM2 7/1/2020 10:29:26 PM> Erasing partition... 7/1/2020 10:30:37 PM> Writing partition... 7/1/2020 10:31:47 PM> Done writing partition. Write speed: 58.58 KB/s 7/1/2020 10:31:47 PM> Partition name: CM 7/1/2020 10:31:47 PM> Filename: cm.bin , Offset: 000004800000 , filesize: 8388608 bytes 7/1/2020 10:31:47 PM> eMMC switching to ROM1 7/1/2020 10:31:47 PM> Erasing partition... 7/1/2020 10:31:52 PM> Writing partition... 7/1/2020 10:33:03 PM> Done writing partition. Write speed: 116.56 KB/s 7/1/2020 10:33:03 PM> Partition name: NAD_REFER 7/1/2020 10:33:03 PM> Filename: nad_refer.bin , Offset: 000005C00000 , filesize: 65536 bytes 7/1/2020 10:33:03 PM> eMMC switching to ROM1 7/1/2020 10:33:03 PM> Erasing partition... 7/1/2020 10:33:04 PM> Writing partition... 7/1/2020 10:33:04 PM> Done writing partition. Write speed: 116.21 KB/s 7/1/2020 10:33:04 PM> Partition name: PARAM 7/1/2020 10:33:04 PM> Filename: param.bin , Offset: 000005D00000 , filesize: 1392640 bytes 7/1/2020 10:33:04 PM> eMMC switching to ROM1 7/1/2020 10:33:04 PM> Erasing partition... 7/1/2020 10:33:07 PM> Writing partition... 7/1/2020 10:33:18 PM> Done writing partition. Write speed: 118.35 KB/s 7/1/2020 10:33:18 PM> Partition name: BOOT 7/1/2020 10:33:18 PM> Filename: boot.img , Offset: 000006F00000 , filesize: 37748736 bytes 7/1/2020 10:33:18 PM> eMMC switching to ROM1 7/1/2020 10:33:19 PM> Erasing partition... 7/1/2020 10:33:28 PM> Writing partition... 7/1/2020 10:38:40 PM> Done writing partition. Write speed: 118.38 KB/s 7/1/2020 10:38:40 PM> Partition name: RECOVERY 7/1/2020 10:38:40 PM> Filename: recovery.img , Offset: 000009300000 , filesize: 55574528 bytes 7/1/2020 10:38:40 PM> eMMC switching to ROM1 7/1/2020 10:38:40 PM> Erasing partition... 7/1/2020 10:38:54 PM> Writing partition... 7/1/2020 10:46:32 PM> Done writing partition. Write speed: 118.26 KB/s 7/1/2020 10:46:33 PM> Partition name: DTB 7/1/2020 10:46:33 PM> Filename: dt.img , Offset: 00000C800000 , filesize: 8388608 bytes 7/1/2020 10:46:33 PM> eMMC switching to ROM1 7/1/2020 10:46:33 PM> Erasing partition... 7/1/2020 10:46:35 PM> Writing partition... 7/1/2020 10:47:45 PM> Done writing partition. Write speed: 118.33 KB/s 7/1/2020 10:47:45 PM> Partition name: DTBO 7/1/2020 10:47:45 PM> Filename: dtbo.img , Offset: 00000D000000 , filesize: 8388608 bytes 7/1/2020 10:47:45 PM> eMMC switching to ROM1 7/1/2020 10:47:45 PM> Erasing partition... 7/1/2020 10:47:47 PM> Writing partition... 7/1/2020 10:48:56 PM> Done writing partition. Write speed: 118.44 KB/s 7/1/2020 10:48:56 PM> Partition name: RADIO 7/1/2020 10:48:56 PM> Filename: modem.bin , Offset: 00000D800000 , filesize: 36920176 bytes 7/1/2020 10:48:56 PM> eMMC switching to ROM1 7/1/2020 10:48:57 PM> Erasing partition... 7/1/2020 10:49:08 PM> Writing partition... 7/1/2020 10:54:13 PM> Done writing partition. Write speed: 118.45 KB/s 7/1/2020 10:54:13 PM> Partition name: VBMETA 7/1/2020 10:54:13 PM> Filename: vbmeta.img , Offset: 000010980000 , filesize: 8592 bytes 7/1/2020 10:54:13 PM> eMMC switching to ROM1 7/1/2020 10:54:13 PM> Erasing partition... 7/1/2020 10:54:14 PM> Writing partition... 7/1/2020 10:54:14 PM> Done writing partition. Write speed: 96.94 KB/s 7/1/2020 10:54:14 PM> Partition name: SYSTEM 7/1/2020 10:54:14 PM> Filename: system.img , Offset: 000011000000 , filesize: 1383743816 bytes 7/1/2020 10:54:14 PM> eMMC switching to ROM1 7/1/2020 10:54:14 PM> Erasing partition... 7/1/2020 11:08:23 PM> Writing partition... 7/1/2020 11:08:23 PM> Sparse image found v.1.0 Total chunks: 25 7/2/2020 2:17:45 AM> Done writing partition. Write speed: 118.93 KB/s 7/2/2020 2:17:45 AM> Partition name: VENDOR 7/2/2020 2:17:45 AM> Filename: vendor.img , Offset: 0000E5000000 , filesize: 135970976 bytes 7/2/2020 2:17:45 AM> eMMC switching to ROM1 7/2/2020 2:17:45 AM> Erasing partition... 7/2/2020 2:18:46 AM> Writing partition... 7/2/2020 2:18:46 AM> Sparse image found v.1.0 Total chunks: 11 7/2/2020 2:37:24 AM> Done writing partition. Write speed: 118.83 KB/s 7/2/2020 2:37:24 AM> Partition name: PRODUCT 7/2/2020 2:37:24 AM> Filename: product.img , Offset: 0000FC800000 , filesize: 6623464 bytes 7/2/2020 2:37:24 AM> eMMC switching to ROM1 7/2/2020 2:37:24 AM> Erasing partition... 7/2/2020 2:38:28 AM> Writing partition... 7/2/2020 2:38:28 AM> Sparse image found v.1.0 Total chunks: 17 7/2/2020 2:39:23 AM> Done writing partition. Write speed: 118.96 KB/s 7/2/2020 2:39:23 AM> Partition name: CACHE 7/2/2020 2:39:23 AM> Filename: cache.img , Offset: 000115800000 , filesize: 78020 bytes 7/2/2020 2:39:23 AM> eMMC switching to ROM1 7/2/2020 2:39:23 AM> Erasing partition... 7/2/2020 2:40:28 AM> Writing partition... 7/2/2020 2:40:28 AM> Sparse image found v.1.0 Total chunks: 14 7/2/2020 2:40:29 AM> Done writing partition. Write speed: 113.43 KB/s 7/2/2020 2:40:29 AM> Partition name: CP_DEBUG 7/2/2020 2:40:29 AM> Filename: modem_debug.bin , Offset: 000131A00000 , filesize: 5242880 bytes 7/2/2020 2:40:29 AM> eMMC switching to ROM1 7/2/2020 2:40:29 AM> Erasing partition... 7/2/2020 2:40:31 AM> Writing partition... 7/2/2020 2:41:13 AM> Done writing partition. Write speed: 119.19 KB/s 7/2/2020 2:41:13 AM> Partition name: NAD_FW 7/2/2020 2:41:14 AM> Filename: nad_fw.bin , Offset: 000131F00000 , filesize: 15586832 bytes 7/2/2020 2:41:14 AM> eMMC switching to ROM1 7/2/2020 2:41:14 AM> Erasing partition... 7/2/2020 2:41:17 AM> Writing partition... 7/2/2020 2:43:25 AM> Done writing partition. Write speed: 118.96 KB/s 7/2/2020 2:43:25 AM> Partition name: USERDATA 7/2/2020 2:43:25 AM> Filename: userdata.img , Offset: 000133300000 , filesize: 133611908 bytes 7/2/2020 2:43:25 AM> eMMC switching to ROM1 7/2/2020 2:43:26 AM> Erasing partition... 7/2/2020 4:02:11 AM> Writing partition... 7/2/2020 4:02:11 AM> Sparse image found v.1.0 Total chunks: 30 7/2/2020 4:20:31 AM> Done writing partition. Write speed: 118.65 KB/s 7/2/2020 4:20:31 AM> 7/2/2020 4:20:31 AM> Check BootConfig for the selected vendor 7/2/2020 4:20:31 AM> 7/2/2020 4:20:31 AM> All done time: [05:51:05:143] After write done Combination file, MDM is Removed ![]() Your phone will be run with Factory binary status. Go To Developer Option Enable OEM then factory reset by Optional. Now put your phone in download mode Flash Official Stock ROM, Enjoy ![]()
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 32 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #5 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 10,642 ![]() | Hi, Here is the A105F ISP PIN Out but both is same, with the different view. ![]() ![]() ![]()
The Following 6 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #7 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 10,642 ![]() | Do not use the USB Cable for voltage of Power source, just use only the VCC and VCCQ. The main thing for better performance is to stream my first post, just set 1 MHz and bus 1 bit.
The Following 4 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #12 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 177 ![]() | Hello i have s10e with MDM lock no download mode no recovery UFS chip And i have one working phone And am new in easy jtag Can anyone help me what to do? For removing MDM lock Sent from my SM-A520F using Tapatalk |
![]() | #13 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2002 Location: Belarus Age: 44
Member: 13148 Status: Offline Thanks Meter: 2,408 | Quote:
but simple you need write combination to device and clone dump (without efs, userfata) to blocked device after you need resett lock from menu | |
The Following 6 Users Say Thank You to layder For This Useful Post: |
