11-23-2020, 12:34 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: lisbon
Member: 1917749 Status: Offline Thanks Meter: 90 | oppo a5 2020 done OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AADF-1804 , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM31 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM31) COM1 ACPI\PNP0501 Porta de comunicações (COM1) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BA2E1A288C3B17D1, ,FW Ver.: 02.52 CMD Pullup Level:2104 mV CMD Active Level:2548 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E03000D9BBE7793 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 07/2020 Rev.0x3 eMMC NAME: hC8aP> , S/N: 891838 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 547 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP>_ 891838_20201123_1128.extcsd Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFD2 sectors 58.2 GiB Disk identifier (GUID): DE6BB3FF-8381-BDC4-AB07-361DDF131DE0 Logical sector size: 0x200 bytes ,First/Last usable sector: 23,122142697 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x00A0020000 (6.246GB) Short EXT fs info: Size: 6.147GB Block size: 4.0KB Inode size: 256 Inodes: 403200 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x02A4020000 (47.678GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BA2E1A288C3B17D1, ,FW Ver.: 02.52 CMD Pullup Level:2105 mV CMD Active Level:2624 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E03000D9BBE7793 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 07/2020 Rev.0x3 eMMC NAME: hC8aP> , S/N: 891838 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 547 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (50) Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BA2E1A288C3B17D1, ,FW Ver.: 02.52 CMD Pullup Level:2103 mV CMD Active Level:2622 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E03000D9BBE7793 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 07/2020 Rev.0x3 eMMC NAME: hC8aP> , S/N: 891838 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 547 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (50) Done. |
