SM-A107f boot why phone still dead eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 0DFF8012C2EBA278 Card Serial = AAAF3D57 EasyJTAG Box Firmware = 1.6300 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 268 mV CMD Active Level: 1237 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 381 mV CMD Active Level: 1876 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 381 mV CMD Active Level: 1794 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 340 mV CMD Active Level: 1732 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Error: Previous operation is not finished yet. Can't init device. Reason: -12 Unknown error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2650 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_121159.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Firmware info not found HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2485 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_122924.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Firmware info not found HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2485 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_123130.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is not blank Checking for ROM3 ... ROM3 is not blank GPT header successfully parsed Missing file for partition: efs Missing file for partition: nvdata Missing file for partition: persist HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_123526.extcsd EMMC Init completed. Operation: MoviNand Reset ... Sending Smart Wipe Request... Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_123558.extcsd EMMC Init completed. Filename: QX63MB_DE07CC69_20201018_123558.extcsd Operation: Repairing ExtCsd ... Error: -30 Unknown error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 2000 mV CMD Active Level: 2629 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_123923.extcsd EMMC Init completed. Filename: QX63MB_DE07CC69_20201018_123558.extcsd Operation: Repairing ExtCsd ... Successfully HiPower mode is ON Error: Previous operation is not finished yet. Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_124110.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Firmware info not found HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 2000 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_124449.extcsd EMMC Init completed. Opening file: A10S_EUR_OPEN.pit Pit: A10S_EUR_OPEN.pit Entry count: 44 The size of the last section has been updated BL_A107FXXU7BTI9_CL18740799_QB34630381_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img.lz4 lk.img.lz4 param.bin.lz4 up_param.bin.lz4 efuse.img.lz4 HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2609 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_124652.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking Lz4: preloader.img.lz4 Unpacking file: efuse.img Unpacking Lz4: efuse.img.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: up_param.bin Unpacking Lz4: up_param.bin.lz4 Unpacking file: lk.img Unpacking Lz4: lk.img.lz4 Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 258560 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 349.16 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000000580000 , filesize: 1024 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 63.30 KB/s Partition name: PARAM Filename: param.bin , Offset: 000006B00000 , filesize: 123392 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 371.43 KB/s Partition name: UP_PARAM Filename: up_param.bin , Offset: 000006F00000 , filesize: 727552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 624.80 KB/s Partition name: LK Filename: lk.img , Offset: 00001C400000 , filesize: 1290064 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 619.98 KB/s Partition CACHE : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:00:42:686] HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1990 mV CMD Active Level: 2578 mV EMMC Device Information : EMMC CID: 150100515836334D4200DE07CC69573E EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63MB , HEX: 515836334D42 , S/N: DE07CC69 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1894 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63MB_DE07CC69_20201018_124841.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOOT_PARA, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: PARA, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: EFUSE, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: NVRAM, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: EFS, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: SEC_EFS, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: BOTA, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: PARAM, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: UP_PARAM, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: EXPDB, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: FRP, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: NVCFG, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: NVDATA, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: METADATA, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: PROTECT1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: SECCFG, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: PERSIST, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: PERSISTENT, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: MISC, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: SEC1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: PROINFO, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: MD1IMG, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: SPMFW, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: SCP1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: SSPM_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: LK, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: STEADY, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: BOOT, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: DTBO, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: TEE1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: VENDOR, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: PRODUCT, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: SYSTEM, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: VBMETA, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: CACHE, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: OMR, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: USERDATA, [000150000000 - 000747BFBE00], size: 0005F7BFBE00 (23.8 GB) GPT header successfully parsed Get firmware version Firmware info not found phone was flashed with wron flash file before |
did you manage to fix this problem i have same phone same problem even after flash dump and bootloader phone wont power on no download mode |
