Old 05-23-2020, 08:52   #1 (permalink)
-=P.F.U=-'s Avatar
Member: 2825953
Thanks Meter: 246
SM-J500F Dead Boot Repair Completed but Doesn't Come ON To Download Mode
Dear, JTAG specialist,
Please figerout me whats wrong !!
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 12 Mhz
CMD Pullup Level: 2128 mV
CMD Active Level: 2626 mV
EMMC Device Information :
EMMC CID: 90014A4838473475920119E4950E44EF
EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4u , EMMC NAME (HEX): 483847347500 , S/N: 19E4950E , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 4/2017
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H8G4u_19E4950E_20200523_031705.extcsd
EMMC Init completed.
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: non-hlos.bin
Unpacking file: modem.bin
Unpacking file: sbl1.mbn
Unpacking file: aboot.mbn
Unpacking file: rpm.mbn
Unpacking file: tz.mbn
Unpacking file: hyp.mbn
Unpacking file: sec.dat
Unpacking file: boot.img
Unpacking file: recovery.img
Unpacking file: persist.img.ext4
Unpacking file: system.img.ext4
Unpacking file: cache.img.ext4
Unpacking file: hidden.img.ext4
Partition name: APNHLOS
Filename: non-hlos.bin , Offset: 000000400000 , filesize: 14452480 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 1390.86 KB/s
Partition name: MODEM
Filename: modem.bin , Offset: 000001300000 , filesize: 46647040 bytes
Done writing partition. Write speed: 1395.62 KB/s
Partition name: SBL1
Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 283892 bytes
Done writing partition. Write speed: 1082.25 KB/s
Partition name: ABOOT
Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1217664 bytes
Done writing partition. Write speed: 1351.33 KB/s
Partition name: RPM
Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 187836 bytes
Done writing partition. Write speed: 1117.42 KB/s
Partition name: QSEE
Filename: tz.mbn , Offset: 000004F78000 , filesize: 520588 bytes
Done writing partition. Write speed: 1277.84 KB/s
Partition name: QHEE
Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 90368 bytes
Done writing partition. Write speed: 1026.38 KB/s
Partition name: SEC
Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes
Done writing partition. Write speed: 29.78 KB/s
Partition name: BOOT
Filename: boot.img , Offset: 000007C00000 , filesize: 10924304 bytes
Done writing partition. Write speed: 1397.09 KB/s
Partition name: RECOVERY
Filename: recovery.img , Offset: 000008900000 , filesize: 12079376 bytes
Done writing partition. Write speed: 1391.50 KB/s
Partition name: PERSIST
Filename: persist.img.ext4 , Offset: 00000AE80000 , filesize: 4350076 bytes
Sparse image found v.1.0 Total chunks: 8
Done writing partition. Write speed: 1361.55 KB/s
Partition name: SYSTEM
Filename: system.img.ext4 , Offset: 00000C000000 , filesize: 1825843932 bytes
Sparse image found v.1.0 Total chunks: 2960
Done writing partition. Write speed: 1378.26 KB/s
Partition name: CACHE
Filename: cache.img.ext4 , Offset: 00008E000000 , filesize: 93626588 bytes
Sparse image found v.1.0 Total chunks: 16
Done writing partition. Write speed: 1398.37 KB/s
Partition name: HIDDEN
Filename: hidden.img.ext4 , Offset: 00009A800000 , filesize: 27239028 bytes
Sparse image found v.1.0 Total chunks: 50
Done writing partition. Write speed: 1360.27 KB/s
Partition EFS : formatting as EXT4. Please wait ...
Formatting completed
All done time: [00:26:22:423]
Backup saved: H8G4u_19E4950E_20200523_034539.extcsd
Scanning soft partitions
GPT header is found and is valid
Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000
Partition: modem, [000001300000 - 000004C70000], size: 000003970000
Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000
Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000
Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000
Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000
Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000
Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000
Partition: fsg, [000005078000 - 000005378000], size: 000000300000
Partition: sec, [000005378000 - 00000537C000], size: 000000004000
Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000
Partition: param, [000005E00000 - 000006800000], size: 000000A00000
Partition: efs, [000006800000 - 000007600000], size: 000000E00000
Partition: modemst1, [000007600000 - 000007900000], size: 000000300000
Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000
Partition: boot, [000007C00000 - 000008900000], size: 000000D00000
Partition: recovery, [000008900000 - 000009800000], size: 000000F00000
Partition: fota, [000009800000 - 00000A480400], size: 000000C80400
Partition: backup, [00000A480400 - 00000AB7E000], size: 0000006FDC00
Partition: fsc, [00000AB7E000 - 00000AE7E000], size: 000000300000
Partition: ssd, [00000AE7E000 - 00000AE80000], size: 000000002000
Partition: persist, [00000AE80000 - 00000B680000], size: 000000800000
Partition: persistent, [00000B680000 - 00000B700000], size: 000000080000
Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000
Partition: system, [00000C000000 - 00008E000000], size: 000082000000
Partition: cache, [00008E000000 - 00009A800000], size: 00000C800000
Partition: hidden, [00009A800000 - 00009EE00000], size: 000004600000
Partition: userdata, [00009EE00000 - 0001D1FFBE00], size: 0001331FBE00
GPT header successfully parsed
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-J500F
Phone platform = msm8916
CPU Abi = armeabi-v7a
Android release = 5.1.1
Firmware version = LMY48B.J500FXXU1AOH2
Firmware date = Thu Aug 13 14:19:56 KST 2015
Old 05-23-2020, 12:52   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
try to write latest FW
The Following User Says Thank You to layder For This Useful Post:
Old 05-24-2020, 21:26   #3 (permalink)
-=P.F.U=-'s Avatar
Member: 2825953
Thanks Meter: 246
Finally my phone has been revive with this dump file,
SK Hynix_Dump_ 100%_Tested_SM-J500F_(LMY48B.J500FXWU1AOJ2-5.1.1-LMY48B)[H8G4u_35E3C581]
Download, Link 1 Link 2 Link 3
1'st create backup security area, just erase eMMC then write the dump
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Setting frequence to 12 MHz
CMD Pullup Level: 2132 mV
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 19E4950E , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2017
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 146890 , Response: Not Clean
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Backup saved: H8G4u_19E4950E_20200523_234359.extcsd
Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15.0 MB)
Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57.4 MB)
Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512. KB)
Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32.0 KB)
Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2.00 MB)
Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512. KB)
Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512. KB)
Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512. KB)
Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3.00 MB)
Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16.0 KB)
Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10.5 MB)
Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10.0 MB)
Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14.0 MB)
Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3.00 MB)
Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3.00 MB)
Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13.0 MB)
Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15.0 MB)
Partition: fota, [000009800000 - 00000A480400], size: 000000C80400 (12.5 MB)
Partition: backup, [00000A480400 - 00000AB7E000], size: 0000006FDC00 (6.99 MB)
Partition: fsc, [00000AB7E000 - 00000AE7E000], size: 000000300000 (3.00 MB)
Partition: ssd, [00000AE7E000 - 00000AE80000], size: 000000002000 (8.00 KB)
Partition: persist, [00000AE80000 - 00000B680000], size: 000000800000 (8.00 MB)
Partition: persistent, [00000B680000 - 00000B700000], size: 000000080000 (512. KB)
Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000 (9.00 MB)
Partition: system, [00000C000000 - 00008E000000], size: 000082000000 (2.03 GB)
Partition: cache, [00008E000000 - 00009A800000], size: 00000C800000 (200. MB)
Partition: hidden, [00009A800000 - 00009EE00000], size: 000004600000 (70.0 MB)
Partition: userdata, [00009EE00000 - 0001D1FFBE00], size: 0001331FBE00 (4.80 GB)
Brand = samsung
Device = j5lte
Model = SM-J500F
CMD Pullup Level: 2133 mV
CMD Active Level: 2628 mV
Backup saved: H8G4u_19E4950E_20200523_234529.extcsd
Operation: Erasing eMMC...
Erasing for: ROM1 , start: 0x000000000000 , size: 0x0001D2000000
Done erasing partition.
Setting frequence to 18 MHz
Backup saved: H8G4u_19E4950E_20200523_235322.extcsd
Operation: Writing all eMMC Regions...
Operation: Writing BootConfig ...
Reg: 179 Value: 0x00
Reg: 177 Value: 0x00
Reg: 162 Value: 0x00
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: boot1.bin
eMMC switching to ROM2
Done writing partition. Write speed: 867.65 KB/s
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Filename: boot2.bin
eMMC switching to ROM3
Done writing partition. Write speed: 851.69 KB/s
Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000
Filename: userarea_1GiB.bin
Done writing partition. Write speed: 2072.32 KB/s
All done time: [00:08:38:000]
CMD Pullup Level: 2130 mV
CMD Active Level: 2625 mV
Backup saved: H8G4u_19E4950E_20200524_000211.extcsd
Partition: userdata, [00009EE00000 - 0001D1FFB000], size: 0001331FB000 (4.80 GB)
Brand = samsung
Device = j5lte
Model = SM-J500F
Firmware version = LMY48B.J500FXWU1AOJ2
Firmware date = Tue Oct 6 14:22:11 KST 2015
CMD Pullup Level: 2139 mV
Backup saved: H8G4u_19E4950E_20200524_001132.extcsd
Brand = samsung
Device = j5lte
Model = SM-J500F
CMD Active Level: 2624 mV
Backup saved: H8G4u_19E4950E_20200524_001150.extcsd
Operation: Try to read table from emmc
Vendor: Qualcomm
Searching GPT ...
Checking for ROM2 ...
ROM2 is blank
Checking for ROM3 ...
ROM3 is blank
CMD Pullup Level: 2136 mV
CMD Active Level: 2623 mV
Backup saved: H8G4u_19E4950E_20200524_001347.extcsd
Operation: Write by vendor (Qualcomm/HiSilicon/Omap)
Partition name: fsg
Filename: fsg.bin , Offset: 000005078000 , filesize: 3145728 bytes
Done writing partition. Write speed: 1204.67 KB/s
Partition name: efs
Filename: efs.bin , Offset: 000006800000 , filesize: 14680064 bytes
Done writing partition. Write speed: 2074.66 KB/s
Partition name: modemst1
Filename: modemst1.bin , Offset: 000007600000 , filesize: 3145728 bytes
Done writing partition. Write speed: 2048.98 KB/s
Partition name: modemst2
Filename: modemst2.bin , Offset: 000007900000 , filesize: 3145728 bytes
Done writing partition. Write speed: 2000.38 KB/s
Partition name: fsc
Filename: fsc.bin , Offset: 00000AB7E000 , filesize: 3145728 bytes
Done writing partition. Write speed: 2008.01 KB/s
Partition name: persist
Filename: persist.bin , Offset: 00000AE80000 , filesize: 8388608 bytes
Done writing partition. Write speed: 2053.43 KB/s
Check BootConfig for the selected vendor
All done time: [00:00:32:237]
Finally flash with this firmware J500FXXU1AOH2_ J500FOJV1AOH1_V5.1.1_Repair_Firmware_4Files_( XFV South Africa (Vodafone)
The Following 2 Users Say Thank You to -=P.F.U=- For This Useful Post:
Old 08-12-2021, 14:45   #4 (permalink)
Member: 2631310
Thanks Meter: 15
thanks very goood its work
Page generated in 0.23382 seconds with 8 queries
