01-04-2021, 09:10 | #1 (permalink) |
Crazy Poster Join Date: Dec 2014 Location: Walling,syangja,nepal
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | a10s emmc problem Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 14 MHz EMMC Device Information : EMMC CID: 150100514436334D420349D50773864F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QD63MB , HEX: 514436334D42 , S/N: 49D50773 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2019 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 356 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QD63MB_49D50773_20210104_135452.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000400000 - 000000500000], size: 000000100000 (1.00 MB) Partition: para, [000000500000 - 000000580000], size: 000000080000 (512. KB) Partition: efuse, [000000580000 - 000000600000], size: 000000080000 (512. KB) Partition: nvram, [000000600000 - 000004600000], size: 000004000000 (64.0 MB) Partition: efs, [000004600000 - 000004E00000], size: 000000800000 (8.00 MB) Partition: sec_efs, [000004E00000 - 000005600000], size: 000000800000 (8.00 MB) Partition: bota, [000005600000 - 000006B00000], size: 000001500000 (21.0 MB) Partition: param, [000006B00000 - 000006F00000], size: 000000400000 (4.00 MB) Partition: up_param, [000006F00000 - 000007300000], size: 000000400000 (4.00 MB) Partition: expdb, [000007300000 - 000008700000], size: 000001400000 (20.0 MB) Partition: frp, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000008800000 - 00000A800000], size: 000002000000 (32.0 MB) Partition: nvdata, [00000A800000 - 00000E800000], size: 000004000000 (64.0 MB) Partition: metadata, [00000E800000 - 000010800000], size: 000002000000 (32.0 MB) Partition: protect1, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: protect2, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: seccfg, [000011800000 - 000012000000], size: 000000800000 (8.00 MB) Partition: persist, [000012000000 - 000015000000], size: 000003000000 (48.0 MB) Partition: persistent, [000015000000 - 000015080000], size: 000000080000 (512. KB) Partition: misc, [000015080000 - 000015800000], size: 000000780000 (7.50 MB) Partition: sec1, [000015800000 - 000015A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000015A00000 - 000015D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000015D00000 - 00001C100000], size: 000006400000 (100. MB) Partition: spmfw, [00001C100000 - 00001C200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001C200000 - 00001C300000], size: 000000100000 (1.00 MB) Partition: sspm_1, [00001C300000 - 00001C400000], size: 000000100000 (1.00 MB) Partition: lk, [00001C400000 - 00001C600000], size: 000000200000 (2.00 MB) Partition: steady, [00001C600000 - 00001CA00000], size: 000000400000 (4.00 MB) Partition: boot, [00001CA00000 - 00001EA00000], size: 000002000000 (32.0 MB) Partition: recovery, [00001EA00000 - 000020A00000], size: 000002000000 (32.0 MB) Partition: dtbo, [000020A00000 - 000021200000], size: 000000800000 (8.00 MB) Partition: tee1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB) Partition: vendor, [000021800000 - 00003D800000], size: 00001C000000 (448. MB) Partition: product, [00003D800000 - 000058800000], size: 00001B000000 (432. MB) Partition: system, [000058800000 - 000133800000], size: 0000DB000000 (3.42 GB) Partition: vbmeta, [000133800000 - 000134000000], size: 000000800000 (8.00 MB) Partition: cache, [000134000000 - 00014D000000], size: 000019000000 (400. MB) Partition: omr, [00014D000000 - 000150000000], size: 000003000000 (48.0 MB) Partition: userdata, [000150000000 - 000747800000], size: 0005F7800000 (23.8 GB) GPT header successfully parsed Get firmware version Error: Mount [data] failed PartType: LINUX Error: Except: Unmount [data/] failed |
