06-30-2021, 15:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: mystery city
Member: 1199392 Status: Offline Thanks Meter: 95 | cph 1937 ufs not detect Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: CFF02CCFB467BB53 EasyJtag Plus Box FirmWare: 2.53.2 Box Hardware = EasyJtag 2nd Generation UFS: Socket Info: S/N: 0x0123E546EEC671D9EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 26.11.20 Type: EasyJtag UFS Socket BGA-254 ID: 3815 UFS: Voltage Info: Mode: LOW VCC : 3247 mV, VCCQ2: 1915 mV 3v3 : 3312 mV, 1v2: 1207 mV UFS: Memory Info: Connection: Socket BGA-254 Vendor: SAMSUNG Name: KM5V7001DM-B621 S/N: 36bc8801311d OEM ID: SAMSUNG_OEM_ID Firm Version: 9.00 UFS Version: 2.1 Size: 0x001DCC800000/119.20 GB Max LUNs: 8 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS RPMB Info: RPMB Counter: 20362 UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 30111744 Block(s)/114.87 GB LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB LUN 3 -> Size: 8192 Block(s)/32.00 MB LUN 4 -> Size: 1048576 Block(s)/4.00 GB LUN 5 -> Size: 65536 Block(s)/256.00 MB W-LUN 0xC4 (RPMB) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 Error Reading Sector: 0, Count: 6, Err: -108/UNKN_ERR Try Again #1 Error Reading Sector: 0, Count: 6, Err: -102/UNKN_ERR Try Again #2 Error Reading Sector: 0, Count: 6, Err: -102/UNKN_ERR Try Again #3 Too Many Errors. Stopped. Err: -102/UNKN_ERR Error While Reading. Exit. Code: -102/UNKN_ERR Error While Scan Partitions. Scanner Shutdown.. Scanner Thread Terminated Elapsed: 00:01:52:086 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
06-30-2021, 15:41 | #2 (permalink) |
Member: 1199392 Status: Offline Thanks Meter: 95 | reset oppo faild Z3X EasyJtag Software ver. 3.7.0.23 UFS Socket Info. Serial: 0123E546EEC671D9EE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 26.11.20 Identify UFS Chip. UFS Chip Voltage: Low VCC: 3215mV VCCQ2: 1915mV Chip Info: Manufacturer: SAMSUNG ProductName: KM5V7001DM-B621 SerialNumber: 36bc8801311d OemID: SAMSUNG_OEM_ID Firmware Version: 9.00 UFS Version: 2.1 Maximum Number of LUs: 8 Number of LUs found: 6 LUN 0: Block size: 0x1000 Size: 0x1CB7800000 / 114,888,000,000B / 114GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 3: Block size: 0x1000 Size: 0x2000000 / 0,032,000,000B / 32MB LUN 4: Block size: 0x1000 Size: 0x100000000 / 4,000,000,000B / 4GB LUN 5: Block size: 0x1000 Size: 0x10000000 / 0,256,000,000B / 256MB Number of W-LUs found: 1 W-LUN 0xC4 (RPMB): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x1DCC800000 / 119,200,000,000B / 119GB RPMB: Counter: 20362 Health: Device life time method A: 0x01 (0%-10% device life time used) Device life time method B: 0x01 (0%-10% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Checking LU0 for partitioning LUN0 Have no partitions LUN1 Have 2 partitions LUN2 Have 2 partitions LUN3 Have 2 partitions LUN4 Have no partitions LUN5 Have 11 partitions ------ Detected 16 partitions ------ LUN1 (XBL) [0x6000 0x380000] Size: 3.500MB LUN1 (XBL_CONFIG) [0x386000 0x20000] Size: 128.0KB LUN2 (XBLBAK) [0x6000 0x380000] Size: 3.500MB LUN2 (XBL_CONFIGBAK) [0x386000 0x20000] Size: 128.0KB LUN3 (領⣴ᰥ頾㳽Ὸጘ쌈鷚棔פּٓ) [0x4967ddd83023c000 0] Size: 0.0B LUN5 (ALIGN_TO_128K_2) [0x6000 0x1a000] Size: 104.0KB LUN5 (OPPODYCNVBK) [0x20000 0xa00000] Size: 10.0MB LUN5 (OPPOSTANVBK) [0xa20000 0xa00000] Size: 10.0MB LUN5 (MODEMST1) [0x1420000 0x200000] Size: 2.0MB LUN5 (MODEMST2) [0x1620000 0x200000] Size: 2.0MB LUN5 (OPPORESERVE1) [0x1820000 0x800000] Size: 8.0MB LUN5 (OPPORESERVE2) [0x2020000 0x4000000] Size: 64.0MB LUN5 (OPPORESERVE3) [0x6020000 0x4000000] Size: 64.0MB LUN5 (DRIVER) [0xa020000 0x2000000] Size: 32.0MB LUN5 (FSG) [0xc020000 0x200000] Size: 2.0MB LUN5 (FSC) [0xc220000 0x20000] Size: 128.0KB ------------------------------------ Done. Z3X EasyJtag Software ver. 3.7.0.23 UFS Socket Info. Serial: 0123E546EEC671D9EE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 26.11.20 Identify UFS Chip. UFS Chip Voltage: Low VCC: 3225mV VCCQ2: 1916mV Chip Info: Manufacturer: SAMSUNG ProductName: KM5V7001DM-B621 SerialNumber: 36bc8801311d OemID: SAMSUNG_OEM_ID Firmware Version: 9.00 UFS Version: 2.1 Maximum Number of LUs: 8 Number of LUs found: 6 LUN 0: Block size: 0x1000 Size: 0x1CB7800000 / 114,888,000,000B / 114GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 3: Block size: 0x1000 Size: 0x2000000 / 0,032,000,000B / 32MB LUN 4: Block size: 0x1000 Size: 0x100000000 / 4,000,000,000B / 4GB LUN 5: Block size: 0x1000 Size: 0x10000000 / 0,256,000,000B / 256MB Number of W-LUs found: 1 W-LUN 0xC4 (RPMB): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x1DCC800000 / 119,200,000,000B / 119GB RPMB: Counter: 20362 Health: Device life time method A: 0x01 (0%-10% device life time used) Device life time method B: 0x01 (0%-10% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Can't stop LU, Code: -406, Reason: UAP SCSI: Command sense: UNIT_ATTENTION Done. |
