06-12-2021, 16:24 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | g532f after update mmc firmware died i connect by isp then check mmc very bad i read dump 512 and security file then update mmc firmware and factory reset and format mmc then i wirte dump phone not go download mode try wirte combination .try write 4 files but phonenot powre on info before do any thing 6/11/2021 12:34:52 AM> Looking for EasyJTAG box... 6/11/2021 12:34:52 AM> EasyJTAG API ver. 3403 6/11/2021 12:34:52 AM> Setting IO Levels to 1.8V 6/11/2021 12:34:52 AM> Setting frequence to 36 MHz 6/11/2021 12:34:52 AM> EasyJTAG Box Serial = 794D20531FC02DF6 6/11/2021 12:34:52 AM> EasyJTAG Box Firmware = 2.5302 6/11/2021 12:34:54 AM> Setting interface to EasyJtag2/ISP_HiPower 6/11/2021 12:34:54 AM> Setting bus width to 1 Bit 6/11/2021 12:34:54 AM> HiPower mode is ON 6/11/2021 12:34:54 AM> Setting frequence to 36 MHz 6/11/2021 12:34:54 AM> CMD Pullup Level: 1735 mV 6/11/2021 12:34:54 AM> CMD Active Level: 1883 mV 6/11/2021 12:34:54 AM> eMMC Init returned = 0 6/11/2021 12:34:54 AM> EMMC Device Information : 6/11/2021 12:34:54 AM> EMMC CID: 150100514E3136424200AA644FE1C3A5 6/11/2021 12:34:54 AM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 6/11/2021 12:34:54 AM> EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: AA644FE1 , rev. 0x00 6/11/2021 12:34:54 AM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2016 6/11/2021 12:34:54 AM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 6/11/2021 12:34:54 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 6/11/2021 12:34:54 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean 6/11/2021 12:34:54 AM> EMMC Permanent Write Protection: No 6/11/2021 12:34:54 AM> EMMC Temporary Write Protection: No 6/11/2021 12:34:55 AM> Extended CSD Information : 6/11/2021 12:34:55 AM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 6/11/2021 12:34:55 AM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 6/11/2021 12:34:55 AM> Boot Bus Config: 0x00 , width 1bit 6/11/2021 12:34:55 AM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 6/11/2021 12:34:55 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 6/11/2021 12:34:55 AM> Device supports partitioning features 6/11/2021 12:34:55 AM> Device can have enhanced technological features in partitions and user data area 6/11/2021 12:34:55 AM> Device can have extended partitions attribute 6/11/2021 12:34:55 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 6/11/2021 12:34:55 AM> Backup saved: QN16BB_AA644FE1_20210611_003455.extcsd 6/11/2021 12:34:55 AM> EMMC Init completed. 6/11/2021 12:34:55 AM> 6/11/2021 12:34:55 AM> Warning: Health report is very BAD 6/11/2021 12:34:55 AM> 6/11/2021 12:34:55 AM> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 6/11/2021 12:34:55 AM> Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time 6/11/2021 12:34:55 AM> Pre EOL information [267]: 0x01 Normal 6/11/2021 12:34:55 AM> 6/11/2021 12:34:56 AM> Scanning soft partitions 6/11/2021 12:34:56 AM> GPT header is found and is valid 6/11/2021 12:34:56 AM> Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) 6/11/2021 12:34:56 AM> Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) 6/11/2021 12:34:56 AM> Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) 6/11/2021 12:34:56 AM> Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) 6/11/2021 12:34:56 AM> Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) 6/11/2021 12:34:56 AM> Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) 6/11/2021 12:34:56 AM> Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) 6/11/2021 12:34:56 AM> Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) 6/11/2021 12:34:56 AM> Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) 6/11/2021 12:34:56 AM> Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) 6/11/2021 12:34:56 AM> Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) 6/11/2021 12:34:56 AM> Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) 6/11/2021 12:34:56 AM> Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) 6/11/2021 12:34:56 AM> Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) 6/11/2021 12:34:56 AM> Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) 6/11/2021 12:34:56 AM> Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) 6/11/2021 12:34:56 AM> Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) 6/11/2021 12:34:56 AM> Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) 6/11/2021 12:34:56 AM> Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) 6/11/2021 12:34:56 AM> Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) 6/11/2021 12:34:56 AM> Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) 6/11/2021 12:34:56 AM> Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) 6/11/2021 12:34:56 AM> Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) 6/11/2021 12:34:56 AM> Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) 6/11/2021 12:34:56 AM> Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) 6/11/2021 12:34:57 AM> Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) 6/11/2021 12:34:57 AM> Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) 6/11/2021 12:34:57 AM> Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) 6/11/2021 12:34:57 AM> Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 (3.63 GB) 6/11/2021 12:34:57 AM> GPT header successfully parsed 6/11/2021 12:34:57 AM> 6/11/2021 12:34:57 AM> Get firmware version 6/11/2021 12:34:57 AM> 6/11/2021 12:34:59 AM> Brand = samsung 6/11/2021 12:34:59 AM> Manufacturer = samsung 6/11/2021 12:34:59 AM> Device = grandpplte 6/11/2021 12:34:59 AM> Model = SM-G532F 6/11/2021 12:34:59 AM> Phone platform = mt6737t 6/11/2021 12:34:59 AM> CPU Abi = armeabi-v7a 6/11/2021 12:34:59 AM> Mediatek platform = MT6737T 6/11/2021 12:34:59 AM> Android release = 6.0.1 6/11/2021 12:34:59 AM> Security Patch = 2018-05-01 6/11/2021 12:34:59 AM> Firmware version = MMB29T.G532FXWU1ARE1 6/11/2021 12:34:59 AM> Firmware date = Wed May 2 17:38:45 KST 2018 |
06-12-2021, 16:25 | #2 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | this after write dump Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1827 mV CMD Active Level: 1889 mV EMMC Device Information : EMMC CID: 150100514E3136424200AA644FE1C3A5 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: AA644FE1 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_AA644FE1_20210612_171009.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 (3.63 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = grandpplte Model = SM-G532F Phone platform = mt6737t CPU Abi = armeabi-v7a Mediatek platform = MT6737T Android release = 6.0.1 Security Patch = 2018-05-01 Firmware version = MMB29T.G532FXWU1ARE1 Firmware date = Wed May 2 17:38:45 KST 2018 |
06-12-2021, 17:30 | #3 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1822 mV CMD Active Level: 1887 mV EMMC Device Information : EMMC CID: 150100514E3136424200AB5AAC5714CD EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: AB5AAC57 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16BB_AB5AAC57_20210612_182654.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: NVRAM, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: LK, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: SECRO, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: SECCFG, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: EFUSE, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: TEE1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: NVDATA, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: RECOVERY, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: BOOT, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: MD1IMG, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: MD1DSP, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: KEYSTORE, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: OMEKEYSTORE, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: PROINFO, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: PARA, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: PROTECT1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: SYSTEM, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: CACHE, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: HIDDEN, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: USERDATA, [0000E9400000 - 0001D1FFBE00], size: 0000E8BFBE00 (3.64 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = grandpplte Model = SM-G532F Phone platform = mt6737t CPU Abi = armeabi-v7a Mediatek platform = MT6737T Android release = 6.0.1 Security Patch = 2018-05-01 Firmware version = MMB29T.G532FXWU1ARE1 Firmware date = Wed May 2 17:38:45 KST 2018 |
