..::GMSR::.. 10-13-2021 02:43
A20 A205F MDM LOCK || NO DOWNLOAD MODE || NO RECOVERY MODE || FIX by Easy Jtag Plus
A20 A205F MDM LOCK || NO DOWNLOAD MODE || NO RECOVERY MODE || FIX by Easy Jtag Plus http://www.youtube.com/watch?v=pIoqM2CKlS8 Before Repair Log Code:
12.10.2021 21:05:44> Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started..
12.10.2021 21:05:55> Box API Version: 3401
12.10.2021 21:05:55> FS Driver Version: 29062020
12.10.2021 21:05:55> SQLite Version: 3.32.0
12.10.2021 21:05:55> FSCK Engine Version: 29062020
12.10.2021 21:05:55> ESE DB Version: 29062020
12.10.2021 21:05:55> System Util Version: 29062020
12.10.2021 21:05:55> System: Windows NT 6.1 (Build 7601, Service Pack 1) / 32 BIT
12.10.2021 21:05:55> CPU: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
12.10.2021 21:05:55> Total RAM: 2.89 GB
12.10.2021 21:05:55> Telegram Support: https://t.me/z3xefm
12.10.2021 21:05:55> FRP Apps: http://efm.easy-jtag.com/frp/
12.10.2021 21:05:57> Z3X Card Serial: AA2778BA
12.10.2021 21:05:57> EasyJtag Plus Box Found at: COM4
12.10.2021 21:05:57> EasyJtag Plus Box Firmware: 2.53.1
12.10.2021 21:06:21> Source: EasyJtag Port [EMMC/SD/MMC]
12.10.2021 21:06:21> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
12.10.2021 21:06:21> Box Voltage set to: 2800 mV
12.10.2021 21:06:21> Scanner Thread Created..
12.10.2021 21:06:21> Config: 1011111111101111
12.10.2021 21:06:21> Setup HiPower CLK: OFF
12.10.2021 21:06:21> Connecting To EasyJtag Plus Box: 2800mV/12MHz/1BIT
12.10.2021 21:06:22> EasyJtag Plus Box Found! Result: 0/OK
12.10.2021 21:06:22> CMD Pullup Level: 483 mV
12.10.2021 21:06:22> CMD Active Level: 1501 mV
12.10.2021 21:06:22> EasyJtag Plus S/N: F6F272D292237F2E
12.10.2021 21:06:22> EasyJtag Plus Box FirmWare: 2.53
12.10.2021 21:06:22> Box Bus Width = 1 BIT
12.10.2021 21:06:22> Box Hardware = EasyJtag 2nd Generation
12.10.2021 21:06:22> Search EMMC Chip...
12.10.2021 21:06:23> EMMC Chip Found! 0/OK
12.10.2021 21:06:23> EMMC CID: 150100424A5444345200C28D48ACC691
12.10.2021 21:06:23> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12.10.2021 21:06:23> EMMC VENDOR: SAMSUNG
12.10.2021 21:06:23> EMMC NAME: BJTD4R
12.10.2021 21:06:23> EMMC SERIAL: C28D48AC
12.10.2021 21:06:23> EMMC REVISION: 00
12.10.2021 21:06:23> EMMC ROM1 Size: 61071360 Block(s)/29820 MB
12.10.2021 21:06:23> EMMC ROM2/3 Size: 8192 Block(s)/4096 KB
12.10.2021 21:06:23> EMMC RPMB Size: 32768 Block(s)/16384 KB
12.10.2021 21:06:23> EMMC RPMB Counter: 0
12.10.2021 21:06:23> EMMC RPMB Answer: -8/UNKN_ERR
12.10.2021 21:06:23> Switch To ROM1 Part: 0/OK
12.10.2021 21:06:23> EMMC REV: 1.8 (for MMC v5.1)
12.10.2021 21:06:23> EMMC VER: MMC 5.1
12.10.2021 21:06:23> EMMC DEV Life Time: 0x01 - Normal
12.10.2021 21:06:23> EMMC MLC Life Time: 0x01 - 0% - 10% Life Time Used
12.10.2021 21:06:23> EMMC SLC Life Time: 0x01 - 0% - 10% Life Time Used
12.10.2021 21:06:23> EMMC Boot Config: 0x48/0x01/0x01
12.10.2021 21:06:23> ExtCSD Automatically Saved..
12.10.2021 21:06:23> Scanning Data From EMMC. Please wait..
12.10.2021 21:06:23> Error Reading Sector: 0, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:23> Try Again #1
12.10.2021 21:06:23> Try Again #2
12.10.2021 21:06:24> Try Again #3
12.10.2021 21:06:24> Error Reading Sector: 0, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:24> Resetting EasyJtag Box...
12.10.2021 21:06:25> CMD Pullup Level: 484 mV
12.10.2021 21:06:25> CMD Active Level: 1501 mV
12.10.2021 21:06:25> Try Again #1
12.10.2021 21:06:25> Error Reading Sector: 0, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:25> Resetting EasyJtag Box...
12.10.2021 21:06:26> CMD Pullup Level: 483 mV
12.10.2021 21:06:26> CMD Active Level: 1501 mV
12.10.2021 21:06:26> Try Again #2
12.10.2021 21:06:26> Error Reading Sector: 0, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:26> Resetting EasyJtag Box...
12.10.2021 21:06:27> CMD Pullup Level: 482 mV
12.10.2021 21:06:27> CMD Active Level: 1501 mV
12.10.2021 21:06:27> Try Again #3
12.10.2021 21:06:27> Too Many Errors. Stopped. Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:27> Error While Reading. Exit. Code: -1/CMD_TOUT_ERR
12.10.2021 21:06:27> Error While Scan Partitions. Scanner Shutdown..
12.10.2021 21:06:27> Scanner Thread Terminated
12.10.2021 21:06:27> Elapsed: 00:00:06:127
12.10.2021 21:06:27> Found 0 Partition(s)..
12.10.2021 21:06:27> Search Partitions Fail..
12.10.2021 21:06:27> Check EMMC or Run Pool Test..
12.10.2021 21:06:47> Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020
12.10.2021 21:06:54> Source: EasyJtag Port [EMMC/SD/MMC]
12.10.2021 21:06:54> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
12.10.2021 21:06:54> Box Voltage set to: 2800 mV
12.10.2021 21:06:54> Scanner Thread Created..
12.10.2021 21:06:54> Config: 1011111111101111
12.10.2021 21:06:54> Setup HiPower CLK: OFF
12.10.2021 21:06:54> Connecting To EasyJtag Plus Box: 2800mV/6MHz/1BIT
12.10.2021 21:06:55> EasyJtag Plus Box Found! Result: 0/OK
12.10.2021 21:06:55> CMD Pullup Level: 484 mV
12.10.2021 21:06:55> CMD Active Level: 1501 mV
12.10.2021 21:06:56> EasyJtag Plus S/N: F6F272D292237F2E
12.10.2021 21:06:56> EasyJtag Plus Box FirmWare: 2.53
12.10.2021 21:06:56> Box Bus Width = 1 BIT
12.10.2021 21:06:56> Box Hardware = EasyJtag 2nd Generation
12.10.2021 21:06:56> Search EMMC Chip...
12.10.2021 21:06:56> EMMC Chip Found! 0/OK
12.10.2021 21:06:56> EMMC CID: 150100424A5444345200C28D48ACC691
12.10.2021 21:06:56> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
12.10.2021 21:06:56> EMMC VENDOR: SAMSUNG
12.10.2021 21:06:56> EMMC NAME: BJTD4R
12.10.2021 21:06:56> EMMC SERIAL: C28D48AC
12.10.2021 21:06:56> EMMC REVISION: 00
12.10.2021 21:06:56> EMMC ROM1 Size: 61071360 Block(s)/29820 MB
12.10.2021 21:06:56> EMMC ROM2/3 Size: 8192 Block(s)/4096 KB
12.10.2021 21:06:56> EMMC RPMB Size: 32768 Block(s)/16384 KB
12.10.2021 21:06:56> EMMC RPMB Counter: 0
12.10.2021 21:06:56> EMMC RPMB Answer: -8/UNKN_ERR
12.10.2021 21:06:56> Switch To ROM1 Part: 0/OK
12.10.2021 21:06:56> EMMC REV: 1.8 (for MMC v5.1)
12.10.2021 21:06:56> EMMC VER: MMC 5.1
12.10.2021 21:06:56> EMMC DEV Life Time: 0x01 - Normal
12.10.2021 21:06:56> EMMC MLC Life Time: 0x01 - 0% - 10% Life Time Used
12.10.2021 21:06:56> EMMC SLC Life Time: 0x01 - 0% - 10% Life Time Used
12.10.2021 21:06:56> EMMC Boot Config: 0x48/0x01/0x01
12.10.2021 21:06:56> ExtCSD Automatically Saved..
12.10.2021 21:06:56> Scanning Data From EMMC. Please wait..
12.10.2021 21:06:56> Scanning GUID Partition Table from ROM1
12.10.2021 21:06:56> GUID Partition Table is Found. Max Parts: 128
12.10.2021 21:06:56> GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB
12.10.2021 21:06:56> GPT: BOTA0 [000000400000 - 000000400000] Size: 4.00 MB
12.10.2021 21:06:56> GPT: BOTA1 [000000800000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: EFS [000001000000 - 000001400000] Size: 20.00 MB
12.10.2021 21:06:56> GPT: SEC_EFS [000002400000 - 000001400000] Size: 20.00 MB
12.10.2021 21:06:56> GPT: CPEFS [000003800000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: BOTA2 [000004000000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: CM [000004800000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: M9KEFS1 [000005000000 - 000000400000] Size: 4.00 MB
12.10.2021 21:06:56> GPT: M9KEFS2 [000005400000 - 000000400000] Size: 4.00 MB
12.10.2021 21:06:56> GPT: M9KEFS3 [000005800000 - 000000400000] Size: 4.00 MB
12.10.2021 21:06:56> GPT: NAD_REFER [000005C00000 - 000000100000] Size: 1.00 MB
12.10.2021 21:06:56> GPT: PARAM [000005D00000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: UP_PARAM [000006500000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: MISC [000006D00000 - 000000200000] Size: 2.00 MB
12.10.2021 21:06:56> GPT: BOOT [000006F00000 - 000002400000] Size: 36.00 MB
12.10.2021 21:06:56> GPT: RECOVERY [000009300000 - 000003500000] Size: 53.00 MB
12.10.2021 21:06:56> GPT: DTB [00000C800000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: DTBO [00000D000000 - 000000800000] Size: 8.00 MB
12.10.2021 21:06:56> GPT: RADIO [00000D800000 - 000002D00000] Size: 45.00 MB
12.10.2021 21:06:56> GPT: PERSISTENT [000010500000 - 000000080000] Size: 512.00 KB
12.10.2021 21:06:56> GPT: STEADY [000010580000 - 000000400000] Size: 4.00 MB
12.10.2021 21:06:56> GPT: VBMETA [000010980000 - 000000080000] Size: 512.00 KB
12.10.2021 21:06:56> GPT: BOTA3 [000010A00000 - 000000080000] Size: 512.00 KB
12.10.2021 21:06:56> GPT: RESERVED2 [000010A80000 - 000000580000] Size: 5.50 MB
12.10.2021 21:06:56> GPT: SYSTEM [000011000000 - 000101800000] Size: 4.02 GB
12.10.2021 21:06:56> GPT: VENDOR [000112800000 - 000022000000] Size: 544.00 MB
12.10.2021 21:06:56> GPT: PRODUCT [000134800000 - 000019000000] Size: 400.00 MB
12.10.2021 21:06:56> GPT: CACHE [00014D800000 - 000019000000] Size: 400.00 MB
12.10.2021 21:06:56> GPT: OMR [000166800000 - 000003200000] Size: 50.00 MB
12.10.2021 21:06:56> GPT: CP_DEBUG [000169A00000 - 000000500000] Size: 5.00 MB
12.10.2021 21:06:56> GPT: NAD_FW [000169F00000 - 000001400000] Size: 20.00 MB
12.10.2021 21:06:56> GPT: USERDATA [00016B300000 - 0005DC400000] Size: 23.44 GB
12.10.2021 21:06:56> GPT Backup Header Not Found
12.10.2021 21:06:56> Reading Table Completed
12.10.2021 21:06:56> Scanning GUID Partition Table from ROM2
12.10.2021 21:06:56> GPT Signature Not Found. Break..
12.10.2021 21:06:56> Scanning GUID Partition Table from ROM3
12.10.2021 21:06:57> GPT Signature Not Found. Break..
12.10.2021 21:06:57> Error Reading Sector: 8192, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:57> Try Again #1
12.10.2021 21:06:58> Try Again #2
12.10.2021 21:06:58> Partition #7 mount as [/mnt/vendor/efs] - 20.00 MB
12.10.2021 21:06:58> Partition #8 mount as [/efs] - 20.00 MB
12.10.2021 21:06:58> Partition #9 mount as [/mnt/vendor/cpefs] - 8.00 MB
12.10.2021 21:06:58> Error Reading Sector: 131072, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:58> Try Again #1
12.10.2021 21:06:58> Error Reading Sector: 163840, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:59> Try Again #1
12.10.2021 21:06:59> Error Reading Sector: 172032, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:06:59> Try Again #2
12.10.2021 21:06:59> Error Reading Sector: 180224, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:00> Try Again #1
12.10.2021 21:07:00> Error Reading Sector: 180224, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:00> Try Again #2
12.10.2021 21:07:00> Error Reading Sector: 188416, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:01> Error Reading Sector: 188416, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:01> Try Again #3
12.10.2021 21:07:01> Error Reading Sector: 190464, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:01> Try Again #1
12.10.2021 21:07:01> Error Reading Sector: 206848, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:02>
12.10.2021 21:07:02> Error Reading Sector: 223232, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:02> Try Again #1
12.10.2021 21:07:02> Try Again #2
12.10.2021 21:07:02> Try Again #3
12.10.2021 21:07:02> Resetting EasyJtag Box...
12.10.2021 21:07:03> CMD Pullup Level: 483 mV
12.10.2021 21:07:03> CMD Active Level: 1501 mV
12.10.2021 21:07:04> Try Again #1
12.10.2021 21:07:04> Error Reading Sector: 223232, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:04> Resetting EasyJtag Box...
12.10.2021 21:07:04> CMD Pullup Level: 483 mV
12.10.2021 21:07:04> CMD Active Level: 1500 mV
12.10.2021 21:07:05> Try Again #2
12.10.2021 21:07:05> Error Reading Sector: 223232, Count: 5, Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:05> Resetting EasyJtag Box...
12.10.2021 21:07:06> CMD Pullup Level: 483 mV
12.10.2021 21:07:06> CMD Active Level: 1500 mV
12.10.2021 21:07:06> Try Again #3
12.10.2021 21:07:06> Too Many Errors. Stopped. Err: -1/CMD_TOUT_ERR
12.10.2021 21:07:06> Error While Reading. Exit. Code: -1/CMD_TOUT_ERR
12.10.2021 21:07:06> Scanner Thread Terminated
12.10.2021 21:07:06> Elapsed: 00:00:11:576
12.10.2021 21:07:06> Found 36 Partition(s)..
12.10.2021 21:07:06> Scan Done. Init Main Engine...
12.10.2021 21:07:06> Resetting EasyJtag Box. Wait..
12.10.2021 21:07:07> CMD Pullup Level: 482 mV
12.10.2021 21:07:07> CMD Active Level: 1502 mV
12.10.2021 21:07:07> Reader Engine Initialized.. 0/OK
12.10.2021 21:07:07> Source: EasyJtag Port [EMMC/SD/MMC]
12.10.2021 21:07:07> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
12.10.2021 21:07:07> Bus Mode: 1BIT
12.10.2021 21:07:07> Operation Done: [Init Engine], Elapsed: 00:00:01:536
After Repair Log Code:
Total RAM: 2.89 GB
Connecting To EasyJtag Plus Box: 2800mV/1MHz/1BIT
Search EMMC Chip...
EMMC NAME: BJTD4R
EMMC REVISION: 00
EMMC RPMB Counter: 1289
EMMC RPMB Answer: 0/OK
EMMC VER: MMC 5.1
EMMC DEV Life Time: 0x01 -> Normal
EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used
EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used
GPT: USERDATA [00016B300000 - 0005DC8FBE00] Size: 23.45 GB
GPT: BACKUP_GPT [000747BFBE00 - 000000004200] Size: 16.50 KB
Partition #7 mount as [/mnt/vendor/efs] -> 20.00 MB
Partition #8 mount as [/efs] -> 20.00 MB
Partition #9 mount as [/mnt/vendor/cpefs] -> 8.00 MB
Partition #29 mount as [/dev_29] -> 4.02 GB
Partition #30 mount as [/dev_30] -> 544.00 MB
Partition #31 mount as [/dev_31] -> 400.00 MB
Partition #33 mount as [/omr] -> 50.00 MB
EmptyCheck:
EMPTY -> #4 - [BOTA0]
EMPTY -> #5 - [BOTA1]
EMPTY -> #9 - [BOTA2]
EMPTY -> #11 - [M9KEFS1]
EMPTY -> #12 - [M9KEFS2]
EMPTY -> #13 - [M9KEFS3]
EMPTY -> #16 - [UP_PARAM]
EMPTY -> #17 - [MISC]
EMPTY -> #23 - [PERSISTENT]
EMPTY -> #26 - [BOTA3]
EMPTY -> #27 - [RESERVED2]
EMPTY -> #31 - [CACHE]
EMPTY -> #34 - [NAD_FW]
EMPTY -> #35 - [USERDATA]
EmptyCheck: Done
Android Info:
Brand = samsung
Vendor = samsung
Device = a20
Model = SM-A205F
Product = a20
CPU ABI = arm64-v8a
Android Version = 9
Firm Version = PPR1.180610.011.FA90_A205FDDU3ASK6
Inc. Version = FA90_A205FDDU3ASK6
Firm Date = Mon Nov 11 12:21:31 KST 2019
Security Patch = 2019-02-01
Android Info:
Platform = exynos5
Android Info:
Samsung S/N = RZ8N20ADPWW
Elapsed: 00:00:46:728
Found 37 Partition(s)..
Bus Mode: 1BIT
Operation Done: [Init Engine], Elapsed: 00:00:01:561
