03-29-2022, 11:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | A20s │SM-A207F │ISP PIN OUT and FRP RESET ││ DUMP BACKUP by EASY JTAG PLUS GSM iNFO ISP Pin Out ==> Code: Z3X EasyJtag EMMC File Manager v 1.21 FINAL at 09/01/2022 Started.. Box API Version: 3403 FS Driver Version: 04012021 SQLite Version: 3.37.1 FSCK Engine Version: 04012021 ESE DB Version: 04012021 System Util Version: 04012021 System: Windows NT 6.1 (Build 7601, Service Pack 1) / 64 BIT CPU: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz Total RAM: 7.70 GB System Date: 3/29/2022 12:33:11 PM Official Site: http://efm.easy-jtag.com/ Telegram Support: https://t.me/z3xefm FRP Apps: http://efm.easy-jtag.com/frp/ Z3X Card Serial: AA42F346 EasyJtag Plus Box Found at: COM33 EasyJtag Plus Box Firmware: 2.53.1 Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/24MHz/1BIT EasyJtag Plus Box Found! Result: 0/OK CMD Pullup Level: 2071 mV CMD Active Level: 2298 mV EasyJtag Plus S/N: 2782D60F58665178 EasyJtag Plus Box FirmWare: 2.53.1 Box Bus Width = 1 BIT Box Hardware = EasyJtag 2nd Generation Search Emmc Chip... EMMC Chip Found! 0/OK EMMC CID: 150100474436424D42018DE897EBB69F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC VENDOR: SAMSUNG EMMC NAME: GD6BMB EMMC DATE: 11/2019 EMMC SERIAL: 8DE897EB EMMC REVISION: 01 EMMC ROM1 Size: 61071360 Block(s)/29820 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 8192 Block(s)/4096 KB EMMC RPMB Counter: 46834, State: Dirty EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x02 -> 10% - 20% Life Time Used EMMC SLC Life Time: 0x02 -> 10% - 20% Life Time Used EMMC Boot Config: 0x38/0x00/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 128 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: SBL1 [000000405000 - 000000080000] Size: 512.00 KB GPT: RPM [000000485000 - 000000080000] Size: 512.00 KB GPT: TZ [000000505000 - 000000200000] Size: 2.00 MB GPT: DEVCFG [000000705000 - 000000040000] Size: 256.00 KB GPT: DSP [000000745000 - 000001000000] Size: 16.00 MB GPT: MDTP [000001745000 - 000002000000] Size: 32.00 MB GPT: SBL1BAK [000003745000 - 000000080000] Size: 512.00 KB GPT: RPMBAK [0000037C5000 - 000000080000] Size: 512.00 KB GPT: TZBAK [000003845000 - 000000200000] Size: 2.00 MB GPT: DEVCFGBAK [000003A45000 - 0000005BB000] Size: 5.73 MB GPT: LKSECAPP [000004000000 - 000000020000] Size: 128.00 KB GPT: CMNLIB [000004020000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64 [000004120000 - 000000100000] Size: 1.00 MB GPT: KEYMASTER [000004220000 - 000000100000] Size: 1.00 MB GPT: ABOOT [000004320000 - 000000200000] Size: 2.00 MB GPT: VBMETA [000004520000 - 000000010000] Size: 64.00 KB GPT: RESERVED [000004530000 - 0000002D0000] Size: 2.81 MB GPT: VK [000004800000 - 000000200000] Size: 2.00 MB GPT: EM [000004A00000 - 000000400000] Size: 4.00 MB GPT: BKSECAPP [000004E00000 - 000000080000] Size: 512.00 KB GPT: BTD [000004E80000 - 000000180000] Size: 1.50 MB GPT: LKSECAPPBAK [000005000000 - 000000020000] Size: 128.00 KB GPT: CMNLIBBAK [000005020000 - 000000100000] Size: 1.00 MB GPT: CMNLIB64BAK [000005120000 - 000000100000] Size: 1.00 MB GPT: KEYMASTERBAK [000005220000 - 000000100000] Size: 1.00 MB GPT: ABOOTBAK [000005320000 - 000000200000] Size: 2.00 MB GPT: DTBO [000005520000 - 000000800000] Size: 8.00 MB GPT: VBMETABAK [000005D20000 - 000000010000] Size: 64.00 KB GPT: APNHLOS [000005D30000 - 000006AD0000] Size: 106.81 MB GPT: FSC [00000C800000 - 000000340000] Size: 3.25 MB GPT: SSD [00000CB40000 - 000000040000] Size: 256.00 KB GPT: MOTA [00000CB80000 - 000000080000] Size: 512.00 KB GPT: DIP [00000CC00000 - 000000400000] Size: 4.00 MB GPT: DDR [00000D000000 - 000000080000] Size: 512.00 KB GPT: SEC [00000D080000 - 000000040000] Size: 256.00 KB GPT: FSG [00000D0C0000 - 000000A00000] Size: 10.00 MB GPT: LIMITS [00000DAC0000 - 000000008000] Size: 32.00 KB GPT: DEVINFO [00000DAC8000 - 000000538000] Size: 5.22 MB GPT: PAD [00000E000000 - 000000040000] Size: 256.00 KB GPT: MODEMST1 [00000E040000 - 000000400000] Size: 4.00 MB GPT: MODEMST2 [00000E440000 - 000000400000] Size: 4.00 MB GPT: SEC_EFS [00000E840000 - 000001000000] Size: 16.00 MB GPT: EFS [00000F840000 - 000001000000] Size: 16.00 MB GPT: SPLASH [000010840000 - 000000B00000] Size: 11.00 MB GPT: APDP [000011340000 - 000000040000] Size: 256.00 KB GPT: MSADP [000011380000 - 000000040000] Size: 256.00 KB GPT: PARAM [0000113C0000 - 000000C00000] Size: 12.00 MB GPT: PERSIST [000011FC0000 - 000002000000] Size: 32.00 MB GPT: MISC [000013FC0000 - 000000100000] Size: 1.00 MB GPT: SYSCFG [0000140C0000 - 000000080000] Size: 512.00 KB GPT: MCFG [000014140000 - 000000400000] Size: 4.00 MB GPT: DPO [000014540000 - 000000002000] Size: 8.00 KB GPT: LOGDUMP [000014542000 - 000004000000] Size: 64.00 MB GPT: KEYSTORE [000018542000 - 000000080000] Size: 512.00 KB GPT: CONFIG [0000185C2000 - 000000008000] Size: 32.00 KB GPT: OEM [0000185CA000 - 000010000000] Size: 256.00 MB GPT: BOOT [0000285CA000 - 000004000000] Size: 64.00 MB GPT: RECOVERY [00002C5CA000 - 000004000000] Size: 64.00 MB GPT: DEBUG [0000305CA000 - 000000A36000] Size: 10.21 MB GPT: STEADY [000031000000 - 000000400000] Size: 4.00 MB GPT: PERSISTENT [000031400000 - 000000080000] Size: 512.00 KB GPT: BOTA [000031480000 - 000002380000] Size: 35.50 MB GPT: SYSTEM [000033800000 - 0000F0000000] Size: 3.75 GB GPT: VENDOR [000123800000 - 00003D000000] Size: 976.00 MB GPT: PRODUCT [000160800000 - 000014800000] Size: 328.00 MB GPT: CACHE [000175000000 - 00000D400000] Size: 212.00 MB GPT: OMR [000182400000 - 000003700000] Size: 55.00 MB GPT: MODEM [000185B00000 - 000005D00000] Size: 93.00 MB GPT: USERDATA [00018B800000 - 0005BC3FB000] Size: 22.94 GB GPT: BACKUP_GPT [000747BFBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Reading Initial Data. Please Wait.. Partition #6 - [DSP] mount as [/dev_5] -> 16.00 MB, Type: EXT4 Partition #30 - [APNHLOS] mount as [/APNHLOS] -> 106.81 MB, Type: FAT16 Partition #43 - [SEC_EFS] mount as [/efs] -> 16.00 MB, Type: EXT4 Partition #44 - [EFS] mount as [/mnt/vendor/efs] -> 16.00 MB, Type: EXT4 Partition #49 - [PERSIST] mount as [/mnt/vendor/persist] -> 32.00 MB, Type: EXT4 Partition #64 - [SYSTEM] mount as [/dev_63] -> 3.75 GB, Type: EXT4 Partition #65 - [VENDOR] mount as [/vendor] -> 976.00 MB, Type: EXT4 Partition #66 - [PRODUCT] mount as [/product] -> 328.00 MB, Type: EXT4 Partition #67 - [CACHE] mount as [/cache] -> 212.00 MB, Type: EXT4 Partition #68 - [OMR] mount as [/omr] -> 55.00 MB, Type: EXT4 Partition #69 - [MODEM] mount as [/MODEM] -> 93.00 MB, Type: FAT16 Partition #70 - [USERDATA] mount as [/data] -> 22.94 GB, Type: EXT4 ================================= Warning! Partition #69 -> 'USERDATA' Contain ENCRYPTED Files! ================================= EmptyCheck: EMPTY -> ROM_1 -> Part #18 - [RESERVED] EMPTY -> ROM_1 -> Part #20 - [EM] EMPTY -> ROM_1 -> Part #22 - [BTD] EMPTY -> ROM_1 -> Part #31 - [FSC] EMPTY -> ROM_1 -> Part #32 - [SSD] EMPTY -> ROM_1 -> Part #33 - [MOTA] EMPTY -> ROM_1 -> Part #34 - [DIP] EMPTY -> ROM_1 -> Part #38 - [LIMITS] EMPTY -> ROM_1 -> Part #40 - [PAD] EMPTY -> ROM_1 -> Part #45 - [SPLASH] EMPTY -> ROM_1 -> Part #50 - [MISC] EMPTY -> ROM_1 -> Part #51 - [SYSCFG] EMPTY -> ROM_1 -> Part #52 - [MCFG] EMPTY -> ROM_1 -> Part #53 - [DPO] EMPTY -> ROM_1 -> Part #54 - [LOGDUMP] EMPTY -> ROM_1 -> Part #55 - [KEYSTORE] EMPTY -> ROM_1 -> Part #57 - [OEM] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition: #62 -> ROM_1 -> 'PERSISTENT' ================================= Android Info: Brand = samsung Vendor = samsung Device = a20s Model = SM-A207F Name ID = a20sxx Product = a20s CPU ABI = arm64-v8a Android Version = 11 Firm Version = RP1A.200720.012.A207FXXU3CUL1 Inc. Version = A207FXXU3CUL1 Firm Date = Fri Dec 10 16:02:18 +07 2021 Security Patch = 2021-12-01 Chip Name = SDM450 Platform = msm8953 FRP Path = /dev/block/persistent Samsung S/N = R9AMC1A10FJ Scanner Thread Terminated Elapsed: 00:00:11:193 Found 71 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2070 mV CMD Active Level: 2297 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1011111111101111 Bus Mode: 1BIT Operation Done: [Init Engine], Elapsed: 00:00:01:537 Multi Read Partitons: Path: D:\A207FXXU3CUL1_eMMC File Manager Backup\ Initializing Reader Engine.. Part Name: 'ROM_2' ROM: 2, Addr: 0x000000000000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'ROM_3' ROM: 3, Addr: 0x000000000000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'GPT_LAYOUT_ROM1' ROM: 1, Addr: 0x000000000000, Size: 17.00 KB Reading Partition.. Read Done. Count: 34 Part Name: 'SBL1' ROM: 1, Addr: 0x000000405000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'RPM' ROM: 1, Addr: 0x000000485000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'TZ' ROM: 1, Addr: 0x000000505000, Size: 2.00 MB Reading Partition.. Read Done. Count: 4096 Part Name: 'DEVCFG' ROM: 1, Addr: 0x000000705000, Size: 256.00 KB Reading Partition.. Read Done. Count: 512 Part Name: 'DSP' ROM: 1, Addr: 0x000000745000, Size: 16.00 MB Reading Partition.. Read Done. Count: 32768 Part Name: 'MDTP' ROM: 1, Addr: 0x000001745000, Size: 32.00 MB Reading Partition.. Read Done. Count: 65536 Part Name: 'SBL1BAK' ROM: 1, Addr: 0x000003745000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'RPMBAK' ROM: 1, Addr: 0x0000037C5000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'TZBAK' ROM: 1, Addr: 0x000003845000, Size: 2.00 MB Reading Partition.. Read Done. Count: 4096 Part Name: 'DEVCFGBAK' ROM: 1, Addr: 0x000003A45000, Size: 5.73 MB Reading Partition.. Read Done. Count: 11736 Part Name: 'LKSECAPP' ROM: 1, Addr: 0x000004000000, Size: 128.00 KB Reading Partition.. Read Done. Count: 256 Part Name: 'CMNLIB' ROM: 1, Addr: 0x000004020000, Size: 1.00 MB Reading Partition.. Read Done. Count: 2048 Part Name: 'CMNLIB64' ROM: 1, Addr: 0x000004120000, Size: 1.00 MB Reading Partition.. Read Done. Count: 2048 Part Name: 'KEYMASTER' ROM: 1, Addr: 0x000004220000, Size: 1.00 MB Reading Partition.. Read Done. Count: 2048 Part Name: 'ABOOT' ROM: 1, Addr: 0x000004320000, Size: 2.00 MB Reading Partition.. Read Done. Count: 4096 Part Name: 'VBMETA' ROM: 1, Addr: 0x000004520000, Size: 64.00 KB Reading Partition.. Read Done. Count: 128 Part Name: 'RESERVED' ROM: 1, Addr: 0x000004530000, Size: 2.81 MB Reading Partition.. Read Done. Count: 5760 Part Name: 'VK' ROM: 1, Addr: 0x000004800000, Size: 2.00 MB Reading Partition.. Read Done. Count: 4096 Part Name: 'EM' ROM: 1, Addr: 0x000004A00000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'BKSECAPP' ROM: 1, Addr: 0x000004E00000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'BTD' ROM: 1, Addr: 0x000004E80000, Size: 1.50 MB Reading Partition.. Read Done. Count: 3072 Part Name: 'LKSECAPPBAK' ROM: 1, Addr: 0x000005000000, Size: 128.00 KB Reading Partition.. Read Done. Count: 256 Part Name: 'CMNLIBBAK' ROM: 1, Addr: 0x000005020000, Size: 1.00 MB Reading Partition.. Read Done. Count: 2048 Part Name: 'CMNLIB64BAK' ROM: 1, Addr: 0x000005120000, Size: 1.00 MB Reading Partition.. Read Done. Count: 2048 Part Name: 'KEYMASTERBAK' ROM: 1, Addr: 0x000005220000, Size: 1.00 MB Reading Partition.. Read Done. Count: 2048 Part Name: 'ABOOTBAK' ROM: 1, Addr: 0x000005320000, Size: 2.00 MB Reading Partition.. Read Done. Count: 4096 Part Name: 'DTBO' ROM: 1, Addr: 0x000005520000, Size: 8.00 MB Reading Partition.. Read Done. Count: 16384 Part Name: 'VBMETABAK' ROM: 1, Addr: 0x000005D20000, Size: 64.00 KB Reading Partition.. Read Done. Count: 128 Part Name: 'APNHLOS' ROM: 1, Addr: 0x000005D30000, Size: 106.81 MB Reading Partition.. Read Done. Count: 218752 Part Name: 'FSC' ROM: 1, Addr: 0x00000C800000, Size: 3.25 MB Reading Partition.. Read Done. Count: 6656 Part Name: 'SSD' ROM: 1, Addr: 0x00000CB40000, Size: 256.00 KB Reading Partition.. Read Done. Count: 512 Part Name: 'MOTA' ROM: 1, Addr: 0x00000CB80000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'DIP' ROM: 1, Addr: 0x00000CC00000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'DDR' ROM: 1, Addr: 0x00000D000000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'SEC' ROM: 1, Addr: 0x00000D080000, Size: 256.00 KB Reading Partition.. Read Done. Count: 512 Part Name: 'FSG' ROM: 1, Addr: 0x00000D0C0000, Size: 10.00 MB Reading Partition.. Read Done. Count: 20480 Part Name: 'LIMITS' ROM: 1, Addr: 0x00000DAC0000, Size: 32.00 KB Reading Partition.. Read Done. Count: 64 Part Name: 'DEVINFO' ROM: 1, Addr: 0x00000DAC8000, Size: 5.22 MB Reading Partition.. Read Done. Count: 10688 Part Name: 'PAD' ROM: 1, Addr: 0x00000E000000, Size: 256.00 KB Reading Partition.. Read Done. Count: 512 Part Name: 'MODEMST1' ROM: 1, Addr: 0x00000E040000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'MODEMST2' ROM: 1, Addr: 0x00000E440000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'SEC_EFS' ROM: 1, Addr: 0x00000E840000, Size: 16.00 MB Reading Partition.. Read Done. Count: 32768 Part Name: 'EFS' ROM: 1, Addr: 0x00000F840000, Size: 16.00 MB Reading Partition.. Read Done. Count: 32768 Part Name: 'SPLASH' ROM: 1, Addr: 0x000010840000, Size: 11.00 MB Reading Partition.. Read Done. Count: 22528 Part Name: 'APDP' ROM: 1, Addr: 0x000011340000, Size: 256.00 KB Reading Partition.. Read Done. Count: 512 Part Name: 'MSADP' ROM: 1, Addr: 0x000011380000, Size: 256.00 KB Reading Partition.. Read Done. Count: 512 Part Name: 'PARAM' ROM: 1, Addr: 0x0000113C0000, Size: 12.00 MB Reading Partition.. Read Done. Count: 24576 Part Name: 'PERSIST' ROM: 1, Addr: 0x000011FC0000, Size: 32.00 MB Reading Partition.. Read Done. Count: 65536 Part Name: 'MISC' ROM: 1, Addr: 0x000013FC0000, Size: 1.00 MB Reading Partition.. Read Done. Count: 2048 Part Name: 'SYSCFG' ROM: 1, Addr: 0x0000140C0000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'MCFG' ROM: 1, Addr: 0x000014140000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'DPO' ROM: 1, Addr: 0x000014540000, Size: 8.00 KB Reading Partition.. Read Done. Count: 16 Part Name: 'LOGDUMP' ROM: 1, Addr: 0x000014542000, Size: 64.00 MB Reading Partition.. Read Done. Count: 131072 Part Name: 'KEYSTORE' ROM: 1, Addr: 0x000018542000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'CONFIG' ROM: 1, Addr: 0x0000185C2000, Size: 32.00 KB Reading Partition.. Read Done. Count: 64 Part Name: 'OEM' ROM: 1, Addr: 0x0000185CA000, Size: 256.00 MB Reading Partition.. Read Done. Count: 524288 Part Name: 'BOOT' ROM: 1, Addr: 0x0000285CA000, Size: 64.00 MB Reading Partition.. Read Done. Count: 131072 Part Name: 'RECOVERY' ROM: 1, Addr: 0x00002C5CA000, Size: 64.00 MB Reading Partition.. Read Done. Count: 131072 Part Name: 'DEBUG' ROM: 1, Addr: 0x0000305CA000, Size: 10.21 MB Reading Partition.. Read Done. Count: 20912 Part Name: 'STEADY' ROM: 1, Addr: 0x000031000000, Size: 4.00 MB Reading Partition.. Read Done. Count: 8192 Part Name: 'PERSISTENT' ROM: 1, Addr: 0x000031400000, Size: 512.00 KB Reading Partition.. Read Done. Count: 1024 Part Name: 'BOTA' ROM: 1, Addr: 0x000031480000, Size: 35.50 MB Reading Partition.. Read Done. Count: 72704 Part Name: 'SYSTEM' ROM: 1, Addr: 0x000033800000, Size: 3.75 GB Reading Partition.. Read Done. Count: 7864320 Part Name: 'VENDOR' ROM: 1, Addr: 0x000123800000, Size: 976.00 MB Reading Partition.. Read Done. Count: 1998848 Part Name: 'PRODUCT' ROM: 1, Addr: 0x000160800000, Size: 328.00 MB Reading Partition.. Read Done. Count: 671744 Part Name: 'CACHE' ROM: 1, Addr: 0x000175000000, Size: 212.00 MB Reading Partition.. Read Done. Count: 434176 Part Name: 'OMR' ROM: 1, Addr: 0x000182400000, Size: 55.00 MB Reading Partition.. Read Done. Count: 112640 Part Name: 'MODEM' ROM: 1, Addr: 0x000185B00000, Size: 93.00 MB Reading Partition.. Read Done. Count: 190464 Part Name: 'BACKUP_GPT_LAYOUT_ROM1' ROM: 1, Addr: 0x000747BFBE00, Size: 16.50 KB Reading Partition.. Read Done. Count: 33 Creating RawProgram XML.. XML Created.. For Write Back Go To FLASH Tab.. Read Done.. Total Readed Partitions: 72 Total Readed Files Size: 0x00018BC03600 Bytes/6.18 GB Path: D:\A207FXXU3CUL1_eMMC File Manager Backup\ Operation Done: [Read Partitions], Elapsed: 00:37:54:249 Reset Google FRP v2.0 Search Google FRP Partition.. Partition #62 -> 'PERSISTENT' is FRP. Erasing Partition. Please Wait.. Erasing Done Backup Saved as: D:\Software\Z3x Box\EmmcManager-1.21-09-01-2022_Final_Easy+JTAG+Plus+Team+by+GSM+iNFO\Backup\FRP_BACKUP_0x000031400000_0x20220329_131254.bin Reset Google FRP Done Elapsed Time: [00:00:14:415] Operation Done: [Reset FRP], Elapsed: 00:00:14:424 |
The Following 3 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
